MAP Sensor Voltage Readings vs Pressure for Citroen C3 1.6 HDI 90HP 2008 No FAP
1864mponepound 660 2
  • Request for MAP sensor voltage-versus-pressure readings
    #1 21620697
    1864mponepound
    Level 4  
    I was wondering if somebody had voltage measurements from idle upwards or
    voltage versus pressure for MAP sensor on 1.6 HDI?
    I do not have lexia.
    I have replaced MAF measured compression all good and done leak off test all good waste gate valve vacuum good and pulling in on start up. But white smoke.
    AI: What is the make, model, and year of your vehicle with the 1.6 HDI engine?
    citroen C3 1.6 HDI 90HP no fap 2008
    AI: Do you have any actual voltage readings from your MAP sensor at idle or under different conditions that you could share?
    no
  • #2 21620864
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    Diagram of ECU connectors A, B, and C pins, turbo pressure sensor test table .
  • #3 21621146
    1864mponepound
    Level 4  
    >>21620864
    Thank you, I will measure.
