Aqara review - sensors, switches and sockets for the smart home
(Sponsored) magic9 3609 5
  • With the popularisation of Smart Home solutions, selecting the right devices is of paramount importance. Aqara presented a range of low-cost and high-performance gadgets that will fill every nook and cranny and meet every smart home need. It is worth mentioning that Aqara is a long-standing brand solutions partner Xiaomi Mi in the US market.
    Currently, the Aqara brand is owned by the company Lumi Technology and has recently become very popular in Europe. Actually, it has all happened through the shops Amazon and through partnerships with Apple . At the moment, Aqara offers a wide range of devices, from motion sensors and indoor cameras to smart switches. Importantly, all products work with Apple HomeKit, Amazon Alexa and Google Home .
    The Aqara system communicates between individual smart home devices using the standard ZigBee . This is a specification for data transmission protocols in mesh, cluster tree wireless networks. Networks based on ZigBee are characterised primarily by low power consumption, low bit rates (up to 250kbps) and ranges between individual nodes of up to 100 metres.
    Aqara is a very rapidly growing ecosystem with a large product portfolio, which currently includes:
    - Smart Home Central Unit ( Hub M1S Gen2 , Hub MS2 , Hub E1 )
    - Switches and sockets ( Smart Wall Switch H1 Double Rocker , Smart Wall Switch H1 Single Rocker , Smart Plug )
    - Sensors ( Motion Sensor P1 , . Door and Window Sensor , Temperature and Humidity Sensor , Water Leak Sensor , Vibration Sensor , TVOC Air Quality Monitor )
    - Indoor Cameras ( Camera Hub G2H , Camera Hub G2H Pro , Camera Hub G3 )
    - Roller Shade Controller ( Roller Shade Controller , Roller Shade Driver E1 )
    - Remote Control ( Cube T1 Pro , Wireless Mini Switch , Wireless Remote Switch Double Rocker , Wireless Remote Switch Single Rocker, Wireless Remote Switch H1 Double Rocker)
    Read our review and learn more about the Aqara smart home system .
    Aqara HUB - control centre
    The heart (control centre) of the entire Aqara ecosystem is the central HUB . This is an essential device, as the other Aqara accessories will connect to it and automation and interaction can be performed. At the moment, the Hub function is performed by the following devices:
    - Aqara System Control Center
    - Up to 128 Aqara devices can be connected to the HUB-.a up to 128 Aqara Zigbee devices can be connected
    - The HUB connects compatible Aqara devices to Apple HomeKit, Amazon Alexa, Google Assistant, Google Assistant, Yandex Alisa and more.
    - When paired with Aqara sensors, an audible alarm or night light can be activated.
    - Includes 18 LEDs for adjustable light colour and brightness.
    - The most advanced and future-proof smart home HUB.
    - Up to 128 Aqara Zigbee devices can be connected to the HUB (gateway)
    - Multi-protocol gateway (Zigbee 3.0, IR, BLE) for maximum compatibility
    - Connects compatible Aqara devices with HomeKit, Alexa, Google Assistant, Yandex Alisa and more
    - Can control infrared-compatible devices such as air conditioners, TVs, heaters, lights etc. And can integrate them with smart home automation.
    [/url] Aqara review - sensors, switches and sockets for the smart home
    - Smallest smart home gateway
    - Supports both classic, as well as the latest Aqara devices
    - Supports up to 128 ZigBee devices
    - Compatible with popular ecosystems like Home Kit, Google, IFTTT etc.
    - HomeKit camera with HUB/gateway function
    - Face recognition, 10-day iCloud storage at no extra charge
    - 140° wide-angle lens with 1080p Full HD sensor and IR Night Vision
    - Camera also functions as a Zigbee gateway (hub) and connects Aqara Zigbee devices to HomeKit
    - Two-way audio with HomeKit support and one-click video messaging.
    - High-end camera with gesture detection and face recognition - The most powerful HUB / Zigbee smart home 3.0
    - Control of infrared devices
    Aqara - switches, sensors, sockets
    Of course, in order to make our ecosystem coherent and functional, we need to arm our home with all sorts of sensors, switches, sockets and other elements that help us automate processes. We connect all these elements, of course, to our HUB , which is the central control unit.
    - Water detection and home protection
    - When the water level reaches above 0,5 mm , an IP67 certified water sensor with this
    - Sensor will activate the gate, which will trigger an alarm and send a notification to the user's phone
    - Detects motion at a distance
    - Captures motion and Detects unauthorised entry
    - - Detects unauthorised entry - Automatically turns the lighting on/off depending on the presence in the room
    - Detects brightness in the room
    - Detects vibration, tilt and fall - When placed on a window or door, sensor notifies you of a knock on the door or a break-in through the window .
    - It can also be placed with your valuables and send notifications, when an object has been moved
    - Detects real-time status of door or window opening
    - Detects - Detects real-time status of door or window opening. Unauthorised opening of doors and windows
    - Turns on/off lights , fan or curtains when window or door is open
    - Compact and robust, Easy to install and set up
    - Monitors temperature, humidity and atmospheric pressure in real time
    - Precisely monitors temperature , humidity and air pressure in each room
    - Automatically turns on the fan or humidifier , when the temperature reaches a certain threshold
    - Small and functional air quality sensor
    - Measures the level of total volatile organic compound (TVOC)
    - Energy efficient E-ink shows temperature, humidity and TVOC levels along with an air quality rating.
    - Can run extractor fans, air purifiers and open windows with Aqara controls,
    - One cube, that controls everything
    - Up to 6 different ways to manually control the smart home
    - Each action can be customised to control a different smart home accessory or scene.
    - Controls smart accessories via one button -. Up to 3 different ways to manually control the smart home with a single press, double press or long press
    - Can function as a doorbell, light switch and controller to control various home appliances
    - Works with wall switch Aqara H1 EU , making the configuration of the 3-way switch.way - Controls a single accessory or group of smart accessories with one touch
    - Each button supports up to 3 different ways to manually control the smart home: single press, double press or long press
    - Connects directly to Zigbee controller 3.0 Aqara and will work even if the gateway is not available.
    - Flexible installation options and full smart home automation support.
    - Zigbee 3.0: the latest, most stable and energy-efficient smart home technology
    - Compatible with HomeKit, Alexa, Google Assistant, Yandex Alisa and others
    - Fits in almost any wall box
    - Controls home appliances from anywhere via smartphone
    - Sets the on/off schedule for home appliances.
    - Monitors energy consumption by appliances.
    - To control devices, ask Siri, Alexa or Google Assistant.
    - Open and close the curtains with a smartphone, cube controller or wireless switch
    - Opening/closing of the curtains using j one button.
    - Adjust the curtains with your voice
    - Possibility to automatically adjust the curtain opening. Automatic adjust curtain opening depending on external lighting using dimmer function.
    - Easiest to install and most flexible roller shutter controller
    - Compatible with the most popular ecosystems and voice assistants: HomeKit, Alexa, Google, IFTTT, Alice
    - Most bead-link roller shutters are supported thanks to the many included adapters. - Simply screw the unit to the wall, insert the adapter, insert the roller shutter's bead string and the device is ready to be connected
    News in 2023
    Aqara is developing its portfolio very rapidly. In 2023, there are some very interesting new products that will find practical application in our smart homes. The new products include:
    - Presence sensor -. Aqara Presence Sensor FP2 - Videophone, doorbell -
    - Aqara Smart Video Dorbell G4 - LED strip -. Aqara LED Strip T1 Basic 2m - LED Extension Cord -. Aqara LED Strip T1 Extension 1m - Termostat - Aqara Radiator Thermostat E1
    Summary and conclusions
    It must be said, that Aqara devices are a very interesting solution for building an entire Smart Home ecosystem. First of all, they are inexpensive and we have a whole range of different products at our disposal that form a coherent whole. Thanks to the mobile app, we can create advanced automation of individual devices and the only thing that limits us is our imagination. Aqara's Zigbee hubs with a growing number of compatible sensors and switches working with Alexa, HomeKit and Google is a must-have item for anyone serious about launching a smart home. The Aqara system offers a lot of great functionality for really little money. We invite you to buy!
    [ADVERTISEMENT COORDINATION].
magic9
Editor
magic9 wrote 1318 posts with rating 519, helped 20 times. Live in city Kielce. Been with us since 2010 year.
  • #2 20747153
    PitD
    Help: 431
    Rate: 237
    Everything is beautifully nice only there is one catch.
    Aqara devices do not work with any other gateway.
    You need to buy an Aqara gateway.
    I bought several Aquara sensors and they could not be paired with a normal ZigBee gateway.
    If anyone decides to go for this system, I would like to inform you that it is closed.
    Only Aqara devices work :( .
    Kuźnia Komputerowa
    Marsz.J.Piłsudskiego 17, Kraków, 31-110 | Company Website: https://www.kuznia.pl
  • #3 20751913
    Jack80dev
    Rate: 20
    PitD wrote:
    If anyone decides to go for this system I would like to inform you that it is closed. :( :(
    Well, that's lame.
  • #4 20760126
    tomek.ch
    Rate: 45
    Strange. I have several Aquara devices and they work for me with Home Assistant after z2m.
  • #5 20763869
    AlexRoss
    I can confirm, at my place they also go over Zigbee2MQTT. And I will say that I really like how the roller shutter controllers go. The battery lasts almost 2 months (with daily use), now and I sleep better myself, and the child does not wake up at night. And the sensors work properly. I have no reservations about this brand.
  • #6 20764046
    PitD
    Help: 431
    Rate: 237
    :arrow: tomek.ch
    :arrow: AlexRoss
    I was writing about a regular gateway, not MQTT.
    If you write that it works with MQTT, then OK.
    But with a regular ZigBee gateway it won't work.
    There is no way to pair the device.
    Kuźnia Komputerowa
