Huawei B535-232 - Failed Update, Lost Menu & Offline: How to Restore Firmware?
adriansi 26805 17
How can I restore firmware on a Huawei B535-232 after flashing the wrong file and losing the web menu?
Yes—restore it through the router’s multicast upgrade mode, not from the web menu. Start the modem with Reset+WPS pressed and keep them held for about 10 seconds after power-up, then set the PC network card to 192.168.8.100/24 [#19786842] Flash only the correct .bin file; for the B535-232 the firmware usually has to be a matching, signed modem + WebUI pair, and wrong C-version packages will not flash [#19786842] [#19800143] The thread also says MIX packages exist that contain both modem and WebUI, and the multicast tool can load modem and WebUI separately, but you still need the right pair [#19788304] [#19789933] If you need to force a C-version change, the multicast tool requires a key tied to the PC [#19873927]
  • #1 19658258
    adriansi
    Rate: 15
    I updated the modem with the wrong firmware. The effect that the device is supposed to work, but there is no menu and it is offline.
    Is it possible to upload the software in a different way than from the menu?
  • UART recovery suggested for dead Huawei B535-232
    #2 19660718
    KOCUREK1970
    Help: 3861
    Rate: 5489
    You probably need to disassemble the modem, connect via UART (if mabo has the right pins) and have a batch file for the programmer - I'm guessing, but this is how you save the equipment completely dead (if it shows any activity via UART).
    https://www.ispreview.co.uk/talk/threads/huawei-b535-232-4g-lte-router-issue.36112/page-40
  • WebUI inaccessible and firmware update tools failing
    #3 19684763
    adriansi
    Rate: 15
    I've searched a bit on the net, tried, etc.
    The modem generally works. Connected to another router via WAN, it transmits internet, wifi broadcasts, etc.
    The problem is that I can't login to it as if it had no configuration menu at all (WebUI??). After entering the address of the router 192.168.8.1, this address changes to the address https://hirouter.net. and that's it.
    I tried to log in via Ai Life, the router is detected, but I can't enter the configuration menu.
    The Update_WEBUI_10.0.1.1(W2SP3C55) application detects the router but has a problem with detecting the ports and aborts the update.
    multicast_upgrade_tool - I can't set the router to Update_mode... and the program doesn't start, besides it shows me a message about the wrong file.
    Anyone got any ideas?
  • #4 19750557
    pawol
    Help: 18
    Rate: 130
    I have the same problem. Where did you get this Update_WEBUI app from?
  • #5 19750646
    adriansi
    Rate: 15
    firmware and so on
    I will unpack the files with the program from the package or download it from the net because my antivirus shouted something there. The update_webui app comes with firmware files named webui.
  • #6 19750682
    pawol
    Help: 18
    Rate: 130
    For now, I have a console after uartie, but the hell is not going to stop uboota
    Added after 32 [minutes]:
    So this application is to be updated via USB. There is something missing on the board. On the example of B525 - puts the router into flashing mode, connects the usb cable to the board, launches the application. She's just looking for a virtual Com
  • SSL certificate issue blocks the router web UI
    #7 19762293
    pawol
    Help: 18
    Rate: 130
    So it looks like there is some problem with the SSL certificates and that's why the page is not displayed. People were hanging out with similar topics with huawei 5G modems.
    In general, the API speaks, the router works (without the gui of course), even by some miracle it manages to connect with the AI life application from time to time - anyway, probably after this API. I don't know how I did it. Rather, it was AI life from the playa store in version 11 than a moment later updated to version 12. After configuring the APN in this app, 4G transmission is heard.
    It seems that the solution will be to use the API to log in and force download the update (e.g. original WEBUI 4SP983 for me) from the file.
    I'm too skinny for that
  • USB boot mode via shorting the mode pin to GND
    #8 19768445
    pawol
    Help: 18
    Rate: 130
    Well, it is still necessary to invent where they skitrali USB on the disc. It is possible to enter the boot usb mode modem after shorting the USB mode pin from the drawing to GND. You can see it in the UART console
    Added after 17 [minutes]:
    And the router is on chips:
    Hi6932 (BB), Hi6559 (PMU), Hi6362 (RFIC)
    Added after 16 [minutes]:
    Balong Hi6932 or V7R22 also has B525 / B528, so in case there is a usb loader
  • #9 19769822
    pawol
    Help: 18
    Rate: 130
    I bit the tamat and found the USB. However, loaders from b525, 528 and e5785 do not match.
    I contacted the Russian developer of the usbloader and we'll see what comes up
    • B535_uart_usb_mode.jpg (1.28 MB) You must be logged in to download this attachment.
    • B535_USB pads.jpg (1.32 MB) You must be logged in to download this attachment.
  • #10 19786842
    pawol
    Help: 18
    Rate: 130
    I found out that by starting the modem with reset+WPS pressed (hold 10 seconds after starting) we enter the multicast upgrade mode. The PC network card should have IP 192.168.8.100/24.
    Puki what flashes only felerne B535_11.0.1.2 (H200SP2C21) for the same. Other versions cling to the wrong C version. The FW file must have the .bin extension (the package contained .zip without .bin)
    • Multicast_Upgrade_Tool_v1.1.0.zip (784.1 KB) You must be logged in to download this attachment.
    • Przechwytywanie.JPG (47.38 KB) You must be logged in to download this attachment.
    • LTE_CPE_upgrade_tool_changeVer.zip (1.31 MB) You must be logged in to download this attachment.
  • Missing webui in firmware packages causes update bug
    #11 19788304
    pawol
    Help: 18
    Rate: 130
    So the cause of the bug is the fact that there is usually no webui in the firmware packages. There has been a crossover between the compatibility of the modem firmware with webui. There are supposedly MIX packages containing modem and webui firmware in one.
    https://qyyd5g.top/%E5%8D%8E%E4%B8%BAB535-232(%E7%8E%B0%E5%AD%98)%E5%9B%BA%E4%BB%B6%E6 %B1%87%E6%80%BB/
    and it should be uploaded via multicast.
    Puki what internets do not find such packages
  • #12 19789933
    pawol
    Help: 18
    Rate: 130
    Multicast tool with the ability to load webui and modem separately.
    It's still a matter of finding the right pair of packs.
    Personally, I'm looking for webui W2SP2C7201
    or packages MIX-B535-232_UPDATE_10.0.1.1(H191SP61C983).BIN because I had the modem originally from Orange
    • Multicast_Upgrade_Tool_Ver1005.zip (1.42 MB) You must be logged in to download this attachment.
  • Signed modem-webui pair required for B535 firmware recovery
    #15 19800143
    pawol
    Help: 18
    Rate: 130
    Well known but not very useful. The problem is that the b535 packages must be a modem - webui pair because they are signed. The Chinese table in the post above explains it. Soft cannot be loaded if it is not from steam. Unfortunately, there is not much webui on the net, even in the C7201 version. The rescue is a mix package, which are also unavailable and the Chinese does not speak.
    You can't change the C version of the packages either because it's locked. Also without the proper original packages is linden
  • #16 19869416
    pawol
    Help: 18
    Rate: 130
    I am attaching the original usbloader for B535-232 for posterity. Usbloader is not patched and therefore there is a high risk of erasing sensitive data (such as IMEI) in the flash memory. And since we are dealing with signed softs in B535-232, it may turn out that we will get a brick.
    • sec_usbloader.zip (8.76 MB) You must be logged in to download this attachment.
  • #17 19873927
    pawol
    Help: 18
    Rate: 130
    With this multicast tool you can force a C version change but you need a key. The key looks like it is assigned to the PC so someone would have to warp it so that it does not ask for the key
  • #18 19873939
    pawol
    Help: 18
    Rate: 130
    With this multicast tool you can force a C version change but you need a key. The key looks like it's assigned to the PC so someone would have to corrupt it
The discussion revolves around issues faced by users of the Huawei B535-232 modem after a failed firmware update, resulting in the loss of the configuration menu and offline status. Users explore various recovery methods, including disassembling the modem to connect via UART, using multicast upgrade tools, and attempting to access the device through different applications like Ai Life. The conversation highlights the importance of using compatible firmware packages that include both modem and WebUI components, as mismatched versions can lead to further complications. Several users share their experiences with different tools and methods, including the need for specific keys to change firmware versions and the risks associated with using unverified loaders. The search for appropriate firmware files and solutions continues, with users sharing links to resources and packages.
TL;DR: To fix a B535-232 with missing WebUI, hold Reset+WPS for 10 seconds and enter “multicast upgrade mode”; “we enter the multicast upgrade mode.” Then multicast-flash an accepted .bin, set your PC to 192.168.8.100/24, and avoid mismatched C versions. [Elektroda, pawol, post #19786842] Why it matters: This helps Huawei B535-232 owners recover a failed update that broke the WebUI, without needing the normal GUI.
How do I fix a Huawei B535-232 that lost its menu after a failed update?
Use Huawei’s Multicast Upgrade mode to restore the WebUI. How-To:
  1. Power on while holding Reset+WPS, keep holding for 10 seconds to enter Multicast Upgrade.
  2. Set your PC NIC to 192.168.8.100/24.
  3. Push an accepted .bin via multicast. One user succeeded with B535_11.0.1.2 (H200SP2C21). Avoid mismatched C versions. This bypasses the browser and replaces the firmware correctly. [Elektroda, pawol, post #19786842]
Why does 192.168.8.1 redirect to hirouter.net and I can’t log in?
A WebUI SSL issue can block the page. The router’s API still responds, and AI Life may connect intermittently. As one expert noted, “there is some problem with the SSL certificates and that’s why the page is not displayed.” Configure APN in AI Life to restore data if needed, then plan an update via API or recovery. [Elektroda, pawol, post #19762293]
Can I update firmware without the web interface?
Yes. Enter Multicast Upgrade mode and push a valid .bin from your PC. Set your PC to 192.168.8.100/24. The router listens for the multicast and accepts signed images. Wrong C versions get rejected, so use a compatible package. This approach avoids the broken browser UI entirely. [Elektroda, pawol, post #19786842]
What is Huawei Multicast Upgrade mode on the B535-232?
It’s a recovery listener you trigger by booting with Reset+WPS held for 10 seconds. The router waits at 192.168.8.1 for a multicast push from your PC at 192.168.8.100/24. It accepts signed .bin images and may refuse other C variants. This is the recommended path when the GUI is gone. [Elektroda, pawol, post #19786842]
Which firmware will actually install via multicast on B535-232?
One confirmed success is B535_11.0.1.2 (H200SP2C21). Others failed with a “wrong C version” message. Ensure the update is a .bin; some archives include only a .zip without a .bin file, which will not load. Use the exact C variant that the router accepts to avoid rejection. [Elektroda, pawol, post #19786842]
Where can I get firmware and WebUI packs for B535-232?
A known source offers paid packs at about $5 each. Availability and content vary, so verify the pack suits your device’s C version before flashing. If your WebUI is missing, seek packs that contain the correct components for your model. [Elektroda, pawol, post #19790292]
Why does Update_WEBUI fail to detect ports on my B535-232?
That tool expects a USB connection exposing a virtual COM port. On some boards you must expose or wire the internal USB pads. As one member put it, “She’s just looking for a virtual Com.” Without USB enumerating, the app aborts. The B525 flashing flow is similar in concept. [Elektroda, pawol, post #19750682]
Can I change the C-version (e.g., C21 to C983) on the B535-232?
Yes, but only with a key. The multicast tool can force a C-version change, yet it prompts for a key tied to the PC. As noted, “the key looks like it is assigned to the PC.” Without that key, the change remains blocked. [Elektroda, pawol, post #19873927]
Do modem and WebUI need to be a signed pair on the B535-232?
Yes. “Packages must be a modem–webui pair because they are signed.” You also can’t freely change C versions; it’s locked. MIX packs combine both elements and can restore a missing GUI when individual pieces won’t load. Use matching, signed content only. [Elektroda, pawol, post #19800143]
Is it safe to use a USB loader or UART to recover?
Use caution. The shared B535-232 usbloader is unpatched and can erase IMEI or other sensitive data. With signed firmware, a failed write may brick the router. Only use a correct, model-specific loader, and understand the risks before proceeding. [Elektroda, pawol, post #19869416]
How do I find the hidden USB and enter USB boot mode?
On the PCB, short the USB mode pin to GND and then power on. The device will enter USB boot mode, visible in the UART console. Reported chips include Hi6932 (BB), Hi6559 (PMU), and Hi6362 (RFIC). This enables USB-based flashing approaches. [Elektroda, pawol, post #19768445]
Will loaders from B525/B528/E5785 work on the B535-232?
No. Loaders from B525, B528, and E5785 do not match this model. A user confirmed the mismatch after finding the USB pads and testing. Always use a loader built for the B535-232. [Elektroda, pawol, post #19769822]
My router works over WAN and Wi‑Fi but has no GUI. What should I try first?
Test the API and Huawei AI Life app. One user connected with AI Life version 11 and, after setting APN there, restored 4G data. Then use API to authenticate and push an update, or plan a proper recovery to re-enable WebUI. [Elektroda, pawol, post #19762293]
Where did the Update_WEBUI app come from?
It was bundled with certain firmware labeled as webui. A user shared a package link and noted antivirus warnings. Extract carefully and verify authenticity before running any updater utilities from such archives. [Elektroda, adriansi, post #19750646]
Can I unbrick via UART if the router seems dead?
Yes. Disassemble the router, connect via UART if the board exposes pins, and use a programmer’s batch file. This approach can revive devices that show activity over UART, even when completely unresponsive otherwise. It requires hardware access and proper scripts. [Elektroda, KOCUREK1970, post #19660718]
