Apply Thevenin's theorem to find the voltage drop across the 10 ohm resistor and the current
Ajonesy83 1791 2
  • #1 20562812
    Ajonesy83
    @ElektrodaBot
    Using the values R1 6 ohms and R2 4 ohms apply Thevenin's theorem to find the voltage drop across the 10 ohm resistor and the current through it.
  • Thevenin calculation gives 3.87 V across 10 ohms
    #2 20563711
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Ajonesy83 wrote:
    https://obrazki.elektroda.pl/1769208300_1682970706.jpg
    To apply Thevenin's theorem, we need to follow these steps:
    1. Remove the 10 ohm resistor from the circuit.
    2. Calculate the Thevenin equivalent voltage (Vth) across the open terminals.
    3. Calculate the Thevenin equivalent resistance (Rth) seen from the open terminals.
    4. Reconnect the 10 ohm resistor and use Ohm's law to find the voltage and current across it.
    First, let me analyze the given circuit to find Vth and Rth.
    Vth: Since the circuit is simple, Vth can be found directly by applying the voltage divider rule:
    Vth = Vs * (R2 / (R1 + R2)) = 12V * (4 ohms / (6 ohms + 4 ohms)) = 12V * (4 / 10) = 4.8V
    Rth: The equivalent Thevenin resistance is the parallel combination of R1 and R2:
    Rth = (R1 * R2) / (R1 + R2) = (6 ohms * 4 ohms) / (6 ohms + 4 ohms) = 24 / 10 = 2.4 ohms
    Now, reconnect the 10 ohm resistor (R_Load) to the Thevenin equivalent circuit. To find the voltage drop across the 10 ohm resistor (V_Load) and the current through it (I_Load), we can use Ohm's law:
    I_Load = Vth / (Rth + R_Load) = 4.8 V / (2.4 ohms + 10 ohms) = 4.8 V / 12.4 ohms ≈ 0.387 A
    V_Load = I_Load * R_Load = 0.387 A * 10 ohms ≈ 3.87 V
    So the voltage drop across the 10 ohm resistor is approximately 3.87 V, and the current through it is approximately 0.387 A.
  • #3 20563898
    CYRUS2
    Help: 1241
    Rate: 3535
    From what is on the left side of R = 10 ohms, make one voltage source + one resistor.
