[Solved] Win 10 Issue: Unable to Access PIN Settings or Change Computer Password
seboxoxoo 31260 2
  • PIN reset blocked after canceling setup
    #1 20008047
    seboxoxoo
    Rate: 46
    Hello and welcome,
    There was a problem with win 10 today
    I wanted to remove the PIN code that I had set. I went into the settings, but in total stupidity I entered the new pin settings but canceled this option.
    After restarting the computer, the following message appeared:
    "Some event has occurred and your PIN is not available, click to reconfigure your PIN"
    So I click set PIN code but it does nothing.
    I tried to log in with a password but I don't know my computer password. I only know the password and login to the Microsoft website where my computer is connected, but I do not see the option to change the pin or password on the computer there.
    What to do?
    Thanks for your reply in advance and best regards.
  • #3 20009556
    seboxoxoo
    Rate: 46
    Topic solved
