VW Transporter 1.9 td. It smokes in the cold.
serwispcv24 4059 11
Why does my 1.9 TD Transporter smoke black when it is cold but stop smoking after it warms up?
Cold black smoke on a 1.9 TD usually points to injection timing/delivery, glow plugs, air in the fuel lines, or worn injectors, so those are the first things to check [#19825804] One reply recommends checking the injection angle and fuel dosage while the engine is cold [#19825804] Another says to inspect the glow plugs, the injection pump, and then test the injectors if it smokes heavily at idle and then clears up [#19825843] A practical first step is to fit new glow plugs and fuel filters, then verify the injection setup [#19826890]
  • #1 19824311
    serwispcv24
    Hello all, I have a 1.9 td Transporter, on cold it smokes, a little later it doesn't, what to do?
  • #2 19824468
    ciuqu
    Help: 512
    Rate: 829
    What colour does it kick in?
  • #3 19824472
    serwispcv24
    In black, as it warms up it is ok.
  • #4 19824493
    ciuqu
    Help: 512
    Rate: 829
    Do you have manual "suction" or automatic?
  • #5 19824935
    serwispcv24
    The manual intake is a '97 4 with no problems at all.
  • Check injection timing and glow plugs cold
    #6 19825804
    arekkwiatek2
    These are old armoured engines. There may be a few reasons for this - the injectors are watered (but it would fire slightly unevenly), the fuel injection angle is too far ahead, then it fires well but smokes black. Blue if the injection angle is too late, air in the lines to the injection pump, faulty glow plugs. The best thing to do is to connect it to vag in the cold and check the injection angle, fuel dosage. In my opinion.
  • #7 19825826
    dizba
    Help: 239
    Rate: 808
    And since when does "suction" affect fuel delivery ?
    arekkwiatek2 wrote:
    The best thing to do is to cold plug into vag and check injection angle,fuel dosage. In my opinion.
    In a mechanical injection pump ? You have confused the cars.
  • #8 19825843
  • Cold-start fuel enrichment lever explained
    #9 19825979
    ciuqu
    Help: 512
    Rate: 829
    dizba wrote:
    And since when does "suction" affect the fuel dose ?
    You're right, because the diesel doesn't have suction, by writing "suction" in quotation marks I meant the "lever" to increase the fuel dose or to change the injection angle or both, I'm not sure, which in the manual version looked the same as the suction in the petrol engine and basically served the same purpose.
    In later "upgraded" versions, the manual linkage was replaced by an actuator filled with liquid, or perhaps gas, which expanded in response to temperature changes, increasing the dose at low temperatures for the duration of engine start-up and warm-up. I don't know if this was also present in the T4, but it was, for example, in the Golf.
  • #10 19826119
    arekkwiatek2
    dizba mate read here .https://www.golf3.pl/silniki-diesla/1-9-diesel-ssanie-t12177.html
    I didn't confuse the cars possibly the engines or more specifically the injection pumps as the next was a TDI VP 37 which is supported by tdi timing.
    Check the timing because in these engines it supposedly cuts the wedges on the shaft although in your case I don't think so.
  • #12 19826890
    serwispcv24
    Candles, new filters, I think I also need to check the injection
The discussion revolves around a VW Transporter 1.9 TD that experiences excessive smoke during cold starts. The author expresses confidence in their ability to handle fuel pump issues, referencing a specific fuel pump model. A follow-up suggests checking the glow plugs ("candles"), replacing filters, and inspecting the fuel injection system as potential solutions to the smoking problem.
TL;DR: 5 likely causes are cited; "The best thing to do is to ... check the injection angle, fuel dosage." For a VW T4 1.9 TD that smokes cold, start with timing, glow plugs, fuel‑air leaks, then injectors. [Elektroda, arekkwiatek2, post #19825804]
Why it matters: Fast, correct checks stop cold-start smoke, prevent excess soot, and keep your Transporter reliable.
Why does my VW T4 1.9 TD blow black smoke only when cold?
Cold black smoke signals over‑fuelling or advanced injection timing. Blue smoke points to late timing. Check glow plugs and air in the fuel lines. “These are old armoured engines,” but they need correct timing and preheat to burn clean. This thread lists five likely causes: injectors, early/late timing, air‑in, and glow plugs. [Elektroda, arekkwiatek2, post #19825804]
What color smoke means late injection timing on a 1.9 TD?
Blue smoke on cold start indicates late injection timing. As one expert wrote: “Blue if the injection angle is too late.” Black smoke instead suggests early timing or excess fuelling. [Elektroda, arekkwiatek2, post #19825804]
Does this engine have a choke? What is the manual/automatic “suction”?
There is no choke on diesels. By “suction,” owners mean a cold‑start lever that increases fuel for starting. Some versions replaced the lever with a temperature actuator that enriches during warm‑up. Inspect this linkage or actuator if enrichment doesn’t release when warm. [Elektroda, ciuqu, post #19825979]
Can VAG‑COM/VCDS set or read timing on a 1.9 TD mechanical pump?
No. On a mechanical pump, you don’t set timing with VAG diagnostics. That guidance applies to electronic TDI systems. Use a mechanical measurement method instead. [Elektroda, dizba, post #19825826]
How do I check and set injection timing “on the clock”?
Use a dial gauge method. 1. Mount a dial gauge to the pump’s timing port. 2. Set the crank at the timing reference and read the gauge. 3. Loosen the pump, adjust to the specified reading, then tighten and re‑check cold. As one poster said, “the injection … only on the clock.” [Elektroda, Anonymous, post #19825843]
My van smokes black at idle for a bit, then clears—what does that suggest?
That pattern suggests excessive cold‑start enrichment. Check glow plugs first. Then set the injection timing on the clock. If it still smokes, move to injector testing on the bench. [Elektroda, Anonymous, post #19825843]
Could glow plugs alone cause this cold smoke?
Yes. Weak or faulty glow plugs reduce combustion quality when cold and create smoke. The symptom often clears as the engine warms. Test and replace bad plugs before deeper fuel system work. [Elektroda, arekkwiatek2, post #19825804]
Should I suspect air in the fuel lines?
Yes. Air in the lines to the injection pump can cause rough starts and visible smoke. Inspect and bleed the fuel lines. Eliminate leaks before adjusting timing or injectors. [Elektroda, arekkwiatek2, post #19825804]
Is my 1997 T4 likely to have a manual cold‑start lever?
The 1997 example in this thread uses a manual cold‑start control. If yours is manual, ensure the lever returns fully to the off position as the engine warms. [Elektroda, serwispcv24, post #19824935]
Could timing slip due to a sheared key (“wedge”)?
Yes. These engines can shear the shaft key (“wedge”), shifting timing and increasing smoke. If symptoms persist after adjustment, inspect the key and timing alignment. [Elektroda, arekkwiatek2, post #19826119]
When should I consider injector testing?
After verifying glow plugs and setting timing, test injectors if smoke remains. Perform an “on the table” bench test to evaluate them properly. [Elektroda, Anonymous, post #19825843]
What is the recommended troubleshooting order for this issue?
Start with glow plug checks. Next, set the injection timing “on the clock.” Finally, bench‑test the injectors if the smoke persists. [Elektroda, Anonymous, post #19825843]
Why do some advise VAG while others say mechanical timing?
One poster noted the next generation used a VP37 TDI pump with ECU‑supported timing. That explains VAG advice on some models versus mechanical timing on this 1.9 TD. [Elektroda, arekkwiatek2, post #19826119]
I replaced glow plugs and filters; what should I check next?
With new glow plugs and filters fitted, proceed to check the injection setting. Verifying the injection angle and dosage is the logical next step. [Elektroda, serwispcv24, post #19826890]
