Understanding the Use of Offset Pin in MAX40660 Transimpedance Amplifier
aescuela 969 1
  • #1 20733818
    aescuela
    what is the offset pin of the MAX40660 transimpedance used for?
  • #2 20733898
    Carolecooper
    aescuela wrote:
    What is the offset pin of the MAX40660 transimpedance used for? mcdvoice
    The offset pin in the MAX40660 transimpedance amplifier is used to compensate for input offset voltage. By applying an external voltage to this pin, users can nullify the offset voltage generated by the amplifier, ensuring accurate signal acquisition in photodiode and optical receiver applications.
