PGE GAMA 350 Two-way Meter: Exploring Remote Reading Options via Network/GSM
Aureliuszz 16884 12
Can I read my PGE GAMA 350 meter data remotely over the Internet or GSM, and how does user access work?
User access is usually limited to the display, and remote reading depends on what PGE/operator provides to you [#19572263] You should ask the seller/operator whether they can enable reading data or give access through a dedicated customer app, similar to the e-meter apps used by some utilities [#19573644][#19573669] The meter is said to support Wireless M-Bus 868 MHz for local communication, but the transmitted data is encrypted and requires the proper key/password to decode it [#21479760][#21836169] One reply also claims the meter has a data bus where an interface can be fitted, such as USB, RS485, or GSM, but without the key and the right software you won’t be able to read useful data [#21835538][#21835565] So there is no simple “download an app and read it from the Internet” solution unless the operator explicitly enables it or provides the needed credentials/interface [#21835565]
  • #1 19572199
    Aureliuszz
    Rate: 21
    I recently had my meter replaced at PGE.
    Two-way counter GAMA 350.
    The technicians wrote down the IP and the key on it.
    After the icons, I can see that the meter has some network/GSM coverage.
    Is there any possibility to read network (from the Internet?) this data?
    Anyone know how it works in PGE?
  • #2 19572263
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    Yes, PGE has remote access for reading and the user has only what is on the screen.
  • #3 19573644
    bartekfigura
    Level 30  
    Help: 112
    Rate: 523
    There should also be a dedicated application for the recipient, something like the e-counter application in Tauron.
  • #4 19573669
    rstlen29
    Help: 40
    Rate: 101
    In the case of this information, it is worth asking the seller or operator whether it is possible to provide reading data.
    In my RD there is an application called My Counter which you can log in via the website.
    R.S. Volt
    Złocieniecka, Drawsko Pomorskie, 78-500
  • #5 21126538
    grodzio86
    Has anything changed since the last post?
  • Wireless M-Bus provides easier meter data access
    #7 21479760
    MarKiep
    >>19572199 .
    Decree of the Minister of Climate and Environment of 22 March 2022 on the measurement system (Journal of Laws 2022, item 788)
    Chapter 11
    Requirements for a remote reading meter for the purpose of communicating it with the equipment of an electricity consumer
    in a household
    § 18. 1. In order to communicate the remote reading meter with the equipment of the electricity consumer in the household, the remote reading meter shall
    household, the remote reading meter shall be equipped with a communication interface for local communication meeting the
    requirements specified in clause 7.3.2 of Annex 1 to the Regulation.
    The communication interface of the remote reading meter for local communication shall ensure protection of the transmitted metering data
    metering data transmitted to the household consumer equipment by using encrypted communication algorithms.
    This meter has a Wireless M-Bus. It is easier to obtain data from it than to present in a report, works a lot of
  • Sub-meter reads kWh only, no tariff breakdown
    #8 21835429
    pepecool
    Help: 10
    I'm just following the topic.
    I have recently changed my tariff from G11 to G12w and consequently PGE has replaced my meter with an "APATOR OTUS 3".
    I asked about the possibility of remote reading of the meter by the user, the gentleman said that there is such a possibility on request, but he needs "the necessary to decode the data transmitted via the wireless M-Bus 868 MHz interface of the remote reading meter"- unfortunately I can't find anything like that on the Internet, and at PGE they said that they can't suggest any device for me. They limited themselves to stating "smart home".
    Is anyone able to provide links as to what I should buy so that I don't have to fly to the meter but read it on my smartphone/computer?
    @djadamus1111 I happen to have bought myself such a meter as a sub-meter for a heat pump.
    It reads the number of kWh consumed, but you can't set tariffs, i.e. I don't know in which tariff how much electricity was consumed.
  • USB or RS485 interface is the easiest reading option
    #9 21835538
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    The meter has a data bus into which any interface can be fitted. (USB/rs485/GSM). So they have disposed of you with silly talk.
    The easiest way is over USB (probably RS232 emulation, or over 485).
    Only you have to write this application and get along with the jerks....
    https://www.apator.com/nasze-rozwiazania/ener...cznej/liczniki-smart/otus-3#pliki-do-pobrania
    You can find a receiver on 868Mhz under the name, Receiver wM-Bus 868MHz Home Assistant (olx).
    But it won't be as pretty...
    https://forum.arturhome.pl/t/komponent-wm-bus...leon-wersja-2-x-watek-ogolny/9117/245?page=22
    I'd steer clear of the radio, and write an application for some USB/485, as you'll have that down in 20 minutes.
    • otus3-karta-katalogowa.pdf (1.14 MB) You must be logged in to download this attachment.
  • #10 21835559
    pepecool
    Help: 10
    >>21835538 I am not proficient in the subject, the information you have given me is incomprehensible to me. Are you able to explain like a peasant on a spit of land: "you need an XYZ or ZYG device e.g.: [link to shop/auction]"
  • Meter data requires a key or cable interface
    #11 21835565
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    I'm not either, and if you're not I wouldn't push any radio.
    You can't read the data without a key (after all, the meter can't broadcast your consumption openly into the ether).
    https://www.elektroda.pl/rtvforum/topic2690976.html
    The meter has the possibility of fitting another interface, (cable).
    If you think it's going to be so simple that you download a wonderful app to your phone and it will work - then no, it won't. It can clearly transmit by cable at most. (USB/rs232) but you probably won't ask for such an insert to be installed.
  • #13 21836169
    Brivido
    Help: 226
    Rate: 430
    And for this you just need a password, what he wrote back to you laconically that on request you might get a key to download the meter data via mbus.
The discussion concerns remote reading of a PGE-installed two-way electricity meter, initially identified as GAMA 350, and whether consumption data can be accessed from the Internet or via GSM/network. Responses indicate that PGE has remote meter reading, but the customer typically only sees the display data unless the operator provides access credentials or a dedicated consumer application. Later posts shift to similar smart meters such as APATOR OTUS 3 and explain that user access may require a password/key to decode data from the wireless M-Bus 868 MHz interface. Alternative access methods mentioned include USB, RS485, RS232 emulation, GSM, and Home Assistant-compatible wM-Bus receivers, with caution that radio data is encrypted and not directly readable without the proper key or interface.
