[Solved] Telefunken TE32269s27yxd - Solo led stand-by sempre lampeggiante. Testato barre
marcellootella 2043 4
  • #1 20055580
    marcellootella
    Level 4  
    Hello, I checked the fast diodes on the wings board which are ok, 12V present. Led bars tested with external power supply, are OK. Is it possible to have the FW? Telefunken TE32269s27yxd - Solo led stand-by sempre lampeggiante. Testato barre
  • #2 20055696
    billobirillo
    Help: 338
    Rate: 797
    mainboard is a 17MB140, but panel code?
    this model may mount 5/6 different panel type
    please post a photo of the sticker with the panel code (with all the vestel codes)
  • #3 20055743
    marcellootella
    Level 4  
    Grazie e scusate, ecco: Telefunken TE32269s27yxd - Solo led stand-by sempre lampeggiante. Testato barre
  • #4 20055827
    billobirillo
    Help: 338
    Rate: 797
    you have a private message: check it!
  • #5 20074828
    marcellootella
    Level 4  
    Ricevuto il FW, seguito istruzioni sul caricamento da USB a TV. Riacceso e tutto OK. Ringrazio in prima linea billobirillo.
