Title: How to Read EEPROM Data from Blaupunkt Bremen SQR 46- Need .bin & Pin Details
macb29 4308 4
  • 8-pin regulator identified, EEPROM still unknown
    #1 19799432
    macb29
    my name is Marcus and I want to read out an EEPROM from an old Blaupunkt Bremen SQR46.
    Inside of the radio looks like this.
    I can’t find details about the EEPROM (seems to be within the 40pin W810 with the three black dots)
    Can somebody help me with details on how to get the .bin? which HW, which pins etc.?
    Best regards,
    German language also possible.
    Marcus
    The littler 8pin is a voltage regulator not the EEPROM:
    The service manual shows this:
  • #2 19802168
    adam white
    Car audio specialist
    Help: 197
    Rate: 328
    Reading this memory is quite mean, but if you just want to turn on the radio, it was a method without a code - applying + 5V voltage through the diode to the metalized point on the ceramic hybrid (W810). Although some Bremen (possibly from later production?) Were resistant to this solution. In this way, other radios with such a design solution were made, eg Gamma from Audi.
  • #3 19802211
    slevy70
    Help: 42
    Rate: 207
    it used to be done with a "slipper"
  • #4 19802237
    adam white
    Help: 197
    Rate: 328
    I dare to doubt. But if you develop the topic and present a credible solution, I will gladly change my mind.
  • #5 19802667
    justka80
    Help: 322
    Rate: 444
    I have included some archival descriptions that may be helpful.
    • Hybryda ceramiczna.rar (1.16 MB) You must be logged in to download this attachment.
