[Solved] Junkers Boiler: No Hot Water, Repressurizing & Locating Taps, CE Error Display (Photos)
icader 8262 3
  • Asking how to repressurize a Junkers boiler
    #1 19819475
    icader
    Hi all,
    My Junkers water boiler had suddenly stopped working (i.e. no hot water coming out of the taps). I have done a bit of research online and found out that I would have to repressurize the system. But all the videos I have seen show a pipe with two taps which would have to be turned on to let water flow to the system - I can't find these taps on my Junkers. Attached are some photos - would anyone kindly help? (Note that the red display shows a blinking CE error)
    Thanks a bunch!
    Junkers Boiler: No Hot Water, Repressurizing & Locating Taps, CE Error Display (Photos) Junkers Boiler: No Hot Water, Repressurizing & Locating Taps, CE Error Display (Photos) Junkers Boiler: No Hot Water, Repressurizing & Locating Taps, CE Error Display (Photos)
    serwisszulborski.pl
    Heating systems specialist
    Help: 360
    Rate: 1448
    In order for the device to work properly, the pressure gauge should be approx. 1-1.5 bar. Water to the Junkers should be added with the blue key by turning it anti-clockwise until you hear that water flows into the device. Top up to 1.5bar max and turn right as far as it will go, but not forcefully.
  • #3 19832808
    ROWE
    Help: 239
    Rate: 535
  • #4 19833449
    icader
    Thank you for your help. I did as was mentioned - turned the blue knob to repressurize the water boiler.
