How do I check the authentic date of a photo sent via Messenger?
Thomson121 76116 3
  • #1 19564357
    Thomson121
    Hello ;)
    I have the following question. Is it possible to check the actual date of taking a photo that was sent via messenger? Possibly the equipment with which it was made ... In a very urgent matter ... I tried to check it on a laptop. But it only shows the date it was downloaded to the laptop. Thanks in advance for all replies ;)
  • #2 19564359
    dt1
    Admin of Computers group
    Help: 7318
    Rate: 8296
    Hello. Right click on the computer on the photo and select properties, see if there is a details tab. If any information of this type is embedded, you will find it there.
  • #3 19564361
    Thomson121
    So I did. And unfortunately, it only shows the date it was downloaded from Messenger.
  • #4 19564364
    dt1
    Help: 7318
    Rate: 8296
    From what you can read on the web - Facebook (along with Messenger) and most other Social Media portals and messengers cut EXIF tags from uploaded photos. So, you probably won't be able to get this information from such a photo.
