Asus tuf gaming - Does not turn on. The keyboard is backlit. He doesn't respond to Mr
Shouyi 23853 9
How can I fix an Asus TUF Gaming FX505DY that shows only the keyboard backlight and will not power on after a black-screen crash?
An Asus TUF Gaming FX505DY that only shows keyboard backlight after a black-screen crash can often be recovered by resetting the internal battery/power state: disconnect the battery, reconnect it, and reassemble the laptop [#18561394] Another user fixed the same symptom by holding the power button for about 1 minute, then connecting the charger after the battery had fully discharged [#19153147] If the laptop is still under warranty, the safer option is to use the warranty/service center instead of opening it [#18499714][#18499967]
  • #1 18499710
    Shouyi
    Hello. I am a user of Asus tuf gaming model FX505DY. The problem I encountered is new to me and I don`t know what it is. While using the device, a black screen appeared and the device did not respond to any commands except holding the On/Off button for about 15 seconds. After turning off the device, it does not want to turn on and the only thing you can see is the working keyboard backlight. Power LEDs do not respond to connecting or disconnecting the power supply. Thanks for your time and please help! Asus tuf gaming - Does not turn on. The keyboard is backlit. He doesn't respond to Mr
  • #2 18499714
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    If there is a warranty, use it.
    If not, look for a website.
  • #4 18560031
    MatysPL
    I have the same problem - a laptop I recently bought on x-kom, as far as I know, I got the last one they had on sale,
    The laptop has been on the desk for a month since new, the keyboard and mouse are connected to the USB ports, it hasn`t even been touched since it was new, it charged for 3 hours before connecting it, then maybe I disconnected it from the power supply once, and this morning my trach got stuck during online lessons and I got sick. exactly the same, in my opinion overvoltage. I won`t say I use the laptop quite a lot, about 5-6 hours every day, because I`m an IT student.
  • #6 18560618
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    Helpful topic for the website Link
    motherboard from asus similar to TUF Gaming FX505DT,DD,DU,
    * CPU Ryzen 5 3550H (i.e. mobile ver. Ryzen 3 2200G)
    The graphics card is AMD Radeon RX 560X, 4 GB
    Sa ver. With
    15.6``, 1920 × 1080, IPS, matt, 60 Hz, AMD Freesync (model NCP002D Sharp)
    15.6``, 1920 × 1080, IPS, matt, 120Hz, AMD Freesync
    Model from the topic
    Asus tuf gaming - Does not turn on. The keyboard is backlit. He doesn't respond to Mr Asus tuf gaming - Does not turn on. The keyboard is backlit. He doesn't respond to Mr
  • #7 18561394
    MatysPL
    Problem solved, I contacted the Asus service center to see if I could remove the disk and copy the items before shipping, they told me it would be fine as long as I didn`t damage anything or break the seals. Before removing it, I disconnected the batteries, then when I did everything, I connected it, screwed everything together and it worked. All I had to do was unplug the batteries and plug them in, best regards.
  • #8 18760124
    alamakrolika
    Hi, could you tell me how you dealt with the battery issue? I`m completely new to the subject and my son stopped doing the same thing.
  • Battery discharge and charger reconnect restored startup
    #9 19153147
    Hyyy
    I just had an identical problem. However, I preferred not to touch anything since I still have warranty. In the meantime, I look into it and the keyboard has gone out, the battery is completely discharged, I guess. I pressed the power button for 1 minute (I don`t know if it helped at all), as the manufacturer recommends, then I connected the charger and everything worked.
    The earlier tormenting of the on/off button did not help, apparently you need to either remove and insert the batteries or wait until it dies.
  • #10 19171663
    bronxter
    Howdy - my son had a similar driving situation, i.e. the light turned red + no life in the lap - after the battery ran out (about 2 days), we connected the power supply and it worked. :-) I wonder how much the website would charge for such an "operation"... 😉
    Greetings!!!
The Asus TUF Gaming FX505DY experiences a failure to power on, indicated by a black screen and only the keyboard backlight functioning. Users suggest checking warranty options for repair, as self-repair may be costly. Some users reported similar issues, with solutions including disconnecting and reconnecting the battery, pressing the power button for an extended period, or simply waiting for the battery to discharge completely. One user successfully resolved the issue by disconnecting the battery and reconnecting it, while others noted that pressing the power button for a minute helped restore functionality.
