[Solved] Redmi Note 9 Pro - the phone turns itself down and makes it louder and switches
patgaret 64314 10
Why does my phone randomly lower and raise the volume and switch or pause music when I listen with headphones?
This is most likely caused by a faulty headphone jack/headphones, although a software bug is also possible. Check the headphone socket for dirt or debris and clean it gently, because a bad connector can trigger volume and playback controls by itself [#19759827] If that does not help, try a hard reset to rule out software problems [#19803918] In this case, the issue was eventually fixed by updating the phone software [#19932253]
  • #1 19755849
    patgaret
    Rate: 56
    I have a problem that when I listen to youtube music, the phone turns down and makes it louder, as if someone was doing it and took control of my phone. I don't know how to check that, I know that one person used to mess with my phone.
  • #3 19755876
    patgaret
    Rate: 56
    I have a phone as in the subject and once someone took my phone and did something and half a year ago when I was listening to Spotify when I was listening to music on headphones, the phone turned itself down and made it louder, stopped songs and played it and today I have YouTube Music and I had the same
  • #4 19759180
    patgaret
    Rate: 56
    I have a damaged jack socket? Or what? Maybe some virus?
    When I unplug my headphones, the phone does not go crazy.
  • #5 19759465
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Do you have this problem while chatting or playing videos?
  • #6 19759617
    patgaret
    Rate: 56
    When you turn on the youtube application, it's the same, turns it down and volume up, stops the video, plays it but doesn't do it all the time, only 30 seconds of peace and again
  • Damaged jack or headphones likely trigger controls
    #7 19759827
    blahfff
    Help: 1036
    Rate: 1301
    when I unplug my headphones, the phone does not go crazy
    You answered yourself. You either have damaged headphones, or bad headphones (different pinout), which themselves trigger these functions, or a damaged jack connector - some kind of crap inside that sometimes shorts out, either mechanically, or some kind of corrosion, etc. First, look at the hole for the headphones and dig out trash it, if there is any, only gently and sensitively, because you can cause more damage by pushing something too deep.
  • Suspected headphone jack or button toggling issue
    #8 19771998
    patgaret
    Rate: 56
    These are another headphones that have this problem, for half a year there was no such problem, the jack connector is clean, but I cleaned it. This is strange because today I listened to music almost all day and there was no problem, and now for a moment the songs themselves switched and now it's quiet again. It looks like someone toggled it, I thought Google Assistant was messing something up. But I turned it off and it's still what it is.
  • #9 19803790
    patgaret
    Rate: 56
    it looks like someone is switching because I listen to music for half an hour and then all of a sudden the songs switch up once a couple of songs then go down, has anyone experienced something like this?
  • #10 19803918
    winmap
    Help: 361
    Rate: 753
    Looks like a damaged connector. Might be buggy software. You can do a hard reset to be sure how you want to copy data etc.
  • #11 19932253
    patgaret
    Rate: 56
    The connector is ok, updating the phone software helped
The discussion revolves around a user experiencing erratic volume control and playback issues on their Redmi Note 9 Pro while using YouTube Music. The user suspects external interference, possibly from a previous incident where someone accessed their phone. Various responses suggest potential causes, including a damaged headphone jack, faulty headphones, or software bugs. Cleaning the headphone jack and updating the phone's software were recommended as solutions. The user later confirmed that updating the software resolved the issue, indicating that the problem was likely software-related rather than hardware damage.
