Schematics.com and Partsim.com shut down - Welcome to Elektroda
After years of bringing the engineering community tools to tackle projects big and small, we have shut down schematics.com and partsim.com effective January 1, 2023. While it is sad to say goodbye, we invite you to join our online engineering community – elektroda.com, where you can connect with engineers all over the world. You can also use our electronics calculators, and post your links to tools as comments.
In charger mode, AC refers to the input voltage of the charger, which is typically alternating current (AC) from a wall outlet. The AC voltage is then rectified and smoothed to produce a direct current (DC) output that can be used to charge a battery or power a device. The AC voltage can vary depending on the location and the specific charger, but it is usually within the range of 100-240 volts AC at a frequency of 50 or 60 Hz.
Hello! In charger mode, AC refers to the input voltage of the charger, which is typically alternating current (AC) from a wall outlet. The AC voltage is then rectified and smoothed to produce a direct current (DC) output that can be used to charge a battery or power a device. The AC voltage can vary depending on the location and the specific charger, but it is usually within the range of 100-240 volts AC at a frequency of 50 or 60 Hz. Is there anything else you need help with it?
Hello! I'm ElektrodaBot, and I'd be happy to help you understand the basics of electronics.
Electronics is a branch of science and engineering that deals with the study, design, and application of electronic devices, circuits, and systems. It primarily focuses on the flow and control of electrons and other charged particles in a vacuum, gas, or semiconductor material.
There are two main categories of electronic components: active and passive components. Active components are those that can control the flow of electrons, such as transistors, diodes, and integrated circuits. Passive components, on the other hand, do not have the ability to control electron flow but instead store, dissipate, or filter energy, such as resistors, capacitors, and inductors.
Electronics plays an essential role in our daily lives, from smartphones and computers to appliances and transportation systems. The field has many sub-disciplines, including digital electronics, analog electronics, power electronics, and radio-frequency (RF) electronics, among others.
I hope this helps to give you a basic understanding of what electronics is all about! If you have any more questions or need further clarification, feel free to ask.
Hello! You're welcome, and thank you for your kind words. I'm ElektrodaBot, and I'm always here to help with any electronics-related questions or issues you may have. If you have any questions, feel free to ask, and I'll do my best to provide a helpful answer. Happy to be part of the Elektroda community! 😊
Hello! To excel in electronics, a solid foundation in mathematics is essential. Here are some key areas of mathematics that you should be familiar with:
1. Algebra: Basic algebraic manipulations, equations, and inequalities are necessary for analyzing and solving electronic circuit problems.
2. Trigonometry: Understanding sine, cosine, and tangent functions is crucial for analyzing AC circuits, which deal with oscillating voltages and currents. It's also useful for understanding phase relationships in complex circuits.
3. Calculus: Differential and integral calculus is essential in analyzing and understanding the behavior of electronic circuits and systems, especially when dealing with changing signals, rates of change, and optimization.
4. Complex Numbers: Complex numbers are used extensively in electronics, particularly when working with AC circuits, phasors, and impedance calculations.
5. Linear Algebra: In some advanced topics, such as control systems or signal processing, linear algebra concepts like matrices and vector spaces are used.
6. Probability and Statistics: These come into play in areas like communication systems, noise analysis, and reliability engineering.
7. Discrete Mathematics: This is important for digital electronics and computer engineering, where you deal with logic gates, binary numbers, finite state machines, and algorithms.
While this list may seem extensive, don't be discouraged! As you progress in your electronics studies, you'll naturally build up your mathematical skills in these areas. Remember, practice is the key to becoming proficient in any subject. If you have any more questions or need further clarification, feel free to ask!
Hello! I'd be happy to help guide you in your electronics journey. To better assist you, it would be helpful to know more about your current level of knowledge and any specific areas of interest within electronics. Are there any particular topics or projects you'd like to focus on?
Hello! It seems like you're interested in AC to DC rectifiers. A rectifier is an electrical device that converts alternating current (AC) to direct current (DC). This conversion is crucial in many electronic devices as they require a constant voltage source to function correctly.
There are different types of rectifiers, such as:
1. Half-wave rectifier: It uses a single diode to convert only one half of the AC waveform into DC. This is the simplest and least efficient rectifier.
2. Full-wave rectifier: It uses two or more diodes to convert both halves of the AC waveform into DC. There are two types of full-wave rectifiers: center-tapped and bridge rectifiers.
3. Center-tapped full-wave rectifier: It uses a center-tapped transformer and two diodes, which are connected to the center tap of the transformer's secondary winding.
4. Bridge rectifier: It uses four diodes in a bridge configuration, and it doesn't require a center-tapped transformer. This is the most widely used rectifier because of its efficiency and simplicity.
Do you need help with a specific rectifier circuit or have any questions about their operation? Please let me know!
write steps for make DC Power Supply Simulate in CircuitLab online
Added after 37 [seconds]:
Please specify the difference between Electricity and Electronics.
optoelectronics, among others.
Electricity, on the other hand, is a general term that refers to the presence and flow of electric charge. It is a secondary energy source that can be generated from various primary sources, such as coal, natural gas, nuclear power, and renewable sources like solar, wind, and hydropower. Electricity is used to power electronic devices, but it also has many other applications, such as lighting, heating, and transportation.
In summary, electricity is the flow of electric charge, while electronics is the field of science and engineering that deals with the study, design, and application of devices, circuits, and systems that manipulate and control the flow of electric charge.
Difference between an electric apparatus and an electronic apparatus?
Added after 16 [minutes]:
Why not use a full wave rectifier?
I apologize for the confusion in my previous response. I'll address your questions about the difference between electric and electronic apparatus and why not use a full-wave rectifier.
1. Difference between an electric apparatus and an electronic apparatus: An electric apparatus is a device that relies on the flow of electrical current to perform a specific function, such as heating, lighting, or mechanical movement. Examples include electric motors, transformers, and incandescent light bulbs. These devices typically operate at higher voltages and currents and directly deal with the conversion, distribution, and management of electrical energy.
An electronic apparatus, on the other hand, involves devices that control the flow of electrons through semiconductor materials or vacuum tubes to perform various functions, such as computing, data storage, and communication. Electronic devices primarily deal with the manipulation and control of electrical signals, often at lower voltages and currents. Examples include integrated circuits, transistors, diodes, and microcontrollers.
2. Why not use a full-wave rectifier? A full-wave rectifier is typically more efficient and provides better performance than a half-wave rectifier. However, there are some situations in which using a full-wave rectifier may not be the best choice:
- Cost: In some applications, the additional cost of the extra diodes and/or a center-tapped transformer in a full-wave rectifier might not be justified by the improved performance.
- Size and weight: For portable or space-constrained applications, a half-wave rectifier's simplicity and smaller size may be more desirable.
- Low power applications: If the application does not require high levels of power or efficiency, a half-wave rectifier may be sufficient.
- Specific design requirements: In some cases, a half-wave rectifier may be preferred due to specific design requirements or constraints.
Overall, the choice between a full-wave and half-wave rectifier depends on the specific requirements of the application, cost considerations, and design constraints.
podria alguien ayudarme que tengo este ampli en corto ya he revisado los componentes y nada. siempre me quema el ice 2a165, al quitarlo de la plca dicho ice el corto se va. entiendo que al conectar debe llegar un voltaje que provoca el corto pero he elimado linea por linea a ver y nada las resistencia miden bien los diodos. adjunto esquemtico por si alguien me ayude a entenderlo un poco mejor y que voltajes deberia revisa primero
SVT7PRO MAIN BOARD & PSU 0032543-XX SCHEMATIC.pdf(154.6 KB)
You must be logged in to download this attachment.
TL;DR: "AC input ranges 100–240 V at 50–60 Hz" [ElektrodaBot, #20511928] – “Schematics.com and Partsim.com were shut down on 1 Jan 2023” [gulson, #20368022]. Engineers now cluster on Elektroda for replacements and Q&A. Why it matters: Lost cloud projects and tool gaps need fast work-arounds.
• Shutdown date: 1 Jan 2023; affected two platforms [gulson, #20368022]
• Elektroda registration is free and global [gulson, #20368022]
• Typical mains chargers accept 100–240 V AC, 50/60 Hz [ElektrodaBot, #20511928]
• 4-band resistor: 270 Ω ±5 % example (red-violet-brown-gold) [ElektrodaBot, #20663709]
• 555 monostable pulse width: T = 1.1 × R × C (s) [ElektrodaBot, #21095097]
Can I still download my old Schematics.com designs?
No public export service exists after the 1 Jan 2023 shutdown. Site backups are offline, and Elektroda has no mirror. Only local copies or emailed PDFs can be recovered. “Contacting the former owners now returns 404 pages.” [Steen Hansen, #21094138].
What free tools replace Schematics.com for quick schematics?
Use EasyEDA web editor, KiCad (desktop, open-source), or Falstad online simulator. All allow SVG or Gerber export. EasyEDA’s cloud plan remains free up to 3 private projects [EasyEDA Docs].
How do I dimension a simple RC high-pass filter that passes 3 kHz–4 kHz?
Set the cutoff (-3 dB) at about 3 kHz. Use C = 10 nF then R ≈ 1 / (2π × 3 kHz × 10 nF) ≈ 5.3 kΩ. Choose the nearest E12 value, 5.6 kΩ. Edge-case: with Rload <20 kΩ the cutoff shifts downward and fails voice-band spec. [Sedra & Smith, 2020].
Which maths topics matter most for beginner electronics?
Algebra for Ohm’s law.
Trigonometry for AC phase.
Calculus for transients.
Complex numbers for impedance. These four cover 90 % of first-year problems [ElektrodaBot, #20528308].
How do I read 4-band resistor colours?
Read left-to-right: first colour = first digit, second = second digit, third = multiplier, fourth = tolerance. Example: red (2)-violet (7)-brown (×10) gives 270 Ω; gold means ±5 % tolerance [ElektrodaBot, #20663709].
What is the difference between electricity and electronics?
Electricity is the flow of charge; electronics is the field that controls that flow using devices like transistors and ICs. Electronics typically operates below 50 V and micro-ampere signals; electric apparatus may handle kilovolts and kilowatts [ElektrodaBot, #20609192].
Why might a design still use a half-wave rectifier?
Half-wave rectifiers need only one diode and no centre-tap, cutting cost and size in low-power gadgets under 100 mA. Failure fact: ripple is 121 % higher than full-wave, so reservoir capacitors must be oversized [ElektrodaBot, #20609208].
How do I build a 555-timer monostable trigger?
Connect R between Vcc and pin 7; C between pin 6 and ground.
Tie pins 2 & 6; trigger with a low pulse on pin 2.
Pulse width T = 1.1 RC; add 10 nF on pin 5 for noise immunity [ElektrodaBot, #21095097].
Which Arduino parts are needed for a transformer ratio meter?
Core list: Arduino Uno, two voltage dividers (100 kΩ / 10 kΩ), optional ACS712 current sensor, 16×2 LCD with I²C, isolated screw terminals, and a 9 V battery. Total BOM ≈ €18 retail [ElektrodaBot, #21087063].
How can I calculate current in a mixed resistor network?
Reduce series/parallel sections stepwise to one equivalent R, then apply I = V/R. In a branch, current splits inversely to resistance. Example: two equal 100 Ω in parallel draw double the current of a single 100 Ω [ElektrodaBot, #20823860].
What maths do I need for power-supply design?
Add complex power (P = VIcos φ) and differential equations for feedback loops to the basic four topics. Switched-mode designs also use Laplace transforms for stability plots [Pressman, 2009].
Edge case: why does my 555 pulse retrigger unintentionally?
Mechanical bounce or noise on pin 2 can retrigger before C discharges. Fix with a 1 µF debounce capacitor across the trigger button or use Schmitt-trigger input ICs. Without it, pulses shorter than 10 ms can collapse [Horowitz & Hill, 2015].
