[Solved] Will it be possible to connect my own router at the optical fiber from Orange? H
Daniels111 17292 18
Can I use my own router with Orange fiber, and is my old WRT54GL still usable as an access point?
Yes, but only if Orange installs a separate ONT; then you can connect your own router to the ONT, typically using VLAN ID 35 on the WAN and PPPoE on that logical interface [#20092304][#20092334][#20092339] You should request the ONT before installation and remind the technician, because Orange now usually supplies the FB6 and bridge mode is currently unavailable, so without an external ONT you may be stuck with their router [#20092304][#20092760][#20092945] The WRT54GL is too old for modern fiber and, as an access point, will likely only give around 10 Mbps in an apartment [#20092192][#20092384] If you want a simple router with good Wi‑Fi and configuration options, FritzBox 4040 was recommended; MikroTik gives more control but is harder to use and its Wi‑Fi is weaker [#20092324][#20092304]
  • #1 20092124
    Daniels111
    Rate: 8
    Good morning.
    They will connect me with optical fiber from Orange. How do you rate the routers that provide the service?
    I like to configure the network myself, access, etc.
    I'm afraid that in these routers there will not be too many possibilities.
    Can I connect my own router? I have some immortal WRT54GL from Tomato, can you make some use of them with optical fiber? If not, what to buy with similar capabilities?
    I couldn't find a section on fiber optics, so I created it here. Please move to the correct department.
    Bródka
    Help: 900
    Rate: 723
    Daniels111 wrote:
    I have some immortal WRT54GL with Tomato,
    They are grandparents, they are not suitable for the modern Internet
    Mikrotik?
    There is RouterOS
    Well, take the ONT itself, but do you have other services with this light, such as TV?
  • #3 20092265
    Daniels111
    Rate: 8
    I don't need any other services like phone or TV. I'm only interested in the internet.
    So ONT + some MikroTik router?
  • Requesting an ONT during Orange fiber installation
    #4 20092304
    IC_Current
    Help: 1499
    Rate: 2523
    It's not that hop siup. You have to take the router from Orange and now you have to pay additional rent for it. However, you can ask BEFORE installing the installation and devices - preferably during a conversation with a consultant and then NECESSARY with a technician when setting the installation date that you need an ONT terminal in addition to the router. As a rule, the terminal does not give - you need to justify. The best justification is that it is not possible to put fiber in the place where the router is mounted, but the UTP cables are already laid and you can mount the fiber and ONT terminal in the patch cabinet and connect the router in the living room through the cable. Once the technician arrives and has an ONT terminal in the trunk, he will connect it to you in practice whenever you want.
    Then you wait about a week for data to PPPoE (FB must be connected at that time, because Orange does link stability tests). Once you have the PPPoE password, you assemble your router.
    As for the advantages of FB6 - basic configuration options, more than enough for 99% of home users. Very good radio and radio performance.
    As for MT - huge configuration possibilities if someone knows how to do it. Poor radio, bandwidth much lower than on FB.
    Of course, do not expect that one MT or FB will cover the entire large apartment or house (unless you pay for 600Mbps and 6Mbps will be enough for you at home).
    Either way, it is worth trying to get an ONT terminal during assembly, because then it is impossible to receive it. Even if you only use FB, you will hide the ONT in the wardrobe for the future.
    FritzBox 4040 recommended over Mikrotik for home use
    #5 20092324
    VaM VampirE
    Help: 43
    Rate: 90
    ONT and also FritzBox 4040.
    Wi-Fi works great, the router has a decent set of options, you can put a media server and us on it.
    It's easy to use, I haven't heard about holes in the system, updates come out from time to time and they can be installed automatically.
    When I was still working as an IT outsourcing, I put a few companies on it, they are still operating today.
    In addition, it has a built-in IPSec VPN, so you can remotely connect to your home, and Fritzbox provides free DDNS for its routers.
    It looks terrible, but other than that 10/10, the 4020 I still use in one place and it's like a tank.
    Mikrotik for a layman is evil incarnate, not to mention that sensibly working WiFi in mikrotik is a bit of a fairy tale.
    Not that I have anything against MT, because I use dozens of these routers for many things, but it's like promising someone who has been sitting on windows all his life that he will be better on Linux.
  • PPPoE needs a fast single core
    #6 20092332
    IC_Current
    Help: 1499
    Rate: 2523
    As a supplement - MT cannot perform PPPoE on multiple cores. He only uses one. Therefore, for example, for a 600Mbps link, you need to buy a specific and expensive model in which one efficient core will be used (to process this traffic) and the remaining 75% of the device is idle.
    What I would personally recommend if FB really limited me - just like FritzBox or Draytek's friend before. They are plug-and-forget devices and have good support for several years after purchase.
    VaM VampirE
    Help: 43
    Rate: 90
    Only in memory I do not remember how to set VLAN ID 35 on the WAN on FritzBox, I do not know if it was necessary or not.
    I have no way to check at the moment.
  • #8 20092339
    IC_Current
    Help: 1499
    Rate: 2523
    VaM VampirE wrote:
    Only in memory I don't remember how to set VLAN ID 35 on the WAN on FritzBox, I don't know if it was necessary or not.
    It is necessary. In addition, the PPP session must be established on this logical interface and not directly on the physical interface by default.
  • Recommend asking Orange for an ONT and using FritzBox 4040
    #9 20092369
    Daniels111
    Rate: 8
    Seriously? It does not make sense.
    IC_Current wrote:
    However, you can ask BEFORE installing installations and devices - preferably during a conversation with a consultant and then NECESSARY with a technician when setting the installation date that you need an ONT terminal in addition to the router.
    OK, valuable advice, thanks.
    I plan on 300 Mbs, it's more than enough for me anyway, and the apartment is small.
    Alternatively, does it make sense to use my WRT54GL as access points or because they are already "grandparents" it makes no sense? 54 Mbs for phone and laptop should be enough (currently I have 10 Mbs and I live :) )
    VaM VampirE wrote:
    FritzBox 4040.
    OK, currently I don't need a media server or NAS, but in the future I don't rule it out, so it may be a good option.
    In general, the whole story came from the fact that I currently have Neostrada but I suffer from a weak (not to say miserable) upload. When I have to upload something to FTP or upload a video to YouTube, it takes forever. Therefore, I thought about this optical fiber since it is already brought to the estate.
    I don't need any grand bells and multimedia wonders of technology :) Just a stable connection with a good upload + a router with the ability to secure the network and control what is happening in it.
    That is, hiding the SSID, filtering devices by MAC, disabling DHCP, the ability to reduce the power of the antennas adequately to the needs, the ability to change Wi-Fi channels, some logs to be pulled out and stuff. Surely that's the standard today, or maybe not? I'm not an expert, I know something, but recently I've been developing in other directions than networks.
    WRT54GL is too old for useful access point use
    #10 20092384
    IC_Current
    Help: 1499
    Rate: 2523
    Daniels111 wrote:
    Alternatively, does it make sense to use my WRT54GL as access points or because they are already "grandparents" it makes no sense? 54 Mbs for phone and laptop should be enough (currently I have 10 Mbs and I live)
    On these WRT in an apartment in a block it will probably be around 10Mbps
    IC_Current wrote:
    More money makes sense for the operator, and thanks to this procedure, he can boast about a 5 zloty lower subscription in advertisements and on the website.
    This FB is enough
    This is more of a security hole than an improvement. With such a hidden SSID, the client is constantly sending requests to join, wherever he is (even outside the home). All you need to do is set up a fake AP and you can sniff traffic from the client in the background.
    This is what FB can do
    It does not make sense. Currently, the power of the device regulates itself according to needs. There is always too little of it in the 5GHz band rather than too much.
    On FB, you can automatically or manually change.
  • #11 20092396
    Daniels111
    Rate: 8
    In fact, if it's true that I have to get a router just to make someone else's extra bucks, then that has already put me off the whole investment :) I'm not giving up copper and a landline phone to replace it with a router :)
    KOCUREK1970
    Help: 3863
    Rate: 5493
    Daniels111 wrote:
    In fact, if it's true that I have to take a router just to make someone else's money, then it already put me off the whole investment
    They have a hardware matrix :D
    Either ONT and FB3, or you'll get FB6 from the march and you'll just end up in a black......chamber :D
  • #13 20092572
    Daniels111
    Rate: 8
    KOCUREK1970 wrote:
    you're about to land in a black......chamber
    What is wrong with him?
    Bridge mode on FB6 adds power and firmware risk
    #14 20092600
    KOCUREK1970
    Help: 3863
    Rate: 5493
    If you get a separate ONT and FB3, then as they write, FB3 to the cabinet and you try to run the service on your router with the ONT connected to it.
    And if you get FB6, it is a connection of 2 devices into one housing and here it is a problem to "separate" it, because physically the ONT is built into the router, and the router is also in some sense an ONT.
    Variant 1 gives the possibility of full configuration - because the ONT is only a converter from light to twisted pair.
    Variant 2, here you have to switch the FB6 klata to bridge/bridge mode if op provides such a mode at all, and only then his router, and so op can release new firmware and sru, you have router mode again, not bridge mode, and again switching, adjusting the settings.
    ONT, when it gets a new soft, nothing changes, it's still just a converter - it will restart and the net will come back.
    If the softa gets FB6 switched to bridge/bridge mode, it may either not accept the softa (I have already seen such cases :D ), or you FB6 will automatically switch back to the router and you will investigate why everything has died (when you are at home, it's half the trouble, but when you are in the field and want to connect to your home, you lie down).
    And, not without significance, power consumption:
    - ONT with 5W, FB3 with 15W - here you will throw FB3, give your router to FritzBox 4040 and it consumes around 6W, the total consumption is around 15W / h
    - FB6 with 20W - here you will switch FB6 to bridge / bridge mode and it still consumes 20W, give your router even this Fritz 4040 again and you have a total of almost 30W / h
    There seems to be no difference, but if the equipment runs 24/7/366 - well, the difference in the electricity bill will be visible.
    FB6 cannot currently be put into bridge mode
    #15 20092760
    IC_Current
    Help: 1499
    Rate: 2523
    It's not like that anymore. You will always get FB6. FB3 no longer gives by default.
    The FB6 has a built-in ONT terminal and a WAN port. You can have both configurations - the menu only changes whether the device is to use the integrated ONT or to use the attached external ONT.
    KOCUREK1970 wrote:
    Variant 2, here you have to switch the FB6 klata to the bridge/bridge mode, if such a mode is available at all, and then your router,
    Unable to put FB6 into bridge mode currently. There must be an external ONT.
    KOCUREK1970
    Help: 3863
    Rate: 5493
    @IC_Current
    As for what equipment they currently provide, I have also come across a situation several times that the client asked for a separate ONT and FB3 and received FB6, but I assumed that it was some local operation of the operator, as you can see it is not.
    As for the bridge / bridge issue - here I am very surprised.
    FB6 only; coordinate with technicians in advance
    #17 20092945
    IC_Current
    Help: 1499
    Rate: 2523
    KOCUREK1970 wrote:
    the client asked for a separate ONT and FB3 and got FB6
    FB3 won't get it anymore. FB6 only. You can ask on the hotline, but they have it d.. mostly. It seems to indicate, but they say that the decisions are made by the technician on the spot. Therefore, it is always necessary to agree with the technicians before their arrival. Once when the date is set and the second time you have to remind them when they confirm the date in the morning before arrival so that they don't forget to take the terminal with them.
  • #18 20092994
    Daniels111
    Rate: 8
    That is, a skin for a layette. It's hard, maybe I'll find some other solution.
    Anyway, thanks for the discussion and it's good that I asked here, because I might be surprised :)
  • #19 20103544
    Daniels111
    Rate: 8
    I resigned
The discussion revolves around the possibility of connecting a personal router to an optical fiber service provided by Orange. The user expresses concerns about the limitations of the routers supplied by Orange and seeks advice on using their existing WRT54GL router with Tomato firmware. Responses highlight that while it is possible to connect a personal router, it often requires obtaining an ONT (Optical Network Terminal) separately. Recommendations include using MikroTik routers for advanced configurations or FritzBox models for user-friendly setups. The conversation also touches on the limitations of the FritzBox 6, which integrates the ONT and router functions, complicating the use of external routers. Users emphasize the importance of discussing equipment options with technicians during installation to ensure compatibility and desired configurations.
TL;DR: Yesyou can use your own router with Orange fiber via ONT + PPPoE (VLAN 35). More than enough for 99% of home users. Expect PPPoE credentials after about a week; ask technicians for an ONT at install. [Elektroda, IC_Current, post #20092304]
Why it matters: This FAQ helps Orange FTTH users who want full control of their home network while avoiding setup pitfalls and rental gotchas.
Can I connect my own router to Orange fiber?
Yes. Accept Oranges router during installation, then request an additional ONT from the technician. Provide justification, such as fiber termination in a patch cabinet with existing Ethernet runs. Keep the FunBox online for about a week while Orange runs stability tests. When you receive PPPoE credentials, connect your router to the ONT and configure a PPPoE WAN. Many users keep the ONT tucked away for future flexibility. Either way, it is worth trying to get an ONT terminal during assembly. [Elektroda, IC_Current, post #20092304]
Do I need VLAN ID 35 and PPPoE on Orange fiber?
Yes. Orange requires PPPoE over a tagged WAN using VLAN ID 35. Establish the PPPoE session on the logical VLAN interface, not the physical port. It is necessary. Configure this on FritzBox or any thirdparty router you plan to use. [Elektroda, IC_Current, post #20092339]
Can I put FunBox 6 into bridge mode?
No. FunBox 6 does not offer bridge mode at this time. It has an integrated ONT and a separate WAN port. You can switch its WAN source between the builtin ONT and an external ONT in the menu. To use your own router as the gateway, request an external ONT during installation. [Elektroda, IC_Current, post #20092760]
How do I request an ONT from the Orange technician?
Ask before installation during the consultant call and again when the technician schedules the visit. Explain you need the fiber terminated in a patch cabinet, with Ethernet already pulled to the router location. Technicians often carry ONTs and can install one if notified. This helps you later attach your own router to the ONT using PPPoE. [Elektroda, IC_Current, post #20092304]
What router is a userfriendly alternative to Oranges FunBox?
Consider a FritzBox 4040. It delivers solid WiFi, builtin IPSec VPN, and free DDNS. Firmware updates arrive regularly and can install automatically. You can host simple media or NAS functions, and management remains straightforward. The model looks plain, but it is durable and reliable. 10/10. Pair it behind an ONT to replace routing features from the FunBox. [Elektroda, VaM VampirE, post #20092324]
How does MikroTik compare to FunBox 6 for WiFi and throughput?
MikroTik offers huge configuration scope with RouterOS, but its WiFi radios underperform versus FunBox 6. Expect lower wireless throughput than FB6 using similar conditions. FunBox 6 provides strong radio performance with enough features for most homes. As for MT  huge configuration possibilities... Poor radio, bandwidth much lower than on FB. Choose MikroTik for advanced routing, not for WiFi. [Elektroda, IC_Current, post #20092304]
Can I still use my old WRT54GL as a WiFi access point?
It will work, but expect very low speeds in apartment environments. On WRT54GLclass gear, throughput can be around 10 Mbps in a block. That bottlenecks a 300 Mbps fiber plan. Use it only for basic IoT or as a temporary stopgap. Replacing it with a modern AP brings massive gains. [Elektroda, IC_Current, post #20092384]
Is FunBox 6s WiFi and feature set good enough for a small flat?
Yes. FunBox 6 offers basic settings, strong WiFi, and performance that fits most homes. The radio section is very good, and the interface covers standard needs like channel selection and security. More than enough for 99% of home users. For larger spaces, add extra access points. [Elektroda, IC_Current, post #20092304]
Why can MikroTik struggle to hit 600 Mbps on Orange PPPoE?
PPPoE processing on MikroTik uses only one CPU core. Hitting 600 Mbps requires a model with a fast single core. The remaining cores sit largely idle for PPPoE traffic. Plan capacity accordingly when ordering highertier fiber packages. MT cannot perform PPPoE on multiple cores. [Elektroda, IC_Current, post #20092332]
How do I set VLAN 35 for Orange on a FritzBox?
Orange requires PPPoE on a VLANtagged WAN (ID 35). Create the VLAN interface first, then bind PPPoE to it.
  1. Add VLAN ID 35 on the WAN and create a logical interface.
  2. Configure PPPoE on that VLAN interface, not on the physical WAN.
  3. Enter your PPPoE credentials and save; verify link status.
It is necessary. [Elektroda, IC_Current, post #20092339]
What if my router cant tag VLAN 35 on the WAN?
It wont connect to Orange fiber. You need a router that supports WAN VLAN tagging and PPPoE on the VLAN interface. If your device lacks this, keep the FunBox for routing or replace the router. This requirement applies to FritzBox and similar gear. It is necessary. [Elektroda, IC_Current, post #20092339]
Will one router cover my whole home?
Do not expect one FunBox or MikroTik to cover a large apartment or house. Add more access points or mesh for reliable coverage. Wireless range depends on walls, interference, and client devices. Planning for multiple APs yields better consistency than relying on one box. [Elektroda, IC_Current, post #20092304]
Do hidden SSIDs or MAC filtering improve security?
Hiding the SSID reduces security. Clients probe constantly and can be tricked by fake access points. This is more of a security hole than an improvement. FunBox supports MAC filtering and DHCP controls, but focus on WPA2/WPA3, strong passwords, and updates. Use channel selection and power controls wisely. [Elektroda, IC_Current, post #20092384]
Whats the power draw difference between ONT + my router and running FB6 with another router?
Approximate figures: ONT ~5 W, FunBox 3 ~15 W, FunBox 6 ~20 W, FritzBox 4040 ~6 W. ONT + 4040 totals about 15 W. FB6 plus another router can approach 30 W. Over 24/7 operation, that difference appears on your electricity bill. Simpler stacks save energy and reduce failure points. [Elektroda, KOCUREK1970, post #20092600]
Do I have to pay monthly for Oranges router?
Yes. Orange requires taking their router and charges additional rental. You can still request an ONT at install to later use your own router. Plan for the rental in your cost comparison, and push for an ONT during scheduling. [Elektroda, IC_Current, post #20092304]
Can I still get a FunBox 3 instead of FunBox 6?
No. Orange now supplies FunBox 6 by default. Hotline agents often defer to the technicians decision on equipment. If you want an ONT, arrange it directly with the technicians before they arrive and remind them on install day. [Elektroda, IC_Current, post #20092945]
