Unlocking Hidden Features in Asus TUF FX504GM Modded BIOS (v3.1.3) for Thermal Throttling
lavoroilir 2493 10
How can I unlock hidden BIOS features or disable/underclock the GPU or CPU on an ASUS TUF FX504GM to reduce thermal throttling?
You cannot do it from Windows or by flashing a pre-modded BIOS through the ASUS BIOS menu; the dump must be written with a hardware programmer such as a CH431A [#20659928] [#20706662] [#20767568] Trying to flash the file from the BIOS menu produced the error “selected file is not a proper BIOS” [#20635228] One reply also confirmed that there is no software-only method and that a programmer is required [#20767568]
  • Request for modded BIOS to disable GPU and underclock CPU
    #1 20545218
    lavoroilir
    Hello, I am facing a problem with thermal throttling from my laptop ASUS TUF FX504GM.
    I have the model with an i5-8300H and GPU 1060 Mobile 6GB.
    If it is possible, I need a modded BIOS (v3.1.3) with hidden features unlocked, e.g. disable GPU from BIOS or underclock CPU.
    Has somebody faced the same problem as me?
    PS. If I disable GTX 1060 from Windows 10-11, the computer works fine without a blue screen, but the external HDMI monitor won't work.
    I'll attach the original BIOS I downloaded from ASUS.
  • #2 20631833
    hsnwjd8
    Bios file
    • fx504gm dump.bin (16 MB) You must be logged in to download this attachment.
  • #3 20631882
    lavoroilir
    Is this the modded BIOS or a dump of the latest? I do have the latest BIOS. :)
  • #5 20633673
    lavoroilir
    Thank you, i will try :)
  • #6 20635228
    lavoroilir
    >>20632950
    Hello, I tried to flash it from the BIOS menu, but it says "selected file is not a proper BIOS".
  • #7 20659928
    mielik6
    Help: 18
    Rate: 40
    You upload the dump through the programmer
  • #8 20667355
    lavoroilir
    Hello, which programmer? Do you mean a software tool or a hardware programmer?
    Thanks in advance.
  • #9 20706662
    mielik6
    Help: 18
    Rate: 40
    Hardware.
    For example ch431a
  • #10 20760403
    lavoroilir
    Is there a possibility to do it via software, for example, with a pre-modded BIOS? I don't know how to use a programmer.
  • #11 20767568
    robertdubina
    programmer only
The discussion revolves around addressing thermal throttling issues in the ASUS TUF FX504GM laptop, which features an Intel i5-8300H processor and a GTX 1060 Mobile GPU. The user seeks a modded BIOS (v3.1.3) to unlock hidden features such as disabling the GPU or underclocking the CPU. Initial responses indicate that the provided BIOS file is not modded, and attempts to flash it from the BIOS menu result in errors. Users suggest using a hardware programmer, specifically the CH431A, to upload the BIOS dump, as software solutions are not viable for this process.
