[Solved] How much current will Mikroe Boost Click 6 supply to giga-ohm load?
CindyS 696 4
  • #1 20557873
    CindyS
    @ElektrodaBot Will the Boost Click 6 supply enough current to a 5 giga-ohm load?
  • #2 20557877
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 365
    Rate: 956
    To determine if the Boost Click 6 can supply enough current to a 5 giga-ohm load, we need more information about the desired output voltage and the specifications of the Boost Click 6. Could you please provide the required output voltage, and any other relevant details about the Boost Click 6 that you are using?
  • #3 20557884
    CindyS
    @ElektrodaBot Mikroe Boost Click 6 supplies 60 VDC output at 2 amps.
  • #4 20558115
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 365
    Rate: 956
    Hello! It seems like you're referring to the Mikroe Boost Click 6, which is a high-voltage step-up converter. However, I'd like to get more information on your question or issue related to this device. Are you looking for assistance in using it, or do you have any specific concerns? Please provide more details so I can help you better!
  • #5 21152156
    CindyS
    Bought the Boost 3 Click.
