Reducing Current from Car Battery to LED Lights: Using 2 Ohm Resistor for 6 Amps
zoah666 1239 1
  • A resistor will not limit controller current safely
    #1 20201031
    zoah666
    Hi there! I am currently putting in some tape LED lights in the back of my truck, and I have gotten a few wires from my car battery to where my camper shell brake lights are. There is a 10 amp fuse so that I don't screw anything, but when I connected the wires to the lights controller, it was to much and broke the controller! I have a new controller, but to ensure I do not blow it up, should I put a ~2 ohm resistor in so the amperage coming out to the controller is roughly 6 amps, which is it's max current? 12v / 2ohm = 6a? If so, what resistor should I get?
  • Bypass resistor and switch LEDs with relay or MOSFET
    #2 20205725
    Wikita
    Help: 11
    Rate: 17
    Could you please tell me the power wattage of the LED lamps?
    If you want to calculate correct current consumption, you should take into account the voltage drop on LEDs.
    If LED tape is dedicated for 12 V systems I think you should connect it directly to the battery without the resistor - if we limit current by resistor, the light intensity will decrease.
    Next point is power dissipation - why do you want to lose the precious power on heating the resistor if you can spend it all on the LEDs (more light).
    Maybe the problem is in the light controller - it does not have enough current efficiency? Instead of powering the LEDs, you should power from the driver a relay or semiconductor electronic switch, and then the LED strip line.
