How can I identify a multimeter IC hidden under epoxy and find its exact part number and datasheet?
It is chip-on-board: the actual die sits under the black epoxy blob on the PCB, so the package/pins you see are on the board rather than on a normal IC body [#20875358] In this DT9205A-style meter, the hidden chip is likely an ICL7106 or a clone, and if it is damaged the multimeter is usually not worth repairing economically [#20876115] The replies also said that the exact variant can differ even for the same model, so you need the whole PCB, any markings or other ICs, and a count of the solder pads/pin pitch to match the correct board version [#20875358][#20877472]
>>20885182 @ElektrodaBot Our transistor is the M6-SMD or S9015. Similar to the DIp number I found Is it 2N5401? Can I replace?? Dip and SMS don't matter.
The S9015 is a PNP transistor, and it is often used in various electronic circuits. The 2N5401 is also a PNP transistor, but they're not necessarily direct replacements for each other, as there are some differences in the specifications that you need to consider. Let's compare their primary characteristics:
S9015 Transistor: - Configuration: PNP - Vceo (Collector-Emitter Voltage): -45V - Ic (Collector Current): -150mA - Ptot (Total Power Dissipation): 625mW - Hfe (DC Current Gain): 70-700 (varies by specific class of S9015)
2N5401 Transistor: - Configuration: PNP - Vceo (Collector-Emitter Voltage): -150V - Ic (Collector Current): -600mA - Ptot (Total Power Dissipation): 625mW - Hfe (DC Current Gain): 40-160
When considering a replacement, you should ensure that:
1. Vceo: The replacement transistor should have a similar or higher voltage rating. 2. Ic: The replacement should be able to handle at least the same amount of collector current. 3. Ptot: The power dissipation should be similar or higher. 4. Hfe: The DC current gain should be in a similar range to ensure the circuit operates as intended.
The 2N5401 has a higher voltage and current rating, which means it can withstand higher stresses in those areas. However, the current gain (Hfe) is different, which may affect the performance depending on how critical the gain is in your circuit.
In many general applications, the 2N5401 could be considered as an over-spec'd replacement for the S9015, as long as the pin configuration and the differences in gain do not pose a problem in the specific application.
If you are replacing a transistor in a sensitive circuit, such as an amplifier or a precise current source, matching the Hfe more closely would be important.
Regarding the packaging (DIP versus SMD), it's mechanically different, but electrically, as long as the specifications match and you can adapt the physical fitting, it would not matter. You would need to ensure that the pinout matches or is adapted correctly: for most PNP transistors, the pinout is EBC (Emitter, Base, Collector) from left to right when the flat side of the transistor is facing you and the pins are down. Always verify the pinout in the datasheet.
It is crucial to check the specific circuit and requirements before replacing a transistor, as other factors might need to be considered. If you're unsure, it might be helpful to seek further assistance or provide more details about the application.
(...) R1
Input o----R2----+----B|<----+ Q1
| | PNP
Vz C|
| E|
+---------+----o Common (Ground reference
Please don't understand the text you sent me. Draw the lines completely.
To make sure everything is clear, I'm going to describe the circuit again, but I'll make sure to use clear line by line text representation:
In this text representation:
1. `Vcc` is the positive supply voltage. 2. `R1` represents a resistor connected between `Vcc` and the base of the PNP transistor `Q1`. 3. `Input` is the point where you apply the voltage you want to measure or protect against. 4. `R2` is a resistor connected between the `Input` terminal and the base of the PNP transistor `Q1`. 5. `Vz` symbolizes the Zener diode connected with its cathode to the base of the PNP transistor and its anode to the common ground. 6. `Q1` stands for the PNP transistor with its base connected to the Zener diode, its emitter connected to `Vcc`, and its collector connected to the common ground. 7. The common ground is shown at the bottom, connected to the collector of the PNP transistor and the anode of the Zener diode.
I hope this helps clarify the circuit for you! If you have any further questions or need more assistance, feel free to ask.
[پسوند] ۲۰۸۸۵۲۰۴[/پسوند]
@ElektrodaBot I want a replacement for the multimeter. The most likely part of the protection is the input voltage of the feed. After I plugged the multimeter into the adapter and it turned on for a few minutes, then it turned off and stopped running.
The multimeter only works on battery and does not have an adapter jack. If it works، I'll buy an S9015 transistor. What do you think?
Given your description, it seems like you are dealing with a multimeter that was damaged due to an incorrect voltage being applied. When multimeters are designed to operate only on battery power and do not have an adapter jack, they are not typically intended to be connected to an external power supply and may not have the protection circuitry to handle higher or incorrect voltages.
If the multimeter was functioning properly on battery power before it was connected to an adapter and turned off a few minutes after being powered by the adapter, it is very likely that an overvoltage condition has damaged one or more components within the multimeter. This could be the S9015 transistor if it is part of the input protection circuit, but there is also a chance that other components have been damaged as well.
Here are the steps you should consider for troubleshooting and repair:
1. Identify the Faulty Component(s): Before replacing any parts, you need to identify which component(s) have failed. Use a good multimeter to check for short circuits, open circuits, or components that show signs of physical damage such as scorch marks or melting.
2. Check Protection Components: Input protection in multimeters often includes components like fuses, diodes, resistors, and transistors. Make sure to check all of these components, as they could be part of the protection circuit and may have taken the brunt of the damage to protect more sensitive parts of the multimeter.
3. Consider a Direct Replacement: If the S9015 transistor is indeed the faulty part, and if it was originally used in your multimeter, you should replace it with the same type or an equivalent part if a direct replacement isn't available. The 2N5401, as previously discussed, could potentially work as a replacement due to its higher voltage and current ratings, provided that its hFE range is acceptable for the circuit's operation.
4. Assess Other Potential Damage: If the incorrect voltage was applied, it's possible that the problem isn't just with the protection components. There could also be damage to the measurement circuitry, the display, or other parts of the electronics. Carefully inspect all parts of the circuit board for damage.
5. Purchase the Replacement: If you are confident that the S9015 is the only component that needs replacing, and you have checked that the rest of the circuit is intact, purchasing an S9015 or a suitable equivalent would be the next step.
6. Replacement and Testing: Once you have the replacement transistor, solder it in place taking care to match the correct pinout. After replacing the component, test the multimeter with a known good battery, and check its basic functions to ensure it's working properly.
7. Consider Professional Repair: If you are not experienced with electronic repairs, especially with delicate test equipment like multimeters, it may be best to take it to a professional for repair. They will have the experience and equipment to diagnose and fix the problem without causing further damage.
Remember, safety is paramount when dealing with electronic repairs. If you are unsure about any of the steps or your ability to perform them safely, it is best to seek professional assistance.
Will be replaced by the S9015 one S8050 Used.؟ Can you use an NPN instead of a PNP?
The S8050 is an NPN transistor, which is not a direct replacement for the S9015, which is a PNP transistor. In most electronic circuits, NPN and PNP transistors cannot be directly swapped because they have different carrier flow and biasing characteristics.
Here are some reasons why you can't use an S8050 in place of an S9015:
1. Polarity: NPN transistors conduct when the base is more positive relative to the emitter, while PNP transistors conduct when the base is more negative. This means that the two types of transistors require opposite voltage polarities to operate.
2. Current Flow Direction: In NPN transistors, current flows from the collector to the emitter, while in PNP transistors, it flows from the emitter to the collector. This difference affects how the transistor is used in a circuit.
3. Biasing: The way you apply bias voltage to an NPN is different from a PNP. If you simply replace a PNP with an NPN without changing the circuit, the transistor will not be properly biased and the circuit will not function as intended.
If you need to find a replacement for a PNP transistor like the S9015, you should look for another PNP transistor with similar or better specifications. Here are some key specifications to match:
- Collector-Emitter Voltage (Vceo) - Collector Current (Ic) - Power Dissipation (Ptot) - DC Current Gain (hFE or β)
The S8050 is a commonly used NPN transistor, and although it's not a suitable replacement for the S9015, you may find a PNP counterpart like the S8550, which could potentially be used as a substitute for the S9015, provided that the specifications are a good match for your application. However, always check the datasheets of both transistors to ensure suitability.
Before you decide on a replacement, could you provide more details about the circuit in which the transistor is used? This information might help in suggesting an appropriate replacement.
An artificial intelligence in Telegram App has introduced the equivalent of the S9015 transistor S8050.
The suggestion provided by the AI on the Telegram app appears to be incorrect. As I mentioned earlier, the S9015 is a PNP transistor and the S8050 is an NPN transistor. They are not equivalent and cannot be used interchangeably without modifying the circuit to account for the different polarity and operation.
It is important to remember that artificial intelligence, while useful, is not always accurate and should not be relied upon without verification, especially for technical details where precision is crucial.
To find an equivalent PNP transistor for the S9015, you should look for one with similar electrical characteristics, such as:
- Collector-Emitter Voltage (Vceo) - Collector Current (Ic) - Power Dissipation (Ptot) - DC Current Gain (Hfe)
You could consider transistors such as the 2N3906, 2N4403, or S8550 as potential PNP equivalents to the S9015. Always check the datasheets to ensure that the replacement transistor will meet the requirements of your specific circuit.
If you have access to the original circuit design or can trace out the components around the S9015, I could help you confirm whether an alternative PNP transistor would be suitable for your application.
Please name some S9015 equivalents. I'm looking for supplies. I can't go to the store now. Because it is night. I'll go tomorrow.
Certainly, if you are looking for equivalents to the S9015 PNP transistor, here are some potential substitutes that you could look for. However, please note that whether a substitute will work in your circuit depends on the specific requirements of your application, including voltage, current, gain, and power dissipation among others. Always check the datasheets to confirm compatibility with your needs.
Here are some general PNP transistor equivalents for the S9015:
1. 2N3906 2. 2N4403 3. BC327 4. BC558 5. S8550
Each of these transistors has its own specific ratings, so it is crucial to ensure that the chosen replacement meets or exceeds the ratings of the S9015 in the particular areas that are important for your circuit. The areas to match or consider include:
It's also good practice to check the pin configuration of any replacement transistor, as it may differ from the original S9015. Make sure the substitute you choose has a compatible pin layout or be prepared to adjust the circuit if necessary.
When you go to the store, bring the original transistor specifications or datasheet with you, if possible, to compare with potential replacements. If you’re in doubt, ask the store's technical support for help in choosing an equivalent transistor. They often have reference materials or databases that can help identify a suitable replacement based on the original component's specifications.
The discussion revolves around a multimeter identified as the DT9205A, which features an IC with three sides of 12 pins each. Users inquire about the functionality of the IC, which is suggested to be a chip-on-board design. The primary focus is on the analog-to-digital converter (ADC) functionality and the identification of the IC, with mentions of the ICL7106 chip. Users express difficulty in finding accurate datasheets due to variations in the multimeter's design, particularly concerning the rotary switch with differing numbers of contacts. The conversation also touches on troubleshooting, specifically regarding a PNP transistor (S9015) used for input protection, and the potential need for replacement components after the multimeter was damaged by incorrect voltage application. Suggestions for equivalent transistors are provided, including the 2N3906 and S8550, emphasizing the importance of matching specifications. AI summary based on the discussion. May contain errors.
TL;DR: این راهنما برای تعمیرکار DT9205A است که میخواهد آیسی زیر اپوکسی و ترانزیستور اطرافش را بفهمد. «این را chip-on-board میگویند» و نشانهی مهم، وجود ۳ ضلع با ۱۲ پد در تصویر است. نتیجهی thread این است که آیسی مرکزی معمولاً ICL7106 یا کلون آن است و تطبیق شماتیک باید با خود برد انجام شود، نه فقط نام مدل. [#20875358]
اهمیت موضوع: در DT9205A یک نام مدل میتواند به چند نسخهی برد اشاره کند، پس شمارش پدها، کنتاکتهای کلید و نوع ترانزیستور از خود شمارهی چاپشده مهمتر میشود.
گزینه
قطبیت
Vceo
Ic
نتیجه برای جایگزینی
S9015
PNP
-45V
-150mA
مرجع اصلی
2N5401
PNP
-150V
-600mA
از نظر نوع نزدیکتر است، ولی باید بهره و پایهبندی چک شود
S8050
NPN
جایگزین معتبر نیست
نکتهٔ کلیدی: اگر برد شما با شماتیکهای DT9205A اینترنتی فرق دارد، ابتدا نسخهی برد را از روی تعداد پدها و کنتاکتهای کلید چرخان تشخیص دهید. نام مدل بهتنهایی برای انتخاب دیتاشیت کافی نیست.
در پرسش اولیه، کاربر روی چیپ ۳ ضلع با ۱۲ پد و در ادامه دربارهی ساختار اتصال همان ناحیه سؤال کرد؛ همین الگو سرنخ اصلی برای تشخیص بستهبندی بدون قاب است. [#20875077]
یکی از پاسخهای فنی صریح گفت زیر «مادهٔ سیاه» معمولاً ICL7106 یا کلون آن قرار دارد و در صورت خرابی، تعمیر اقتصادی نیست. [#20876115]
کاربر گزارش کرد کلید چرخشی برد او ۷ زبانهٔ فلزی دارد، در حالی که شماتیکهای پیداشده فقط ۵ کنتاکت نشان میدهند؛ این اختلاف یعنی برد او نسخهای متفاوت است. [#20878317]
مقایسهای که در thread آمده: S9015 = PNP, -45V, -150mA, 625mW و 2N5401 = PNP, -150V, -600mA, 625mW؛ پس نوع قطبیت یکی است، اما مشخصات و بهره یکسان نیست. [#20885204]
سناریوی خرابی مهم این بود که مولتیمترِ فقط باتریخور برای چند دقیقه به آداپتور وصل شد، سپس خاموش شد و دیگر کار نکرد؛ این نشانهی آسیب احتمالی چند قطعه، نه فقط یک ترانزیستور، است. [#20885270]
1. چیپ-آن-برد چیست، و چرا یک مولتیمتر DT9205A از دایِ بدون پکیج زیر اپوکسی سیاه بهجای آیسی معمولی استفاده میکند؟
چیپ-آن-برد روشی است که در آن دایِ سیلیکونی مستقیم روی PCB نصب میشود و بعد با اپوکسی سیاه پوشانده میشود. "Chip-on-board یک روش مونتاژ است که دایِ بدون قاب را مستقیم روی برد مینشاند، اتصالها را با باندینگ انجام میدهد و برای کاهش فضا و هزینه معمولاً زیر تودهای از اپوکسی پنهان میشود." در این thread همین روش برای آیسی مرکزی DT9205A مطرح شد. نتیجهی عملی این است که شناسایی قطعه از روی ظاهر بسیار سخت میشود. [#20875358]
2. چگونه میتوانم آیسی زیر اپوکسی سیاه در یک مولتیمتر DT9205A را شناسایی کنم و دیتاشیت یا شماتیک درست را پیدا کنم؟
باید خود برد را تطبیق دهید، نه فقط نام DT9205A را. 1. از کل PCB و همهی مارکینگها عکس بگیرید. 2. تعداد پدهای لحیمی آیسی و کنتاکتهای کلید چرخان را بشمارید. 3. شماتیکی را انتخاب کنید که همین الگوها را تکرار کند. در thread گفته شد با اطلاعات اولیه تقریباً نمیشود فهمید آیسی دقیقاً چیست، و بعداً هم اختلاف بین شماتیکهای آنلاین تأیید شد. [#20875358]
3. چرا آیسی مولتیمتر طوری دیده میشود که انگار روی شش ضلع پایه دارد، و این پدهای باندینگِ قابلمشاهده چه نسبتی با اتصالهای واقعی چیپ دارند؟
آنچه میبینید خود پایههای پکیج نیست، بلکه پدهای اتصال روی برد برای باندینگ دای است. کاربر از الگویی با ۱۲ پد در چند ضلع حرف زد و همین ظاهر باعث سردرگمی شد. در مونتاژ chip-on-board، دای بدون قاب روی برد مینشیند و سیمهای باندینگ به پدهای پیرامونی وصل میشوند؛ بنابراین ظاهر میتواند شبیه «چند ضلع پایهدار» باشد، حتی وقتی آیسی پکیج معمولی ندارد. [#20875077]
4. ICL7106 چیست، و چگونه بهعنوان مبدل آنالوگبهدیجیتال در مولتیمترهای دیجیتال مثل DT9205A استفاده میشود؟
در این thread، ICL7106 بهعنوان چیپ محتمل زیر اپوکسی و مبدل آنالوگبهدیجیتال مولتیمتر معرفی شد. "ICL7106 یک مدار مجتمع ADC است که ورودی آنالوگ را برای مولتیمتر دیجیتال به نمایش قابلخواندن تبدیل میکند، و در این خانواده از بردها معمولاً زیر اپوکسی یا در قالب کلون بهکار میرود." یکی از پاسخها گفت اگر همین چیپ خراب شده باشد، تعمیر دستگاه عملاً بهصرفه نیست و خرید مولتیمتر جدید منطقیتر است. [#20876115]
5. وقتی دیتاشیتهای آنلاین برای یک مدل DT9205A یکسان، همگی متفاوت بهنظر میرسند، چگونه تشخیص دهم کدام شماتیک با برد من مطابقت دارد؟
شماتیکی درست است که با سختافزار واقعی شما یکی باشد. در thread کاربر گفت سه شماتیک DT9205A پیدا کرده، اما همه با مولتیمتر او فرق دارند. پاسخها تأکید کردند باید تعداد پدهای آیسی، آرایش کلید چرخان، و اجزای اطراف را با برد خود مقایسه کنید. اگر این سه مورد نخورد، نام مدل یکسان ارزش تشخیصی کافی ندارد. [#20877073]
6. چرا ممکن است یک کلید چرخشی DT9205A هفت کنتاکت فلزی داشته باشد، در حالی که شماتیکهای دیگر فقط پنج کنتاکت نشان میدهند، و این برای یافتن نسخهی درست برد چه معنایی دارد؟
این اختلاف یعنی بردها یکسان نیستند. کاربر صریحاً گفت کلید چرخشی او ۷ زبانهٔ فلزی دارد، اما شماتیکهای پیداشده ۵ کنتاکت نشان میدهند. این تفاوت فقط جزئی نیست؛ معمولاً نشان میدهد نسخهی PCB، مسیرها یا منطق انتخاب رنج تغییر کرده است. پس شماتیکی که ۵ کنتاکت دارد، برای برد ۷ کنتاکته مرجع مطمئنی نیست. [#20878317]
7. چگونه با شمردن پدهای لحیمی PCB، کنتاکتهای کلید چرخشی و دیگر ویژگیهای برد، برای دیتاشیت مولتیمتر جستوجو کنم؟
باید جستوجو را با ویژگیهای فیزیکی برد بسازید. 1. مدل را همراه تعداد پدها و تعداد کنتاکتهای کلید یادداشت کنید. 2. این دادهها را با عکس بردِ پشت و رو کنار هم بگذارید. 3. در انجمنها یا بایگانیها همان ترکیب را جستوجو کنید. در thread حتی توصیه شد اول تعداد پدهای لحیمی سیستم شمرده شود، چون اندازه، گام و حتی پایهبندی میتواند با QFP44 هم نخواند. [#20877472]
8. یک ترانزیستور PNP با مارک M6 یا S9015 معمولاً در یک مولتیمتر چه نقشی دارد، مثلاً حفاظت ورودی، سوئیچینگ تغذیه یا کنترل رنج؟
در این thread بیشترین حدس روی نقش حفاظتی یا سوئیچینگ داخلی بود، نه روی بخش اندازهگیری اصلی. پاسخهای فنی چند نقش را مطرح کردند: حفاظت ورودی، سوییچینگ رنج، پردازش سیگنال و رگولاسیون تغذیه. بعدتر خود کاربر هم گفت احتمال میدهد این قطعه در بخش حفاظت ورودی تغذیه باشد، چون دستگاه پس از اتصال اشتباه آداپتور از کار افتاد. بدون شماتیک دقیق، نقش نهایی فقط با دنبالکردن مسیرهای برد مشخص میشود. [#20877508]
9. چگونه یک ترانزیستور PNP از نوع S9015 یا M6 را با مولتیمتر در حالت تست دیود آزمایش کنم تا بفهمم اتصالکوتاه شده یا باز است؟
بهترین روش، تست خارج از مدار در حالت diode است. 1. ترانزیستور را از برد خارج کنید. 2. بین بیس-امیتر و بیس-کلکتور در جهت درست افت دیودی بگیرید. 3. در جهت برعکس باید مدار باز باشد. در thread تأکید شد اگر هر دو جهت رسانا باشند، قطعه معیوب است؛ اگر هر دو جهت قطع باشند نیز ترانزیستور سالم نیست. این روش از تداخل قطعات اطراف جلوگیری میکند. [#20877113]
10. وقتی یک ترانزیستور PNP در تست دیود بین کلکتور و امیتر رسانایی نشان میدهد، این دقیقاً چه معنایی دارد و از کجا بفهمم نشانهی خرابی است؟
اگر بین کلکتور و امیتر در هر دو جهت هدایت ببینید، خرابی محتملترین نتیجه است. در پاسخ thread گفته شد برای یک PNP سالم، یک جهت باید افت دیودی نشان دهد و جهت معکوس باید OL یا قطع باشد. اگر هر دو جهت عدد مشابه بدهند، اتصالکوتاه داخلی محتمل است. اگر هیچ جهتی هدایت ندهد نیز خرابی از نوع بازشدگی مطرح میشود. [#20877113]
11. کدام ترانزیستورهای جایگزین به S9015 برای تعمیر مولتیمتر نزدیکترند، و هنگام انتخاب معادل کدام مشخصات بیشترین اهمیت را دارند؟
نزدیکترین جایگزینها باید PNP باشند و پایهبندیشان هم بررسی شود. در thread این گزینهها مطرح شدند: 2N3906، 2N4403، BC327، BC558 و S8550. معیارهای مهم نیز روشن گفته شد: Vceo، جریان کلکتور، توان تلفاتی، hFE و چیدمان پایهها. اگر قطبیت اشتباه باشد یا پایهها نخواند، حتی ترانزیستور با ولتاژ بالاتر هم میتواند مدار را از کار بیندازد. [#20885345]
12. بین S9015 و 2N5401 و BC327 و 2N3906، برای یک ترانزیستور آسیبدیده در مولتیمتر DT9205A کدام جایگزین منطقیتر است؟
در این thread، 2N5401 از نظر نوع قطبیت از S8050 منطقیتر است، چون هر دو PNP هستند. اما پاسخ فنی صریح گفت 2N5401 لزوماً جایگزین مستقیم نیست، چون بهرهی DC آن با S9015 فرق دارد. اعداد مقایسهشده این بودند: S9015 با -45V، -150mA، 625mW و 2N5401 با -150V، -600mA، 625mW. بنابراین اولویت عملی این است: همان S9015 یا PNP نزدیکتر با پایهبندی درست. [#20885204]
13. چرا S8050 جایگزین معتبری برای S9015 نیست، و در این تعمیر چه تفاوتهای عملی بین ترانزیستورهای NPN و PNP مهماند؟
چون S8050 از نوع NPN است و S9015 از نوع PNP. در thread روشن گفته شد این دو بدون تغییر مدار جای هم کار نمیکنند. تفاوت عملی مهم این است که بایاس، جهت جریان و قطبیت فرمان در NPN و PNP برعکس است. حتی یک هوش مصنوعی دیگر S8050 را معادل معرفی کرده بود، اما همانجا این پیشنهاد رد شد. [#20885320]
14. هنگام مقایسهی ترانزیستور اصلی با جایگزین، مقادیر دیتاشیتی PNP مثل VBE و VCE و علامتهای قطبیت را چگونه تفسیر کنم؟
علامت منفی در PNP معمولاً جهت مرجع ولتاژ را نشان میدهد، نه «بدتر بودن» قطعه را. در thread توضیح داده شد Vbe برای روشنشدن PNP معمولاً حدود -0.7V است و اگر Vce قطعهی اصلی -50V باشد، جایگزین با تحمل بیشتر میتواند از نظر ولتاژ مناسب باشد. همچنین گفته شد قطعهای با -150V میتواند بهجای -50V از نظر تحمل ولتاژ قابلقبول باشد، ولی باید بهره و جریان هم چک شوند. [#20885182]
15. وقتی یک مولتیمتر DT9205A باتریخور بهاشتباه با آداپتور تغذیه شده و حالا دیگر روشن نمیشود، امنترین مسیر عیبیابی چیست؟
امنترین مسیر این است که ابتدا خرابی چندبخشی را فرض کنید، نه فقط خرابی یک ترانزیستور. 1. با باتری سالم تست کنید و مسیر تغذیه را دنبال کنید. 2. فیوزها، دیودها، مقاومتها و ترانزیستورهای حفاظتی را اندازه بگیرید. 3. فقط بعد از جداسازی قطعه، جایگزین بخرید. در thread کاربر گفت دستگاه چند دقیقه بعد از اتصال آداپتور خاموش شد و پاسخ فنی هشدار داد که ممکن است علاوه بر S9015، بخشهای دیگری هم آسیب دیده باشند. [#20885273]
