[Solved] Huawei B315s-22 Power LED Only: Repair Guide for USB Cable & E3256sBootRomDownloadTool Usage
fronek22 39675 13
  • #1 16410833
    fronek22
    Rate: 94
    I managed to put the Router Huawei B315s-22. It did not turn on and only the power LED was on and sometimes flashed and there was no reaction:
    We will need a computer, a USB cable type AA male, a soft program and the batch file itself (in the attachment)
    We will pick up our router, remove any plugs from it, unscrew it -2 screws one hidden under the seal
    2. Gently pry the plastic cube and split the casing
    3. unscrew one screw that holds the main board
    4. connect the usb cable to the computer and to our router
    5. run the program E3256sBootRomDownloadTool-2s and select "BootRom" and add the file "usbloader.bin"
    6. Click Next (we open a new window in which we click "Scan & Upgrade"
    7. We are making a jumper with tweezers as I have shown in the picture and holding it so we connect the power supply, the computer will detect our router with the characteristic sound of connecting a USB device and it will start to soften our router (it is not software) the operation takes very quickly. (I did not have time to do the pics at the end of the soft-up)
    8. Later, run our device to pat the 192.168.8.1 and edit the file which takes over 65MB
  • #2 16702823
    Foxtrott
    Help: 253
    Rate: 944
    Could you write which softie you later flash? Because every time I have an "unsuccessful update"
  • #3 16704682
    fronek22
    Rate: 94
    I threw this file, you can also download it and click on the paw ;)
  • #4 16704758
    Foxtrott
    Help: 253
    Rate: 944
    Thank you for good intentions :-) but reading various forums I've come as quick and easy to upload any firmware we want :-)
    ps. the feet are nowhere to be found, and a helpful post does not want to pass the point.
  • #5 16754525
    fronek22
    Rate: 94
    Okay, greetings and the subject I am closing
  • #6 16885720
    wazik87
    Rate: 14
    hello, when I made a jumper, I heard that it detected the device but there is no driver like him to have it 10
  • #7 16890403
    fronek22
    Rate: 94
    I did it under Windows 7 to 10, it may not actually be drivers
  • #8 16890489
    wazik87
    Rate: 14
    I will say this in my white LED lights but I have uploaded fw because I see it as a program to connect the router in USB mode. For me, there is such a strange thing that I do not have IP router does not see the page 192.168.8.1 you can somehow upload it on the router or rather it is some serious fault
  • #9 16899956
    pl_chris
    Help: 34
    Rate: 22
    Everything is nice only after this operation (from what I see) we get a router with the IMEI number removed. Is there any way to enter it manually? The operator may block the device after some time.
  • #10 16918078
    makosuu
    Help: 369
    Rate: 370
    Where does this idea come from? IMEI usually blur on screens.
  • #11 16918451
    pl_chris
    Help: 34
    Rate: 22
    On the screenshots from the Boot Room Download Tool, the IMEI field and the serial number also remain blank. This program modifies the boot area and the manufacturer has to store these individual device numbers somewhere. I would like to be wrong and I hope that the author will explain the matter.
  • #12 16918554
    makosuu
    Help: 369
    Rate: 370
    As far as I know, IMEI can be entered manually and the device without IMEI number will not log on to the network so I do not see the problem. No blocking will be.
  • #13 16956536
    layza
    Thanks for the guide.
    I've fixed this way. The only problem that arose is the need to use the program Balong USB Downloader instead E3256sBootRomDownloadTool because he did not want to find the device. What to posts above. I do not see any problem with the IMEI number.
    Greetings Tomek
  • #14 17728740
    fronek22
    Rate: 94
    It's a very nice topic
✨ The discussion revolves around troubleshooting the Huawei B315s-22 router, which only shows a power LED and fails to boot. Users share a repair guide involving the use of a USB cable and the E3256sBootRomDownloadTool to recover the device. Steps include disassembling the router, connecting it to a computer, and using specific software to upload firmware. Some users report issues with driver recognition on Windows 10 and suggest using the Balong USB Downloader as an alternative. Concerns are raised about the IMEI number being erased during the process, with discussions on whether it can be manually re-entered. Overall, the guide is deemed helpful, with some users successfully restoring their routers.
