  • #1 19781062
    polycomp6811
    Good day
    I am wondering if it is possible to set STC90C52 mcu to work with two serial (not at the same time)
    Thank you in advance
    • STC90C51RC-en.pdf (1.05 MB) You must be logged in to download this attachment.
  • STC90C52RC has only one hardware UART
    #2 19782779
    kamyczek
    Help: 394
    Rate: 573
    But this processor only has 1 Uart which means only that the latter would have to be written as software or you would have to switch pins between two modules. Besides, it will still be 51 and even with an 80MHz clock it will only execute 10M instructions per second - that is, any AVR will do the same twice as fast at 16MHz. And in the case of the second teg you will find a chip that has 2 hardware items. And it is even possible that it will be compatible with the conclusions (except for the reset because it works the other way around)
  • #3 19786963
    polycomp6811
    This is very useful information.
    Thank you for taking the time to reply.
