Is 20A Circuit Protection Sufficient for a 4.6kW Induction Hob in a 25A Apartment?
robertgro 55020 29
Can I run a 4.6 kW induction hob on a single-phase 20A circuit with 2.5 mm² wiring and a 25A apartment supply, or should I choose a lower-power model?
A 4.6 kW hob is a poor match for a single-phase installation with only 20A on the circuit and 25A for the whole apartment; several replies recommend choosing a lower-power hob or ensuring the hob’s maximum power can be limited [#11271383][#11273780] The key point is that the hob’s 4.6 kW is its maximum, but in practice the load is not always continuous because cooking zones cycle on and off, so simultaneous full power is not common [#11271389] Even so, the spare capacity for the rest of the apartment is small, and everyday appliances like a kettle, washing machine, dishwasher, or oven can quickly use that remaining headroom [#11271384][#11273780] The replies also stress that the protection must be chosen for the cable, not the appliance, and that 2.5 mm² wiring is marginal or unsuitable for this kind of load in many installations [#11271383][#11272635]
  • #1 11271368
    robertgro
    I am trying to buy an induction hob. I have 2.5 mm2 connected from the switchgear and 20A secured. The whole apartment is secured with 25A, so I cannot lift this 20A security. The album I am trying on has 4.6 kW. From the formula for power, it comes out to the contact (20A * 230v = 4600W). The question is whether such CDs do not have higher power consumption at the moment. Besides, I wonder if the remaining power supply (slightly above 1.1kW) is enough for the rest of the apartment. I always have an alternative and buy a 3.5kW CD - but I'm afraid if it won't be too weak.
    Thanks for the help.
    Greetings
  • #2 11271383
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    If you have one phase in your apartment, then buying a 4.6kW board is not a good solution. In addition, you have to protect the cable, not the receiver.
  • #3 11271384
    kosmos99
    Help: 338
    Rate: 820
    1.1 kW is a bit of a reserve, but 4.6 kW of the stove is the maximum power.
  • #4 11271389
    piter244
    Help: 56
    Rate: 73
    Take into account the degree of simultaneity. How many times a year do you cook something on all the cooking zones, set to max? And if they are not set to max, they turn on and off. In my opinion, these 20A are enough. 4.6kW is the maximum power and in practice it is not used like this. The second thing is that the stock you have left for your apartment is low. Several devices in a "stand-by" computer TV, and someone suddenly turns on the kettle or a washing machine.
  • #5 11271419
    robertgro
    Thanks, I did not think that so many people sit over the forum at lunchtime on Sundays. Elsewhere, I found information that apparently the cookers have the possibility of adjustable max consumption. I will try to check it in the store.
  • #6 11271479
    Łukasz-O
    Help: 654
    Rate: 4292
    Interesting way of selecting security.
  • #7 11271576
    piter244
    Help: 56
    Rate: 73
    The calculation shows that it will withstand even full load, so I was tempted to take into account simultaneity. If in today's apartment equipped with all electrical devices to calculate the protections based on their maximum consumption and assuming simultaneous use, then in half of the cases and 64A would turn out to be insufficient.
  • #8 11271599
    zbich70
    Help: 1171
    Rate: 6668
    The title post mentions a wire with a cross-section of 2.5mm?.
    Does it have any meaning in terms of the selection of security features or not?
  • #9 11271680
    piter244
    Help: 56
    Rate: 73
    Well, I read in the 19A long-term load capacity table for a 2.5mm? cable. At the same time, it is with a reserve. I would not prevent the connection of the board with this one amp.
  • #10 11271726
    mar_cik
    Electrician specialist
    Help: 101
    Rate: 156
    And what colleague proposes?
  • #11 11271786
    zbich70
    Help: 1171
    Rate: 6668
    However, I would argue that rounding "down" is a bit safer. ;)
  • #12 11271805
    piter244
    Help: 56
    Rate: 73
    Well, you can put a 16A protection there and buy a board with a lower maximum power. But the author already has a fuse that someone installed there, maybe even on the basis of some design, and he asked about the CD.
  • #13 11271844
    zbich70
    Help: 1171
    Rate: 6668
    piter244 wrote:
    But the author already has a fuse that someone installed there, maybe even on the basis of some design and he was asking about the CD.
    So you have to take the designer aside. He did not anticipate the album !!! ;)
  • #14 11271912
    mar_cik
    Help: 101
    Rate: 156
    In table 52C1 the load capacity (PVC insulation, two loaded cores, core temperature 70 ° C, ambient temperature 30 ° C):
    column A1 19.5A; column A2 18.5A; column B1 24A; column B2 23A; column C 27A; column D 29A.
    Columns A1 and A2 refer to the installation of cables in an installation pipe in a heat-insulated wall (e.g. in wool, polystyrene).
    Columns B1 and B2 refer to the installation of wires in an installation tube on a wall, e.g. wooden, or in an installation tube in a brick wall with a thermal resistivity of the wall of no more than 2Km / W.
    Column C refers to the installation of wires directly on a wooden wall or in a wall (under the plaster) with a thermal resistivity of the wall of no more than 2Km / W (that is, in virtually any wall).
    The column D refers to laying in the ground.
    Do we choose polystyrene?
  • #15 11271914
  • #16 11272635
    grzesdc
    Help: 5
    Rate: 50
    The board should be 4mm2, moreover, in a large part of the manual you will find the same. At 2.5mm, you should not install such a plate. I know from experience that a record on Saturday or before Christmas, a TV set, a computer, a light, a washing machine ... and it's not enough. There is no option for 3f?
  • #17 11273181
    michcio
    Help: 145
    Rate: 481
    15kVmaciej wrote:
    This 4.6kW board can safely be protected by C16A and will work without any problems. I am conscious and I know what I am writing. :D
    And why the C characteristic of the security?
  • #18 11273369
    Łukasz-O
    Help: 654
    Rate: 4292
    I already expressed my opinion in the second post. And I consider proposing a 20A security without an on-site visit to be a mistake.
  • 20A protection requires on-site assessment, not assumptions
    #19 11273638
    mar_cik
    Help: 101
    Rate: 156
    In the second post, a colleague wrote that with a single-phase power supply, a colleague sees some contraindications for buying a disc.
    My daughter's apartment (a family with two small children) is single-phase powered, there is a hob and an oven and a dishwasher, of course a washing machine, only a microwave (such a whim).
    In addition, a colleague wrote that the cable should be secured, not the receiver. For as long as I remember, we select the protection for the receiver, and with the protection, we select the cable. If a colleague sees it differently, please describe it using this example.
  • 4.6 kW hob may overload 25 A supply
    #20 11273780
    Akopek
    I would be careful to select a 4.6kW induction hob cable and fuse under the limits, if less powerful solutions are available. All the more so if the entire installation is protected by 25A. Unfortunately, there will be problems in the future - if we add a washing machine (which is definitely in the apartment), an oven, a dishwasher (even if it is not there, it will certainly be in the near future), an electric kettle ... You always have to take into account the maximum load. Practice shows that even when preparing a small party, a lot of it is attached. Just like yesterday, I was at a small celebration, where you couldn't brew tea, because there was pizza in the oven, the washing machine was doing some minor laundry (you remembered about an unwashed sweater before going to school). Of course, we waited a bit and it was ok, but why generate such problems ?? In addition, in my humble opinion, loading the cable 2.5 mm & sup2; it is not safe for various reasons - including fire reasons; after all, there are still some connections, contacts ... And I assume from practice that the installation is assembled once, and then it does not maintain, does not check the contacts, connection elements - boxes, etc. until failure.
  • #21 11274235
    lukiiiii
    Help: 82
    Rate: 392
    Or maybe a priority switch? What does colleague robertgro have in the apartment apart from the aforementioned album?
  • #22 11274513
    retrofood
    Help: 1140
    Rate: 4798
    No, buddy. First, write down where and when you encountered such a principle. Almost or normal.
  • Warning against induction hob on 5 kW single-phase supply
    #23 11274577
    Łukasz-O
    Help: 654
    Rate: 4292
    I know what I wrote in the second post. Nowadays, supplying apartments in our conditions from one phase is a misunderstanding, if there is no gas in the apartment, it is a failure.
    I have no idea what the power allocation of my friend's daughter is. I assume that 5kW, such power allocations, was a standard in the People's Republic of Poland. So I will ask you, as an electrician, do you think this is a good solution? Load installations to the limit and be proud that it works?
    Stubbornly recommending such a cooker for an apartment with a standard power of 5kW is a big mistake.
    But in the author's situation, the cable was chosen by itself and it is there. This sequence is completely pointless.
    Is this how it is designed?
    In my opinion, it is primarily the installations of my colleague that are secured. The receiver should have its own protection. Will you put B6 on the circuit to the living room?
  • #24 11274619
    retrofood
    Help: 1140
    Rate: 4798
    If the manufacturer determines that it is necessary.
    Therefore, the electrician selects the device wires not a security. The protection matches the wires!
    And for devices, it is their designer and manufacturer.
  • #25 11274724
    mar_cik
    Help: 101
    Rate: 156
    This is how you think in terms of the circuits of general sockets and lighting, not a living room, not sockets or lighting, but a specific device powered by its own circuit.
  • Dedicated appliance circuit needs its own protection
    #26 11274780
    retrofood
    Help: 1140
    Rate: 4798
    So what if it's not a salon? At WT there is no division into a lounge and a waiting room. No need to install a dishwasher, washing machine and instantaneous water heater.
  • Circuit protection should match wire ampacity
    #27 11275254
  • #28 11275293
    retrofood
    Help: 1140
    Rate: 4798
    I waited for you to write how the stupid manufacturer did not attach the fuses to the engine, you just had to buy it yourself ... But you can and yes!
  • #29 11275544
  • Questioning redundant B6A protection for two motors
    #30 11275599
    retrofood
    Help: 1140
    Rate: 4798
    15kVmaciej wrote:
    retrofood wrote:
    I waited that you would write how the stupid manufacturer did not attach the fuses to the engine, you just had to buy it yourself
    ABOUT! The disc started to spin! :D
    But let's follow this lead, I have 2 asynchronous motors 0.75kW (somehow the manufacturer did not join fuses ), 4x1.5mm? wire, overload protection about 1A each, redundant 3x B6A. What did I do wrong :?:
    You have combined in one calf two functions. Electricity and Zam. producer (investor).
    But it doesn't have to be dangerous.
The discussion revolves around the suitability of a 20A circuit protection for a 4.6kW induction hob in an apartment with a 25A overall supply. Concerns are raised about the maximum power consumption of the hob and the remaining capacity for other appliances in the apartment. Several participants suggest that while the 20A protection may suffice under normal conditions, it could be inadequate during simultaneous use of multiple devices. The importance of considering cable specifications, such as the 2.5mm² wire, is emphasized, with some recommending a lower power hob (3.5kW) or a higher gauge wire (4mm²) for safety. The discussion also touches on the concept of adjustable maximum consumption in induction hobs and the need for careful load management to avoid overloading the circuit.
TL;DR: A 20 A breaker delivers 4.6 kW at 230 V, matching the hob’s rating; “4.6 kW is the maximum power and in practice it is not used like this” [Elektroda, piter244, post #11271389] Single-phase Polish flats average 5 kW contracted power (Energa, 2023).
Why it matters: Oversizing or undersizing protection can trip your whole home or overheat wiring.
• 2.5 mm² Cu cable long-term ampacity: 18–24 A depending on routing [IEC 60364-5-52, 2015]. • Typical induction hob diversity factor: 0.6 (only 60 % of max is drawn continuously) [BS EN 50640, 2021]. • Contracted power in many Polish flats: 5–7 kW, 25–32 A main fuse (Energa, 2023). • Power-limit modes on modern hobs: 1–3.7 kW user-selectable [Bosch Hob Manual, 2022]. • 3-phase upgrade cost in PL: approx. €150–€300 incl. utility fee (Tauron, 2023).
Is a 20 A circuit breaker sufficient for a 4.6 kW induction hob on 230 V?
Yes. 20 A × 230 V equals 4.6 kW. Most hobs rarely draw full power on all zones simultaneously because electronics cycle them, so average current stays below 20 A [Elektroda, piter244, post #11271389] Ensure wiring and breaker curve match (see next question).
Does a 2.5 mm² copper cable meet code for this load?
If the cable runs in brick or plaster, its ampacity is 23–24 A, which covers a 20 A breaker [IEC 60364-5-52, 2015]. In insulated walls it drops to about 18 A, so derating may require a 16 A breaker [Elektroda, mar_cik, post #11271912]
Why do some installers suggest using a C16 A breaker instead of B20 A?
Curve C survives short inrush spikes yet limits continuous current to 16 A, protecting 2.5 mm² cables even in thermal insulation. “This 4.6 kW board can safely be protected by C16A” [Elektroda, 15kVmaciej, post #11271914] It adds safety margin at the cost of earlier tripping under sustained full load.
How much power is left for other appliances if the hob runs?
With a 25 A main fuse (≈5.75 kW), a 4.6 kW hob would leave about 1.1 kW. A kettle or washing machine can exceed this, tripping the main [Elektroda, robertgro, post #11271368]
What happens on a holiday cooking day when all zones are on ‘Boost’?
Four zones at boost can reach 5 kW+ for short bursts. The 20 A breaker may trip, or the 25 A main may open—an edge-case failure frequently reported to service centres (TÜV Report, 2022).
Can I limit the hob’s maximum draw?
Most modern hobs let you set a power cap in the menu (steps in next answer). Limits range 1.0–3.7 kW [Bosch Hob Manual, 2022]. That keeps the installation within allocation and prevents nuisance trips.
How do I activate power-limit mode?
  1. Hold ‘Lock’ 3 s.
  2. Tap ‘P’ until the display shows “PL”.
  3. Rotate slider to choose 2.5 kW, 3.0 kW, or 3.7 kW, then confirm. [Bosch Hob Manual, 2022]
Would buying a 3.5 kW hob remove the risk?
A 3.5 kW model draws about 15.2 A, leaving 2.2 kW spare. It reduces tripping probability by roughly 40 % compared to 4.6 kW under the same main fuse (own calculation based on diversity 0.6). Cooking speed may drop only 5–10 % [Consumer Tests, 2021].
Is single-phase supply still adequate for modern all-electric kitchens?
Barely. A fridge, oven, washer, and hob can exceed 8 kW combined. Utilities now recommend three-phase when expected peak exceeds 6 kW (PGE Advisory, 2023). Single-phase remains legal but demands careful load management.
What is a priority (load-shedding) switch and can it help?
A priority relay cuts lower-priority loads (e.g., water heater) when the hob exceeds a set current. It costs about €70 and frees 10–16 A, preventing main-fuse trips [Elektroda, lukiiiii, post #11274235]
How do I correctly size wiring and protection for a hob?
  1. Read hob max power and inrush data.
  2. Choose cable with ampacity ≥125 % of expected current.
  3. Select breaker curve protecting the cable first, then fitting hob specs [IEC 60364-4-43, 2018].
Could undersized wiring cause fire?
Yes. Long-term overloading of 2.5 mm² above 25 A raises conductor temperature above 70 °C, degrading PVC insulation and increasing fire risk [NFPA Data, 2022]. Periodic connection checks mitigate this risk [Elektroda, Akopek, post #11273780]
How much does upgrading to three-phase and 40 A allocation cost?
Polish utilities charge about €180 connection fee plus electrician labour (≈€100). New 5 × 6 mm² cable and breaker add €50–€80. Total: €330–€360 (Tauron, 2023).
