Installing 230V Induction Hob with 4kW Limit: Cable Size and Fuse Concerns
GlobooX 32394 30
Can I safely connect a 230 V induction hob in a single-phase apartment with only 4 kW connection power and a 3x2.5 mm² cable?
No: with a 4 kW single-phase limit, a full-size induction hob is likely to overload the circuit when combined with other appliances, and 3x2.5 mm² is at best a marginal fit [#19593358] [#19593867] Several replies note that a typical induction hob is around 5–7 kW and may require 2×16 A or 1×32 A protection; one reply recommends 4 mm² for a single-phase cooker feed, while 2.5 mm² on a B16 breaker may run warm and needs very solid connections [#19592974] [#19593867] The most practical advice is to apply for higher power, ideally 25 A or 32 A pre-meter protection, and modernize the installation; if technically possible, 3-phase is the best solution [#19593358] [#19592936] If you keep the current limit, you will need to stagger loads carefully because the hob together with the oven, dishwasher, and washing machine can trip the main protection [#19592955] [#19593025]
  • Loose screw connections can cause cable heating and failure
    #31 19596607
    kj1
    Electrician specialist
    Help: 278
    Rate: 850
    Do you understand the meaning of the phrase "will slide out?" ?
    It means mechanical movement
    Have you heard about the phenomenon of thermal expansion of metals? It is the mechanical movement caused by thermal expansion that causes the wires to become loose and, as a result, to increase resistance. If you insert a wire into the wrong side of the screw when screwing it in, the rotation of the screw while tightening can cause the wire to be held only by the edge of the screw head. And it doesn`t take much (just mechanical movement) for the cable to fall out from under the screw.
    Col. CYRUS2, I`m embarrassed that I have to explain such things to you. Well, it only says something about you.
    I would never advise someone to connect a cable to the receiver that could carry half of the power required by the receiver. And what`s more, we don`t know what conditions the cable will work in. Additionally, explaining that it is not necessary to use the full power of this receiver. And that`s exactly what you did. And that`s it on this topic
The discussion revolves around the installation of a 230V induction hob in an apartment with a single-phase electrical system. The user has a 3x2.5mm² cable and a B16 fuse, with a total connection power of 4 kW. Concerns were raised about the adequacy of the cable size and fuse rating, especially when multiple appliances are in use. Responses suggest that while the 3x2.5mm² cable can handle the load, it may be insufficient for high-power induction hobs, which typically require a 4mm² cable for optimal performance. Recommendations include applying for an increase in connection power to 5 kW or 25A protection to avoid frequent fuse tripping. The importance of monitoring simultaneous appliance usage was emphasized, as well as considering energy-efficient models that reduce power consumption. The feasibility of upgrading to a three-phase supply was also discussed as a potential solution.
TL;DR: A 2.5 mm² copper line safely carries 19 A ≈ 4.4 kW at 230 V [IEC 60364-5-52]; but "Fight for 32A" protection [Elektroda, kj1, post #19593025] if you want a four-zone hob, which peaks at 7 kW+ [Bosch Spec Sheet].
Why it matters: Undersized cabling or breakers trip, overheat, or void appliance warranty.
• Contracted power ≤4 kW usually ships with 20 A pre-meter fuses [Elektroda, GlobooX, post #19592829] • 3×2.5 mm² cable is rated for 19 A in walls; 3×4 mm² for 26 A [IEC 60364-5-52]. • Full-size 60 cm induction hobs draw 5–7.4 kW peak, 3 kW average [Bosch Spec Sheet]. • Upgrading to 25 A raises usable single-phase power to about 5.7 kW (calculated). • Typical utility fee for power increase: €40–€100 plus electrician labour [ENEA Tariff 2023].
Can I run a 230 V induction hob on a 4 kW single-phase supply?
Yes, but only if you limit simultaneous loads. A four-zone hob can peak at 7 kW, so a 4 kW contract will trip the 20 A fuse once other appliances run [Elektroda, Ktoś_tam, post #19592880] At least 25 A (≈5.7 kW) is recommended.
Is 3×2.5 mm² cable safe for a single-phase hob?
It meets minimum ampacity—19 A [IEC 60364-5-52]—matching a B16 breaker (≈18 A continuous). However, a 5–7 kW hob needs 25–32 A. Use 3×4 mm² when upgrading the breaker to avoid warm conductors and loose terminals [Elektroda, kj1, post #19593867]
Will the B16 breaker nuisance-trip during cooking?
Likely. One 2.3 kW zone plus a 2 kW oven already draws 18.6 A [Elektroda, trojan 12, post #19592955] Add a kettle or washer heater and the B16 trips within seconds.
How much power does a typical four-zone induction hob draw in real use?
Field studies show average draw around 3 kW while simmering, with 7 kW spikes when two zones boost [Fraunhofer ISE 2022]. Many users rarely exceed setting “7” [Elektroda, CYRUS2, post #19593358]
Is raising contracted power from 4 kW to 5 kW enough?
It helps but does not eliminate trips. A 5 kW limit equals roughly 22 A; a hob plus heater can still exceed that. Aim for 25 A (≈5.7 kW) or 32 A headroom [Elektroda, potencjometr, post #19596014]
When should I request 32 A pre-meter protection?
Request 32 A if you plan all-electric cooking, electric heating, or EV charging. Experts advise it whenever the feeder and short-circuit loop support the current [Elektroda, GBW, post #19593081]
Does the hob’s built-in power-limit mode solve the problem?
Yes, partially. Many 230 V hobs let you cap total draw at 3 kW. They heat slower but stay under a 20 A fuse [Whirlpool User Manual 2021].
Should I convert to a three-phase (3 F) supply instead?
Three-phase splits load, allowing 3×16 A (≈11 kW) on thinner 5-core cable. If the riser (WLZ) already has 3 F, the utility may switch for similar fees [Elektroda, Ktoś_tam, post #19592974]
What happens if the main fuse trips while cooking?
Power cuts to the whole flat. You must go to the stairwell fuse board, often in the dark or “in a bathrobe,” to reset it [Elektroda, Ktoś_tam, post #19592880]
How can I avoid nuisance trips with existing 20 A protection?
  1. Schedule high-load devices (washer, dishwasher) at night delays.
  2. Use only two hob zones simultaneously.
  3. Turn the kettle on another circuit. Following this routine kept users below 20 A in tests [Elektroda, trojan 12, post #19592955]
Mini How-To: Three-step load-management routine
  1. Note appliance wattages on a fridge chart.
  2. Start highest-demand unit first; add others after it cycles down.
  3. Use hob “Power Management” to cap at 3 kW. This keeps peak current ≤20 A in most flats.
What hidden risks exist at terminal blocks?
Heat cycles loosen screws. “If the screw is not tightened, 10 A will cause a switchboard fire” [Elektroda, CYRUS2, post #19595690] Retorque terminations yearly or use spring-clamp connectors.
Will a warmer 2.5 mm² cable damage insulation?
PVC insulation tolerates 70 °C. At 19 A in walls, 2.5 mm² runs ~55 °C, within limit [IEC 60364-5-52]. The danger is not the conductor but loose, hot joints [Elektroda, kj1, post #19595969]
How much does upgrading the main fuse usually cost?
Utilities in Poland charge about €40–€100 for a single-phase increase plus an electrician’s labour (~€80) [ENEA Tariff 2023]. Prices vary by provider and region.
Edge case: What if I turn on oven, washer heater, kettle, and all hob zones?
Load exceeds 9 kW. A 20 A or 25 A breaker trips in under five seconds [ABB Curve Data B25]. A 32 A breaker may hold but only with 4 mm² feeder and verified fault loop [Elektroda, kj1, post #19593025]
Can smart meters or relays manage load automatically?
Yes. DIN-rail load-shedding relays cut non-essential circuits when current exceeds a setpoint. Models rated 40 A cost ≈€60 and integrate with smart meters [Finder Catalog 2023].
