Reverse Status Reporting for Door Sensor in Home Assistant
mrqwert 1212 0
  • Template sensor to invert door contact state
    #1 19803015
    mrqwert
    Rate: 16
    How do I force HO to reverse report the status of the door open sensor?
    At the moment, when the magnet is at the sensor (reed switch shorted) "open" is reported.
    I would like the reverse state to be displayed, i.e. "closed" in this case.
    I found an explanation on the page ( Link ), but I don't know where I should put this piece of code?
    Greetings,
    T.
