HP 2710 printer - How to fix an e0 error related to ink?
Vista2 28188 3
  • #1 19924510
    Vista2
    Rate: 36
    Hello, today I wanted to print something and I got an e0 error. Is there anything I can do to fix it?
  • #2 19924636
    krakarak
    Help: 681
    Rate: 1842
    If E0 is an ink error you should remove the inks and wash the cartridge and carriage contacts with isopropanol.
    If E0 is a paper related error then check the sensor flags and the paper path.
    E0 is variously described....
  • #3 19924848
    Vista2
    Rate: 36
    To me it seems to be a problem with the black ink because the Black Ink icon is flashing and after removing the Black Cartridge, the error is not there.
    Video below
    • P1040136.MP4 (25.64 MB) You must be logged in to download this attachment.
  • #4 20062410
    lolus098
    Rate: 19
    Hi, I have an identical problem with my 2710 printer, have you been able to solve this fault? I wiped the cartridge and the ribbon in the printer with isopropanol, unfortunately this only worked for 2 printouts.
