Step-by-Step Guide: Calculating Current & Voltage Across R2 in Electrical Circuits (Image Included)
jomiskin13 23850 5
  • #1 12348082
    jomiskin13
    Hello, can someone explain to me step by step how to solve this type of circuits? and especially how to calculate the current and voltage across R2
    Please help as soon as possible.
  • #2 12348268
    sebastiane94
    Rate: 9
    1. Calculate the equivalent resistance "Rz23" for R2 and R3
    2. Calculate the equivalent resistance "Rz" for R1 and Rz23
    3. Calculate the total current flowing in the circuit from Ohm's law. You use the formula I = E / (Rz + Rw).
    4. Calculate the voltage across the resistors using the formula U = R * I. The voltage across R2 is equal to the difference of the emf with the sum of the potential drops across Rw and R1 (UR2 = E - (UR1 + URw).
    5. The current through IR2 and IR3 is not equal to IR1!! It should be calculated from the voltage that prevails on these resistances (from the relationship of voltages in parallel connection).
    Ad.1
    1/Rz23 = 1/3 + 1/6 = 2/6 + 1/6 = 3/6
    Rz23 = 6/3 = 2 ohms
    Ad.2
    Rz = 1.5 + 2 = 3.5 ohms
    Ad.3
    I = 12 / (3.5 + 0.5) = 12/4 = 3A
    Ad.4
    U = R * I
    URw = 0.5 * 3 = 1.5V
    UR1 = 1.5 * 3 = 4.5V
    UR2 = UR3 = 12 - (1.5+4.5) = 6V
    Ad.5
    I = U / R
    IR2=6/3=2A
    IR3 = 6 / 6 = 1A
  • #3 12348291
    bryku13
    Help: 5
    Rate: 15
    equation for Kirchhoff's law 1:
    I1-I2-I3=0
    equations for Kirchhoff's 2nd law:
    E-I1*Rw-I1*R1-I2*R2=0
    U2=I2*R2=I3*R3, i.e. the voltages on resistors R2 and R3 are equal because they are connected in parallel, this is the end of electrical engineering and mathematics remains
    you can find the same examples here:
    http://www.mbmaster.pl/elektrotechnika-zadania.html
  • #4 12348303
    jomiskin13
    Thanks especially for point 3. :) it turned out that for UR2 U = 8V and what about R3, after all, cannot be equal to 0? Thanks again.
  • #5 12348354
    sebastiane94
    Rate: 9
    I gave the results and calculation method in my first post.
  • #6 12348559
    Quarz
    Help: 1646
    Rate: 629
    Ad.1
    Rz23 = 6/3 = 2 ohms
    Ad.2
    Ad.3
    Ad.4
    U = R * I
    Ad.5
    I = U / R
    IR2=6/3=2A
    IR3 = 6 / 6 = 1A
    Incorrect entries - the scheme in question contains general designations of elements, so you should write down the general formula first, and then substituting numerical values into the formula.
    However, the numerical formulas presented here are not unambiguous, especially when more than one element of the circuit has the same numerical value of the parameter.
    Besides, this post breaks the rules and accepted rules of this forum - we do not solve school/academic tasks here for anyone.
