iPhone 5 Unexpected Shutdown: Calendar Access Causes Phone to Turn Off After 2-3 Minutes
131XIII 7692 10
Why does an iPhone 5 shut down after 2–3 minutes of use, but stay on while connected to a charger?
The most likely cause is a worn-out battery, and the first thing to try is replacing or testing it with a known-good one [#16414344][#16416143][#16811593][#16814654] If the phone does not shut off while plugged into a charger or computer, that further points to the battery rather than normal software behavior [#16416127][#16795846] Some replies also suggest the U2 charging/power IC as a possible fault if a good battery does not solve it [#16416730][#16806299] If battery replacement and basic checks do not help, the next step is motherboard diagnosis with proper tools [#16416649]
  • #1 16414327
    131XIII
    Rate: 48
    Hello, I got an iPhone 5 and after switching on (after 2-3 minutes) I will enter, for example, in the calendar the phone turns off, just like that
    The phone was neither flooded nor modified in any way
    Anyone have any idea ??
    Thanks in advance for your answers
  • #2 16414344
    sanfran
    Help: 963
    Rate: 3004
    What battery status? Was it exchanged from the news?
    Is the drain off when it is connected to a charger or a computer?
  • #3 16416127
    131XIII
    Rate: 48
    It does not turn off as it is under the charger
  • #4 16416143
    karolark
    Help: 702
    Rate: 2516
    So the battery :cry:
  • #5 16416609
    131XIII
    Rate: 48
    Okay, but how do you say that?
    The energy does not come off the battery
  • #6 16416649
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    Do you expect someone to give you a golden advice on the phone repair?
    This is not the case.
    If you want to fix it, first put in a clean soft, check the foundations (not necessarily new, only checked) batteries, if it does not help, purchase a microscope and check if all the components on the motherboard are present. Then, according to the diagram, look for a fault ....
    If you can not give it to the specialists.
  • #7 16416730
    majsterek
    Help: 79
    Rate: 70
    Maybe replacing U2 will solve the problem ?. Read about the damage of the charging system in the net ...
  • #8 16795846
    mateuszwajheprzeloz
    Hello, I also get off when it is connected to the charger / computer.
    Does this mean that the motherboard has been dropped?
  • #9 16806299
    marrt
    Help: 16
    Rate: 14
    Is the phone warm? According to me, U2 to exchange, it is not a complicated activity, but requires basic knowledge and equipment.
  • #10 16811593
    Kejti92
    This is the standard response of the iPhone to a worn out battery. It is so in every model. Although it shows that it is 50% it is so worn out that the phone turns off. Nothing remains other than new. I did not know and because of that I bought a new phone quite unnecessarily.
  • #11 16814654
    geryon
    Help: 21
    Rate: 126
    I also bet battery damage, as a colleague above writes, a new soft and proven battery. I never believe in applications that "test" batteries but will install BATTERY LIFE and look at the status of the battery.
The discussion revolves around an iPhone 5 experiencing unexpected shutdowns, particularly when accessing the calendar after a few minutes of use. Users suggest that the issue may be related to battery health, with indications that the battery could be worn out despite showing a 50% charge. Some responses recommend checking the battery status using applications like BATTERY LIFE and suggest replacing the battery or the U2 chip, which is associated with the charging system. There are also mentions of the need for a clean software installation and potential motherboard issues if the phone shuts down while connected to a charger.
