how to understand Panic Full log in iPhone and iPad
bert_studionapraw 49398 2
  • Hello, hello.
    Christmas and New Year: How to understand panic full log in iPhone and iPad
    There was a bit about this on the forum some time ago, but there are still a lot of misunderstandings on this topic. So I am dispelling misunderstandings and myths (about disappearing elements), with hints like "tell me how to replace this thermalmonitord" - by the way: Thermal Monitor Daemon is a logical function written in SWIFT.
    As usual, graphic version on mine studionapraw.pl blog who I also invite in every other matter.
    iPhone Kernel Panic Full Log, as this is its full name (and mandatory for iPad or Mac), is a record of the kernel state and a crash log in the system of your device. However, this is not a complete repository of the problem. These are constantly being created by code engineers in Cupertino and, more importantly, are constantly changing, depending on the needs of the hardware resources being tested.
    Panic full or crash log is a documentation of events in Unix systems (your IOS is a Unix based OS after all)
    By analogy with my experiences with Unix machines, the problem with the readability of Panic Full Log was no longer terrifying. Everything started to fall into place only when I associated common features, previously invisible due to the encoding of important information. For now, I think I'm compatible with version 16 and I think I know where to look when version 17 comes out.
    Panic Full Log (or crash.log - depending on the device) appears whenever the system kernel has a hardware problem with a driver function, data structure, or incoming sensor pipeline. In many cases you can do without it, but for some time (iOS 14.5) it has been a sufficient reason to start the restart procedure in several cases (... I think it is more economic than technological).
    The location has not changed since many releases, go to settings --->> privacy and security -->> analytics and enhancements -->> analytics data. The data catalog will contain all analytical reports, feedback measurements and other files sorted alphabetically. Find the letter "P" - Panic.Log or Panic.Full ending with numbers (date, time).
    Reading the log is easy, although individual sections may change their location depending on the version. There should be no difficulty in locating individual places. If you have any doubts, write e-mail and I will try to help.
    It starts with locating the report in time. Then present the boundary conditions of the device and indicate the location of the problem. The important thing starts with the "panicString" section. There you will find a quite clear description of the problem with its RAM signature. Below, there is only coded information from the design debugger, memory dump and other details important for system engineers. In the file below, two examples: from the watch (watchOS is also pro'unixOS) on the left and from the phone on the right. The marked sections will clear your doubts.
    As a side note, I would like to point out two things - the sections are divided according to "bit information" (for Swift developers) and the caveat that the provisions of such a report should (in this section) be treated as a guide, nothing more. The structure of the report and its code changes with the release of the system version.
    TYPES OF FULL LOG PANICS AND THEIR DECORDED INDICATIONS
    ANS2 Recoverable Panic Full log
    Apple NAND Storage v.2 – NORD or NAND data storage controller. The log may indicate damage to the system itself. Example of a short circuit or harmonic distortion of the control/logic signal.
    AOP NMI POWER (Non-Maskable Interrupt)
    A type of IRQ with emergency powers granted. Has priority in memory shares and the right to interrupt lower priority transmissions. Everything indicates that it is related to the AP.SEP "Secure Enclave" mechanism, a set of front Face.ID sensors and a front camera.
    AOP Panic Full log
    AOP is a whole subset of function types. Information about what exactly AOP refers to is not widely known. However, information has leaked out that an entire segment (APsoc) of the processor is dedicated to supervising AOP functions.
    AppleSoc: Hot Hot Hot
    alarm type message. Indicates a critical temperature reading from the internal self-monitoring mechanism of the main processor and RAM. By the time you see it, it's probably too late.
    i2c (i2c0-5) Panic Full log
    master-slaves communication protocol. There will be more about this in a while, in the theoretical section of the studionarpaw.pl blog, due to the large scope of the issue. For now, let it be enough that the MASTER device in this architecture is always the main processor and the receivers (SLAVE) are peripheral and sub-system controllers. If the instruction does not arrive or the signal checksum is missing, there must be something physically wrong "down the line".
    SEP.Rom Panic Full log
    The Secure Enclave Processor (AP.SEP) is a dedicated layer of the processor for storing ultra-secure data. Indicates damage in the transmission space or physical layer of "Secure" devices. The subsystem includes the main processor, Face.ID/Touch.ID band devices, NAND, Baseband, Stockholm and eeprom.
    SMC Assertion Failed
    SMC is a familiar device to all Mac and MacBook technicians. The SMC device is also present in the iPad and iPhone, but from the 11th model it was incorporated into the system PMU, and later moved to the CPU. This type of error usually has the string BSC FAILURE. On models 13 and later, the bug causes system restarts at an interval of 180 seconds (appears to be a new version of Watchdog). Always occurs with a sensor array parameter. (ONLY FOR models from 13)
    Watchdog Timeout Thermalmonitord Missing Sensor
    The Watchdog system process is programmed to examine external sensor data. The cycle is cyclical, as the name suggests, and has a value of 180 seconds. If the measurement interval is not interrupted by incoming data (confirmed), the system will start an emergency start, hoping that a restart of the system and the current activation of the sensor will solve the problem. To find the missing signal from the sensor, analyze the incoming data from Panic.Log. (Applies only to 7-12pro/Max models)
    PRSo – charging port voltage sensor (room=dock)
    Mic1 – sensor (unknown function) of the lower connecting strap (room=dock_flex)
    Mic2 – sensor (unknown function) of the upper connecting band (room=power_flex/strobe)
    TG0V – battery voltage sensor (room=battery)
    TG0B – battery temperature sensor (room=battery)
    TT0D-TT9D – display driver sensor (only available in tablets)
    Watchdog Timeout No Check In
    The Timeout process checks the overall functionality of the system. If the time between sub-checks exceeds the maximum, the device will reboot to try to fix it. Easy to spot if the physical location of the sensor is not listed in the Springboard, logd, wifid or Thermalmonitord instructions. I assume that in this case it is a software component. Particularly visible in the first releases of version 16.0. Since version 16.2 I have not noticed any case (findings?)
    Undefined Kernel Instruction (unidentified kernel function)
    Kernel is what the name suggests (the heart of the system). Unidentified instructions, functions and arrays are a constant part of the system engineer's fun. If you encounter this error, it is most likely related to the system itself or an incompatible application (which has happened before).
    Finally, a few words about robots (useful applications). There are several in use. In my opinion, the most popular one still shows the same group of errors (although maybe I don't have enough experience to judge it). There should always be a charging port and a power cable. In another popular device (3uT), only the number of logs is counted, but this may only be temporary. The information is also the same: "visit a repair shop".
    I hope I have shed some light on the problem. If it has a positive impact on the quality of the devices you (the reader) repair, leave a comment and brag about it. I will be very pleased that my work is needed.
    - Regards,
    bert_studionapraw
    Specialist - Apple
    bert_studionapraw wrote 871 posts with rating 266, helped 176 times. Live in city Warszawa. Been with us since 2021 year.
  • 3uTools crash logs indicate battery condition errors
    #2 20412706
    staś pytalski
    Help: 760
    Rate: 1436
    Thank you, my friend Bert, for an interesting article-guide. Today I wanted to check the condition of the battery with 3u tools. Interestingly, the program itself suggests that unexpected errors have occurred and indicates how many of these "crash" logs are available.
    I had a few of the same ones, I'm pasting a screenshot from the program of the mentioned error, because I can't see the list in your article, or I'm reading the log wrong. I'm curious what my error is related to.
    Thank you and best regards :)
    • CrashLog 2.txt (278.36 KB) You must be logged in to download this attachment.
  • Panic.string must be read from iPhone analytics data
    #3 20412736
    bert_studionapraw
    Specialist - Apple
    Help: 176
    Rate: 266
    Hello, hello.
    Unfortunately, this standard reader from 3uT is just a fitting for the version that will be released in a few months at the earliest (from December 2022, referring to my correspondence with Akacy - one of the 3uT programmers, whom I approached when this article was being written). All you can find out now is that the system registered Panic.log but does not provide a solution yet. I don't know the reasons. Similarly, although it will be a bit better with Panic.full - an application for WIN, the help is slightly better written, but (at least in my case) most error messages come down to "replace boot tape" or "...trigger tape". I haven't seen any others and I don't even think they exist (although sometimes I'm wrong).
    Also look at the dates, I can see in the picture that it's last year so probably related to an iTunes bug or previous fixes. For you, the one with the date of the last restart will be valid, the earlier ones may be outdated due to IOS and iTunes upgrades.
    In addition, the file (according to my instructions) should be read from the system: settings-->>privacy-->>analysis and enhancements-->> analysis data to extract reliable information from the "Panic.string" section. You can take a screenshot and show it here (or email me if you're concerned about showing the insides of your phone - in the future someone might actually find a mine of vital system information there), I'll try to help you read it.
    I guess that's it... greetings.
    PS, unfortunately the file you attached is encoded for me. I only see the code... :)
    " panic String " : " panic ( cpu 1 caller 0 xffffffff 0 1 e 1 5 5 d 9 4 ) : K erneldataabort . ( savedstate : 0 xfffffff 0 0 0 8 8 2 d 1 0 ) \ n \ tx 0 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 x 1 : 0 x 0 0 0 0 0 0 0 0 0 e 0 0 0 5 0 0 0 x 2 : 0 xfffffff 0 1 eaadae 8 x 3 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 \ n \ tx 4 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 x 5 : 0 xfffffff 0 0 1 8 5 ea 6 0 x 6 : 0 xfffffff 0 0 0 d 5 4 5 3 0 x 7 : 0 xfffffff 0 1 ef 5 a 7 a 4 \ n \ tx 8 : 0 xfffffff 0 1 de 8 fef 0 x 9 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 3 8 0 0 1 x 1 0 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 x 1 1 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 7 \ n \ tx 1 2 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 8 8 x 1 3 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 x 1 4 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 x 1 5 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 \ n \ tx 1 6 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 x 1 7 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 x 1 8 : 0 xfffffff 0 1 dfa 1 0 0 0 x 1 9 : 0 xffffffff 0 1 6 4 2 2 0 0 0 \ n \ tx 2 0 : 0 xffffffff 0 0 1 2 f 1 0 0 0 x 2 1 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 7 dcx 2 2 : 0 xfffffff 0 0 3 f 5 5 8 0 0 x 2 3 : 0 xfffffff 0 0 0 8 8 3 3 6 8 \ n \ tx 2 4 : 0 x 0 0 0 0 0 0 0 0 e 0 0 0 5 0 0 0 x 2 5 : 0 xfffffff 0 1 dc 4 2 3 0 dx 2 6 : 0 x 0 0 0 0 0 0 0 0 0 0 0 0 0 7 d 3 x 2 7 : 0 xfffffff 0 1 6 4 2 2 a 2 8 \ n \ t
