Windows 10 Black Login Screen After Reset: White-to-Black Screen Transition & PIN Issue
MRDI 6027 10
Why does Windows 10 show a black screen at the login/PIN screen after reset, while Safe Mode still displays normally?
This usually points to the graphics subsystem: a bad GPU or a problem that appears only when the normal video driver loads, because Safe Mode uses only the basic driver [#16519851] Test it by removing the PCI/AGP card and using integrated graphics if the board has it, or by trying another graphics card [#16519887] In this thread, swapping to another AMD card and reinstalling the drivers made the system work again for a while, which also supports a driver/GPU-related cause [#16525943] Later testing showed the black screen could return even on a fresh Windows 10 install, so the issue was not just the installation itself [#16525943] The follow-up research also found that this black-login-screen problem is common on some AMD/Windows 10 combinations, and in some cases it is linked to faulty hardware; there is no single official fix [#16525943]
  • #1 16519749
    MRDI
    Hi.
    This time I need help. Namely, when using the computer (I was browsing the net) the screen suddenly turned white. Since I waited a bit, nothing has changed. Ok, went the reset. The start screen, system loading normally appears, and then ... Nothing. Emptiness, black in the place where I should put the pin. The monitor detects the source (I changed from DVI to dsub), the screen is black. I tried self-repair, nothing. I start the safe mode, normally I turn on the screen with logging in to the computer, which was not visible in normal mode. That there is a problem here. I don't remember the account password. That's all from logging in. Changing your Microsoft account password did nothing. The system was also restored, because it turns out that I didn't have backups. Enabling the ASRock setup settings works, the monitor displays normally until you enter the PIN. I know that a fresh installation can be a solution, but someone has an idea what could happen? Specification: ASRock P67 pro3, i5 2500k, hd7850, 8gb ram, win 10.
    Heniek56
    Help: 6
    Rate: 18
    You definitely have copies on the disk, try to restore in safe mode.
  • #3 16519807
    MRDI
    Thank you for your response. The problem is, there is a problem here. In order to start the emergency mode I have to log in to the account assigned to the system. And I can't remember my password. I changed them on another computer, but it doesn't work, the password is still incorrect.
    310artur
    Help: 980
    Rate: 670
    90% damaged graphics card - works in safe mode because there is no driver in normal mode you have a black screen when the driver is loading.
    As usual, I predict because I repair an unknown PC to anyone ...
  • #5 16519856
    MRDI
    I have similar concerns. Where I live, I have nobody to borrow a card to check it out. Tomorrow I'm taking my computer home and I will check it. Thanks for "shooting".
  • #6 16519887
    310artur
    Help: 980
    Rate: 670
    If the equipment has an integrated graphics chip, remove the PCI / AGP chip and connect the monitor to the integrated one. Such a simple test quickly.
  • #7 16519910
    MRDI
    Specification I gave earlier in the first post. It is not possible for me.
    Added after 13 [hours] 4 [minutes]:
    I sit at work and wonder. I have not tried to put the system down again. Do you think these may be drivers, not a hardware problem?
  • #8 16521647
    310artur
    Help: 980
    Rate: 670
    In safe mode the drivers do not work. Only the simplest system.
    Of course you can try. But I think the chances are small.
  • #9 16521848
    MRDI
    That is why it puzzled me. If the login screen is displayed in safe mode and not in normal mode, it may be the fault of the drivers. I can't check it now. If I know something, I will let you know and we will close the topic.
    EDIT
    Okay, I'm stupid. I connected another graphics card at home, also amd. It works. Wyinstalowalem So I uninstalled the drivers, reinstalled my card, fired the computer. Happy I came back to myself, plug in the computer, turn on ... It doesn't work. I thought for a moment and came to the conclusion that I connected the monitor at home to HDMI. At home under DVI, because the monitor has no hdmi output. So the DVI socket must have fallen. I quickly brought the TV, plug it in and it doesn't work. What is? At home, it worked normally.
    Added after 1 [hours] 6 [minutes]:
    PS. Tip. Brother has an old monitor in 4: 3 format. I have 16: 9 in full HD. Maybe the drivers do not want to load the resolution?
    I merged. RADU23
  • #10 16524691
    310artur
    Help: 980
    Rate: 670
    Maybe the card can't handle the resolution? Did you install her drivers at her brother's and did a load test even in OCCT?
    Or maybe your power supply has died. You also didn't even say what you got there. And the card draws some power.
    DVI and HDMI are basically the same signal and the socket itself is rather difficult to damage.
  • #11 16525943
    MRDI
    I'm in the middle of a fight. I have been struggling for a long time to get around the win10 password, but finally I work around to clean my system disk and install fresh win10. To do this, I installed win7 on the second disk. Everything works normally on a fresh system, full HD resolution.
    Yesterday I also noticed that when win10 turns on and, instead of iast login screens is a black screen, USB ports also turn off. The keyboard and mouse are not lit.
    A power supply OCZ zt 650w.
    UPDATE
    Unfortunately you probably were right, it's something with the equipment. Win 10 installed, we turn on about 3 times. I installed a browser to download the drivers to the motherboard (I didn't even install the card controls) and suddenly the screen went black. And everything returned to the original problem. The system is loading and instead of "welcome" I have disabled USB ports and a black gray screen. I noticed that at first it becomes so dark gray, then it quickly flashes black as if it turned on only, a monitor message is displayed that the source is DVI and then nothing. Tera, it's hard for me to tell if it's a card or a power supply.
    Oh, I've got two fresh systems on my computer right now. Under win7 the problem has not yet appeared. I will see after some time.
    UPDATE
    Well, I reached for English-language resources and it turns out that the problem of a black image in the login screen is not uncommon. A lot of people using AMD equipment struggle with it. Different forums present different solutions, but for most, including me, they are ineffective. There are people who (because they can't afford a new card) fight the problem for weeks, months. The problem concerns the drivers and system version. Suddenly, different models on different versions of wines 10 evoke a black screen. AMD on official forums and support is silent on this topic. Employees contribute on other topics helping users, with the problem of a black screen are silent. There is no real solution to this.
    One person (unrelated to AMD) gathered all the victims (about a hundred people) to report and analyzed their problems. Unfortunately, it turned out that one of the reasons (in some cases, e.g. black screen during driver installation) MAY be a card malfunction.
    Overall: There are some tips on how to solve the black screen problem. However, only in some cases they can help. There is no official solution or any words from AMD.
The discussion revolves around a Windows 10 user experiencing a black login screen after a system reset, following a transition from a white screen. The user is unable to log in due to a forgotten password and suspects a graphics card issue, as the screen works in safe mode but not in normal mode. Various suggestions are made, including checking integrated graphics, potential driver issues, and hardware problems. The user eventually connects a different graphics card, which resolves the issue temporarily, but the problem recurs after installing drivers. The user also notes that USB ports become unresponsive during the black screen issue, indicating possible hardware failure. The power supply is mentioned as a potential culprit.
