Smart EMU 1 & 3 Bidirectional Meter: User Manual Obtainment Success Story
Wislaw 66 38649 26
  • #1 17729199
    Wislaw 66
    Rate: 34
    Smart EMU 1 and 3 bidirectional meter user manual was hard to come by but I finally got it
    • smartEMU_13_08_2018_instrukcja.pdf (4.06 MB) You must be logged in to download this attachment.
  • #2 17755388
    rafmysz
    Many thanks for pdf.
    Now the question arises how to connect the Wireless M-BUS module to this meter?
  • #3 17950287
    tomoow
    Has anyone been able to read the data from such a meter through the optical head? PGE operator. For me, on 1 try, I got something like the attachment. reading the instructions, I conclude that you may need a password from PGE.
  • #4 17972349
    bondmu
    I also have such a counter. How to read data from it correctly with a head? I can see that the character encoding above in the screenshot is not ok
  • #5 18053178
    gucioguci
    Help: 7
    Rate: 17
    Reads easily through the optocoupler at home
    Interestingly, I was at my power plant asking how they relate to reading the basic parameters, i.e. those without a password. They stated that there is no problem, they normally pleasantly surprised me
    Smart EMU 1 & 3 Bidirectional Meter: User Manual Obtainment Success Story Screenshot...rminal.png (42.2 kB)You must be logged in to download this attachment.
    Connected to FTDI device
    / APA6 \ 2EMU30
    ^ BC.1.0 ()
    0.9.1 (21:23:34)
    0.9.2 ()
    0.2.2 (19G12w)
    C.1.7 ()
    1.0.0 ()
    1.8.0 (* 000,027.36 kWh)
    1.8.1 (* 000,008.62 kWh)
    1.8.2 (* 000,018.73 kWh)
    2.8.0 (* 000,354.09 kWh)
    2.8.1 (* 000,190.95 kWh)
    2.8.2 (* 000,163.13 kWh)
    5.8.0 (000003.61 * kVarh)
    6.8.0 (000002.13 * kVarh)
    7.8.0 (000042.94 * kVarh)
    8.8.0 (000022.89 * kVarh)
    1.6.0 (01.435 * kW) (19-06-20 18:45)
    2.6.0 (05.073 * kW) (19/06/21 10:45)
    C ^ I ^
    Connection lost
    Good luck
  • #6 18192215
    AlekZ
    Vacuum tubes specialist
    Help: 85
    Rate: 2893
    Can you tell me how to check if this meter has phase-to-phase balancing?
  • #7 18200931
    xfiless
    Rate: 9
    What does the red button do? The one next to the blue ones? There is nothing about this in the instructions
  • #8 18201001
    AlekZ
    Help: 85
    Rate: 2893
    This button is sealed and is used to access meter functions not available to the user.
  • #9 18201074
    xfiless
    Rate: 9
    So it's physically impossible to even press it?
    Is it possible to press, but the pressure will not do anything?
    Will I break the seal by pressing the red button?
  • #10 18205237
    oshii
    Help: 84
    Rate: 259
    On the right side you have a wedge, secured by a seal (in the form of a wire), which would indicate that there is no physical possibility to press the red button without additional interference.
  • #11 18262829
    Maco65
    Rate: 10
    I did this: I pressed the top blue button for more than 5 seconds, the data on the display changes. Then I pressed the blue button again (scrolling through what is displayed) and at one point the inscription "FErrAri5" appeared - that is, confirmation that balancing is. According to the instructions (from the beginning of the thread) the Ferraris method provides phase-to-phase balancing in the meter.
    I don't know what is displayed if there is no balancing. Maybe "PErPha5E" as per the instructions?
  • #12 18265806
    kazek1561
    Rate: 39
    My emaur3 from Tauron has no balancing and communicates with the inscription "nornAL".
  • #13 18266016
    Maco65
    Rate: 10
    That we should be 100% sure. Do you have the code C.80.0 in the upper left corner of the display?
    I am attaching a photo of this setting from my counter.
  • #14 18267693
    AlekZ
    Help: 85
    Rate: 2893
    Thank you for the tip. It seems that my (PGE) balancing is.
  • #15 18267969
    adamkorski
    / APA6 \ 2EMU30
    ^ BC.1.0 ()
    0.9.1 (21:23:34)
    0.9.2 ()
    0.2.2 (19G12w)
    C.1.7 ()
    1.0.0 ()
    C ^ I ^
    Connection lost
    Good luck
    You can write, what optical connector you read and what program it is?
  • #16 18273283
    macko_m
    In the thread "reja" https://www.elektroda.pl/rtvforum/topic3575192.html
    they write as in the instructions, i.e.
    " The smartEMU3 counter allows you to choose between three energy balancing methods. Two methods are available:
    The "algebraic method" "per phase", in which each measuring system of a three-phase meter adds the energy it measures to the appropriate counters, regardless of other systems,
    The "vector method" "Ferraris", imitating induction meters; in this method, the energies from the three measuring systems are first summed (including phase energy signs), and then, if the sum of the energy is positive, it is added to the 1.8.x counters, and if negative - to the 2.8.x counters (without the minus sign) ).
    Example:
    Initial condition of counters:
    1.8.0 = 900.0 kWh
    2.8.0 = 100.0 kWh
    Sample energy consumption:
    EL1 = +1 kWh (1 kWh consumption occurred in phase L1)
    EL2 = +4 kWh (4 kWh consumption occurred in phase L2)
    EL3 = -3 kWh (3 kWh export occurred in L3 phase)
    Final state of counters in the "per phase" method:
    1.8.0 = 905.0 kWh
    2.8.0 = 103.0 kWh
    The final state of the counters in the "Ferraris" method:
    1.8.0 = 902.0 kWh
    2.8.0 = 100.0 kWh
    Zakład Energetyczny decides itself how the measurement should be carried out by the meter.
    Energa uses - "Algebraic method" "per phase".
    The "vector method" "Ferraris" - is more beneficial for us and so looking at the entries Maco65 and AlekZ does PGE.
    In the evening I will check with myself; (PGE connected 8.11).
  • #18 18342857
    abukkja
    Rate: 10
    Hello, does anyone know what the code c.12.5 means in the smart emu1 counter? Thank you in advance for your answer.
  • #19 18435815
    afromat
    Muczios players ;) You save your ass hard.
  • #20 18570479
    pompadom
    And this interface via USB to Android is how it is made? Can you ask for some diagram, where to buy or how to do?
  • #21 18980940
    pet314
    rafmysz wrote:
    Many thanks for the pdf.
    Now the question is how to connect the Wireless M-BUS module to this meter?
    I was able to start remote reading from the Apator Smart EMU3 meter at OSD Tauron. The same should work with other smart AMIPlus meters fitted by Tauron (Mitsubishi, Networked Energy Services NES)
    1) In the eLicznik Tauron Dystrybucja service, you need to activate the service they call HANPlus (from Home Area Network). Tauron sends the command to activate the wireless M-BUS transmission to the meter via the PLC link. In my case, activation by the website returned an error several times ("HAN activation order - failed"). The hotline is a dead end, no one there is aware of the existence of such a service. I started calling their API manually, the next attempt was successful ("HAN Activation Request - Successful").
    2) After successful HANPlus activation, the meter ID and communication decryption key are available on the eCount page.
    3) I bought a W-MBUS reading dongle: iM871A-USB. A cheaper alternative, which I haven't checked myself, is to use the DVB-T tuner as a softradia and rtl-wmbus program.
    4) I installed wmbusmeters on my Raspberry which reads and decrypts data. The available information is total consumption, instantaneous input power, total energy fed into the grid, instantaneous input power.
    5) I store the data in the InfluxDB database, together with the readings from the Fronius inverter, I have a complete set of information about production, consumption, self-consumption and energy given to the grid.
    6) PROFIT !!!
  • #22 18981168
    wello
    Help: 23
    Rate: 105
    How did you do it? I do not see such an option to choose from. Edit: I checked and this option is only available in selected cities.
    How did you do it manually? Have you plugged into your installation and sent the commands that your meter reads?
  • #23 18981192
    pet314
    Yes, not everyone in Tauron has this option. You can check the service availability here:
    https://amiplus.tauron-dystrybucja.pl/elicznik/sprawdz-dostep
    HANPlus activation is available here:
    https://elicznik.tauron-dystrybucja.pl/licznik
    I manually triggered the activation command on the Tauron website (endpoint / ot / hanon ) as if I had clicked on a link. However, the link itself was unavailable for me, I only saw the Deactivation link, even though the activation had failed earlier.
  • #24 20078926
    firepunch
    Rate: 33
    abukkja wrote:
    Hello, does anyone know what the code c.12.5 in the smart emu1 counter means? Thank you in advance for your answer.
    Probably it will be gsm signal strength (remote meter reading)
    for example: -55 signal strong, -95 signal weak
  • Clarifying 1.8.0 and 2.8.0 meter subregisters
    #25 20280990
    mikrobi701
    Does any of the forum members know how to interpret the readings read from the "window" under the numbers:
    1.8.0.1 ..... 1.8.0.6, 2.8.0.1 ....... 2.8.0.6 and the same values as in 2.8.0 ...: 2.8.1.1 .... 2.8.1.1
    As far as I read in the forum manual that 1.8.0 is energy bought (for me 8786.5) and 2.8.0 is energy "sold" (for me 12614). These values from .1 to .6 keep me awake at night because I don't know what they mean.
    Does PGE have a website where you can read the meter via the net ?!
  • Zone-specific import and export meter readings explained
    #26 20281128
    pablo_banita
    Rate: 16
    1.8.0 Active energy input, total kWh A
    1.8.1 Active energy consumed in zone I kWh A (T1)
    1.8.2 Active energy consumed in zone II kWh A (T2)
    1.8.3 Active energy consumed in zone III kWh A (T3)
    1.8.4 Active energy consumed in zone IV kWh A (T4)
    2.8.0 Active exported energy, total kWh A-
    2.8.1 Active energy delivered in zone I kWh A- (T1)
    E.T.C.
  • Explains 1.8.0.x and 2.8.0.x archival meter values
    #27 20281263
    =Grzegorz=
    Help: 73
    Rate: 447
    These are archival values, depending on how the counter is closed, and it can close, for example, every month or every day, or for any day of the month
    if every month on the 1st day of the month then:
    1.8.0.1 = state of energy consumed on 1.11.2022
    1.8.0.2 = state of energy consumed on 01/10/2022
    e.t.c
    if the counter will have daily closing, then:
    1.8.0.1 = state of energy consumed -1 day back at 0:00
    1.8.0.2 = state of consumed energy -2 days back at 0:00
    e.t.c
    Closing can be any and it is determined by the ZE.
    2.8.0.x is the same
The discussion revolves around the challenges and solutions related to obtaining and utilizing the user manual for the Smart EMU 1 and 3 bidirectional meters. Users share their experiences in connecting the meters to various devices, such as the Wireless M-BUS module and optical heads for data reading. Several users inquire about specific functionalities, such as the purpose of a red button on the meter, phase-to-phase balancing, and interpreting meter readings. Solutions include using specific software and hardware for remote reading, as well as methods for checking energy balancing. The conversation highlights the importance of understanding the meter's display codes and the activation of services for remote data access.
TL;DR: In one field test 46 OBIS codes were downloaded in 15 s via the optical port—"reads easily through the optocoupler" [Elektroda, gucioguci, post #18053178] Unlock wireless M-BUS with Tauron’s HANPlus, then decrypt frames using wmbusmeters [Elektroda, pet314, post #18980940] Why it matters: Fast local data cuts energy-billing surprises.
• Optical port: IEC 62056-21, typical 9600 baud, mode C/D [Apator Manual, 2018]. • Wireless M-BUS: 868 MHz, AES-128 encryption key shown after HANPlus activation [Elektroda, pet314, post #18980940] • Three balancing modes; “Ferraris” gives netting across phases, often enabled by PGE [Elektroda, macko_m, post #18273283] • Archive registers .1–.6 hold daily or monthly snapshots set by the utility [Elektroda, =Grzegorz=, post #20281263] • Red sealed button is service-only; pressing breaks the wire seal [Elektroda, oshii, post #18205237]
1. Where can I get the Smart EMU 1/3 user manual?
Forum user Wislaw 66 shared the PDF in the first post [Elektroda, Wislaw 66, post #17729199] If the link expires, search “Apator Smart EMU3 instrukcja” on the Apator support site; file size ≈1.4 MB.
3. What hardware and software read W-MBUS frames?
Users report success with an iM871A-USB dongle (€40) or an RTL-SDR stick (€20) running rtl-wmbus [Elektroda, pet314, post #18980940] wmbusmeters on a Raspberry Pi consumes <4 % CPU while parsing 30-second telegrams [wmbusmeters Docs, 2023].
4. How do I read the meter through the optical head?
Attach an IEC 62056-21 compliant head to a 3.3 V FTDI adapter, set 9600 baud, 7E1. Run the Android app “ZR Robo” via USB-OTG to pull OBIS codes; 46 lines stream in ~15 s [Elektroda, gucioguci, post #18053178]
5. Which OBIS codes show energy bought and sold?
1.8.0 = total import kWh; 1.8.1–1.8.4 = tariff zones T1–T4. 2.8.0 = total export kWh; 2.8.1–2.8.4 = export per zone [Elektroda, pablo_banita, post #20281128]
6. What do the .1 to .6 suffixes mean (e.g., 1.8.0.3)?
They are archival snapshots. Utilities pick the closure period: daily, weekly, or monthly. Example: 1.8.0.1 shows import at 00:00 the previous day when daily closing is set [Elektroda, =Grzegorz=, post #20281263]
7. How can I tell if phase-to-phase balancing (Ferraris) is active?
Hold the upper blue button > 5 s, scroll until the display shows “FErrAri5”. If you see “nornAL”, balancing is off [Elektroda, Maco65, #18262829; kazek1561, #18265806].
8. What is code C.12.5 on the LCD?
C.12.5 reports GSM signal strength for the remote modem; typical values range −55 dBm (strong) to −95 dBm (weak) [Elektroda, firepunch, post #20078926]
9. What does the sealed red button do?
It accesses installer menus. A metal wedge and wire seal block the plunger, so pushing it breaks the seal and voids certification [Elektroda, oshii, post #18205237]
10. How do I build a low-cost USB optical head for Android?
Solder an SFH 309-FA photodiode and an IR LED to a USB-TTL board, align them 18 mm apart, then use ZR Robo over OTG [Elektroda, pompadom, #18570479; gucioguci, #18330928].
11. Why does HANPlus activation sometimes fail?
The eLicznik front-end times out; repeated orders return “HAN activation order – failed” [Elektroda, pet314, post #18980940] Sending the API call manually bypasses the bug. Edge-case: if PLC coverage is bad, the meter never receives the enable flag.
12. Can I store readings in InfluxDB with solar inverter data?
Yes. wmbusmeters exports to JSON; Telegraf writes it to InfluxDB. One user merged meter data with Fronius production to monitor self-consumption in real time [Elektroda, pet314, post #18980940]
13. What balancing method does Energa usually set?
Energa selects the algebraic “per phase” method, meaning import/export are calculated per phase independently [Elektroda, macko_m, post #18273283]
14. Are there speed limits on wireless telegrams?
Mode S sends 4 × 25-byte frames per minute, giving ~9.6 kbit/day—ample for energy data but too slow for waveform streams [“EN 13757-4”].
15. How secure is the wireless channel?
AES-128-CTR encrypts each telegram with a rolling frame counter; no breach reports exist to date [“Wireless M-Bus Security”, 2022].
