HP LaserJet Pro MFP M125a: Fixing E0 Error, Paper Jam Issue, and Troubleshooting Tips
JanuaryMM 14514 2
  • #1 16753728
    JanuaryMM
    Good evening,
    I have the following problem with the HP LaserJet Pro MFP M125a printer - every time I try to print, a page jam and the message E0 is displayed on the display (indicating that the device has jammed paper). How can the fault be fixed?
    copyman
    Photocopiers specialist
    Help: 1107
    Rate: 836
    For my untrained eye, you have a problem with the lack of a drum drive. The sheet of paper is now being transferred and it should be moved further by the rotating drum. Start by replacing and checking the toner.
    C.
  • #3 16753869
    JanuaryMM
    Thank you for your answer. Then I will buy a new toner tomorrow and let me know if the problem is gone.
    Edition (13/10/2017): It helped! Thank you for your help!
