[Solved] Buy Sefuse D6SC4 12A98C SMD Assembly Fuse for 4 Li-ion Battery Package
kapikp910i 5376 2
  • #1 19662649
    kapikp910i
    Help: 8
    Hello, I am looking for a place where you can buy the original or a replacement for the Sefuse D6SC4 12A98C SMD assembly. The fuse is mounted in the package of 4 Li-ion batteries.
    • D6-SMD_reference_document_131025.pdf (886.35 KB) You must be logged in to download this attachment.
    Sources for Sefuse D6SC4 fuse suppliers
    #2 19673978
    FreshH
    Help: 11
    Rate: 19
    They have it:
    https://atcsemitec.co.uk
    Here is the manufacturer:
    https://www.schott.com/en-dk/products/lithium-ion-battery-protectors
    And here I found in friends:
    https://en.aliexpress.com/item/10050029890917...d=7347d-b8-d=7347d-b8-d=4347d-b8-d=7347d-b8-d % 22sku_id% 22% 3A% 2212000023091 206 625% 22% 7D
    PS. I can order you if you don't use Ali for some good beer for your trouble.
  • #3 19674031
    kapikp910i
    Help: 8
    I didn't think about Ali. Thank you very much for help.
