Resetting PC Settings Failure: How to Navigate BIOS for Windows 10?
Kelio95 85407 6
  • Seeking Windows 10 reset recovery options via BIOS or forced shutdown menu
    #1 16034843
    Kelio95
    Rate: 16
    Hello. I decided to refresh my PC a bit, so I wanted to reset its settings. I do it according to the instructions and suddenly, when I load the blue background bar, I get this message: "There was a problem resetting the computer settings to its initial state. No changes were made." From what I remember, I had a similar problem and found a guide somewhere on how to get around it, but it was quite a long time ago. And here's a question for you how to do it? From what I remember there was something through the BIOS. Or something in such a way that you turn off the computer several times with the Power button, until some modes pop up, and then do it.
    Ps = Windows 10.
  • #2 16034856
    bakubaku69
    Help: 18
    Rate: 53
    You can always do a clean install with the windows download tool.
  • #3 16035128
    Kelio95
    Rate: 16
    Unfortunately. A window like this pops up.
    • Resetting PC Settings Failure: How to Navigate BIOS for Windows 10? Screen Shot 11-02-16 at 05.46 PM 001.PNG (395.64 KB) You must be logged in to download this attachment.
  • #5 16035504
    Kelio95
    Rate: 16
    There is the same problem in safe mode.
    310artur
    Help: 980
    Rate: 670
    Download win10 image from MS site. Burn to DVD. Boot PC from DVD - clean install.
    https://www.microsoft.com/pl-pl/software-download/windows10
    In advance of the question, please omit the product key during installation. After installation, the system activates itself.
  • #7 16050417
    Kelio95
    Rate: 16
    I did as you said. So far everything is flashing :) . Thanks for the help. Subject to be closed.
The discussion revolves around a user experiencing issues while attempting to reset their Windows 10 PC settings, encountering an error message stating, "There was a problem resetting the computer settings to its initial state." Various solutions were proposed, including performing a clean installation using the Windows download tool and booting from a DVD with the Windows 10 image. The user also attempted to reset in Safe Mode but faced the same issue. Ultimately, the user successfully followed the advice to download the Windows 10 image, burn it to a DVD, and perform a clean install, resolving the problem.
