I need the operating instructions for the GAMA 150 electricity meter.
CYRUS2 wrote:So it`s a novelty, after the serial number there is "23", i.e. the year of production, and it`s only February.I`ve had one for 12 days.
CYRUS2 wrote:Are you sure you`ve looked through the appropriate registers? Maybe you held the button a little longer and the counter entered the overview of not the current registers, but the average ones.But….
Yesterday the counter showed differently than today.
zbich70 wrote:Power currently consumed.Are you sure you`ve looked through the appropriate registers? Maybe you held the button a little longer and the counter entered the archive register review.
zbich70 wrote:I don`t know the codes - for this I need, for example, instructions.Krzychu, write down what the counter showed while scrolling the display: OBIS code -> register contents.
Without this we will never figure out what is going on.
CYRUS2 wrote:OBIS codes are universal for all meters, no model-specific instructions are needed.I don`t know the codes - for this I need, for example, instructions.
CYRUS2 wrote:This code is actually not on the list. This may be the equivalent of a code 16.7.0 Power P, instantaneous value only six were lost.Parameter name 17.0 T1 description = kW.
zbich70 wrote:The list shows an instantaneous power of 17.0 and that`s it.This code is actually not on the list. This may be the equivalent of a code 16.7.0 Power P, instantaneous value only six were lost.
was177 wrote:All you need is a description from the counter.I also had GAMMA 150 installed. I would also like to see the instructions. With the right button you can scroll to code 1.8 and then there is consumption and other codes?
TL;DR: New in 2023 ("23" on the serial), the GAMA 150 is navigated via two buttons—"You have two buttons to scroll through the OBIS codes." This FAQ helps you read consumption and live power without a missing manual. [Elektroda, zbich70, post #20451334]
