MAN-Power! TCU 5 00119-02 Intarder not function on 3,4,5,6....
georgechirac 3939 8
  • #1 20399466
    georgechirac
    Hi! I have this problem, is single error Code. MAN-Power! TCU 5 00119-02 Intarder not function on 3,4,5,6....
    Intarder not function on 3, 4, 5, 6....
    Advices?
  • #2 20403703
    darfur5
    Help: 267
    Rate: 1708
    Maybe you could write what kind of car it is.
  • #4 20403732
    kakibara
    Help: 202
    Rate: 1278
    1. Check the oil level in the retarder.
    2. Check the gearbox oil level.
    3. Do you have wet (outside) rear air tanks?
    It seems to me that it has a scania gearbox.
  • #5 20405214
    darfur5
    Help: 267
    Rate: 1708
    TruckElectronica wrote:
    MAN
    It now has a color monitor! It's amazing how long I haven't looked into the cabin.
  • #6 20405245
    TruckElectronica
    Help: 73
    Rate: 275
    such a small colorful one is already old in principle :) in the latest TG3 model there is already a full lcd
    Truck Bus Electronica
    Opolska, Kraków, 30-000 | Company Website: https://www.truckbuselectronica.pl
  • #7 20405289
    darfur5
    Help: 267
    Rate: 1708
    It's good that retirement is near because it's getting harder and harder to handle the litter box :crazyeyes:
  • #8 20936666
    turnip4
    Rate: 67
    Hello, what was the cause of this error because I have the same problem?
  • #9 20936785
    ROKADI
    Help: 43
    Rate: 193
    SPN 0119 Retarder oil pressure
    Monitoring strategy
    Retarder oil pressure monitoring with T80 oil pressure sensor
    Client perception/symptom description
    • The central warning light illuminates continuously yellow when driving and when the vehicle is stationary
    • Retarder braking mode is not possible
    Failure Mode Identification (FMI)
    FMI 1 Value too high
    Indication on the display
    Priority 5 Text
    indications
    Control device conditions
    Setting conditions
    Retarder oil pressure greater than 1350 mbar even though no braking torque has been requested
    Reset conditions
    Symptoms
    Systemic reaction/possible effects
    Substitute reaction
    Reasons
    Possible causes
    ► T80 oil pressure sensor faulty
    ► Damaged or disconnected electrical cables and plug connections from the control device
    gearbox to the T80 oil pressure sensor or the V97 valve block
    ► The solenoid/proportional valves in the V97 valve block are faulty
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 2/11
    Inspections
    Possible control steps
    Visual inspections
    ► Carry out a visual inspection of the T80 oil pressure sensor
    ► Carry out a visual inspection of the V97 valve block
    ► Check the lines and plug connections from the transmission control unit to the oil pressure sensor
    T80 for damage, abrasion, interruption, short circuit, transition resistance, change in cross-section,
    corrosion, correct connection and loose contacts
    ► Pin assignment:
    Contact Action Connection
    1 Supply voltage 5 V Gearbox control device
    gears, contact B33
    2 Sensor ground Gearbox control device
    gears, contact B35
    3
    Sensor output signal
    oil pressure (0.6–4.5V / 1–
    30 bar)
    gears, contact B36
    ► Measured values:
    Pressure
    oil in
    mbar
    1000 2000 3000 4000 5000 6000 7000 ...
    Tension
    In
    volts
    0.6 0.8 0.9 1.1 1.2 1.3 1.5 …
    ► Check the supply voltage of the T80 oil pressure sensor in the oil pressure sensor between pin 1 and
    pin 2. Set value: 5 V
    ► Check the signal voltage of the oil pressure sensor T80 in the gearbox control unit
    pin B35 (-) and pin B36 (+). Setpoints: see measurement value table
    Solenoid/proportional valves in the V97 valve block
    ► Check the correct operation of the solenoid/proportional valves in the valve block
    V97 with MAN-cats and actuator test (retarder xxxx): Acoustic feedback
    (ticking test)
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 3/11
    Inspections
    ► Pin assignment:
    1 Unused ---
    2 Valve control
    proportional
    gears, contact B37
    3 Proportional valve mass Gearbox control device
    gears, contact B39
    4
    Valve control
    electromagnetic power supply
    compressed air
    gears, contact B34
    5 Valve weight
    electromagnetic
    gears, contact B38
    6
    Valve control
    solenoid valve
    power supply security
    compressed air
    gears, contact B4
    7 Unused ---
    ► Proportional valve measurement values:
    Temperature in °C -40 +20 +125
    Resistance in ohms 22.5 29.4 41.5
    ► Measurement values of solenoid valves:
    Resistance in ohms 98 128 (+10%/-5%) 180
    Remedy
    Possible remedy
    ► If necessary, replace the T80 oil pressure sensor
    ► Repair cables and plug connections if necessary
    ► Replace the V97 valve block if necessary
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 4/11
    Attention
    Additional information/tips
    ► The T80 oil pressure sensor measures the oil pressure in the retarder, which is proportional to the torque
    braking
    ► To check the T80 oil pressure sensor, pressure must be applied to it. Sensor
    The oil pressure switch must output a signal of 0.6V ±2% at atmospheric pressure when energized
    voltage of 5 V
    FMI 2 Value too low
    Priority 5 Text
    indications
    Setting conditions
    Oil pressure in the retarder less than 1000 mbar, although torque above 2000 Nm was requested for longer than
    for 7 s
    Reset conditions
    Symptoms
    Substitute reaction
    Reasons
    Possible causes
    ► Too little retarder oil
    ► Low quality of oil in the retarder
    ► Oil temperature in the retarder too low
    gear to the T80 oil pressure sensor
    ► The solenoid valve in the V97 block is faulty
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 5/11
    Inspections
    ► Check whether the retarder oil quantity is between the minimum and maximum values:
    set value approximately 7.9 l
    ► Check the quality of the oil in the retarder
    ► Check the oil temperature in the retarder: Setpoint: greater than 0°C
    Visual inspections
    Pin assignment:
    gears, contact B33
    gears, contact B35
    3
    30 bar)
    gears, contact B36
    Measured values:
    Pressure
    oil in
    mbar
    Tension
    In
    volts
    (ticking test)
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 6/11
    Inspections
    ► Pin assignment:
    1 Unused ---
    2 Valve control
    proportional
    gears, contact B37
    gears, contact B39
    4
    Valve control
    compressed air
    gears, contact B34
    5 Valve weight
    electromagnetic
    gears, contact B38
    6
    Valve control
    solenoid valve
    compressed air
    gears, contact B4
    7 Unused ---
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 7/11
    Remedy
    Possible remedy
    ► Correct the retarder oil quantity so that it is between the minimum value and
    maximum: set value approximately 7.9 l
    ► Change the retarder oil if necessary
    ► Replace the retarder oil filter if necessary
    Attention
    braking
    voltage of 5 V
    FMI 5 Short circuit to ground
    Priority 5 Text
    indications
    Setting conditions
    The voltage of the T80 oil pressure sensor is below 0.175 V for longer than 500 ms
    The T80 oil pressure sensor has a short circuit to a low voltage source
    Reset conditions
    Symptoms
    Substitute reaction
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 8/11
    Reasons
    Possible causes
    Inspections
    Visual inspections
    Pin assignment:
    gears, contact B33
    gears, contact B35
    3
    30 bar)
    gears, contact B36
    Measured values:
    Pressure
    oil in
    mbar
    Tension
    In
    volts
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 9/11
    Remedy
    Possible remedy
    Attention
    braking
    voltage of 5 V
    FMI 12 Interrupt or short to UBatt+
    Priority 5 Text
    indications
    Setting conditions
    The voltage of the T80 oil pressure sensor is above 4.60 V for a period longer than 500 ms
    Reset conditions
    Symptoms
    Substitute reaction
    Reasons
    Possible causes
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 10/11
    Inspections
    Visual inspections
    Pin assignment:
    gears, contact B33
    gears, contact B35
    3
    30 bar)
    gears, contact B36
    Measured values:
    Pressure
    oil in
    mbar
    Tension
    In
    volts
    Remedy
    Possible remedy
    SPN_0119_Retarderöldruck_GTR-SGC-Scania : 2021-09-29 : 11/11
    Attention
    braking
    ROKADI - MAN
    Kętrzyńskiego 8, Olsztyn, 10-506 | Tel.: 660-XXX-XXX (Show)
✨ The discussion revolves around a malfunctioning Intarder (TCU 5 00119-02) in a MAN vehicle, specifically not functioning in gears 3, 4, 5, and 6. The user reports a single error code and seeks advice. Responses suggest checking the oil levels in both the retarder and gearbox, as well as inspecting the rear air tanks. A detailed analysis of the error code SPN 0119 indicates potential issues with the T80 oil pressure sensor, electrical connections, or solenoid/proportional valves in the V97 valve block, which could prevent retarder braking mode from functioning properly.
