Philips 26pf5321/12 TV - Issues with Random Freezing, Volume and Channel Switching
over5 1527 5
  • Fault traced to side control button PCB
    #1 19937210
    over5
    do anybody know where can be the problem? TV Philips 26pf5321/12 randomly freezing, volume and channel switching. When I disconnect PCB control buttons (manually buttons on side of TV) TV works normally with remote controller. I tried eeprom dump from uloz.to but this solution not working.
    Thank you.
    https://uloz.to/file/xb1PnWhQ/repair-26pf5321-32pf5331-with-eeprom-dump-zip#!ZGV3MQR2AmyuBGAzLJSvBGVmZzLjAySbI25DA3ujrRElYJR1AD==
  • #2 19948871
    the_thug
    Hello, there are 2 options:
    1. some buttons on the side panel have defects (increased conductivity) - you have to replace them all.
    2. resistors on the side panel or mainboard (depends on the model) they can have changed values.
  • #3 19949480
    maksar
    Help: 177
    Rate: 1030
    over5 wrote:
    does anyone know where the problem may be?
    In the buttons.
  • #4 19961806
    dzagorski4
    Rate: 32
    Try disconnecting the local keyboard, turn on the TV and check ..
  • #5 19965230
    bajdu
    Help: 193
    Rate: 327
    "Disconnect the local keyboard, turn on the TV and check .." After all, he disconnected the local keyboard and it's fine, so replace the switches on the keyboard.
  • #6 19984232
    over5
    Thank you,
    I replaced all 6 buttons on the board and it works perfectly.
    Thank you.
