Connecting Multiple Modems to One Internet Contract in a Multi-Room Flat
mykolavlasov11 1134 5
  • Single contract with mesh or wired access points
    #1 20907489
    mykolavlasov11
    Hi.
    I have a few rooms in my flat, but I can only put a Wi-Fi router in rooms A and B. However, rooms A and B are in different parts of the flat and separated by several walls, so if I put a router in one of them, the other one will get a slow/unstable connection.
    One of the options is to sign 2 contracts with different internet providers.
    However, I don't want to pay twice and was thinking about whether it's possible to sign a contract with 1 provider but buy an additional modem or something similar.
    I'm in Warsaw and don't have any contract with an internet provider right now, open to possible options.
    Thanks
  • #3 20909848
    IC_Current
    Help: 1499
    Rate: 2521
    sosarek wrote:
    Lay wires to the other devices.
    And at the end of these wires, in a room with poor coverage simply install an additional access point.
  • #4 20909908
    jprzedworski
    Help: 758
    Rate: 828
    It is impossible to connect two modems on one link. Technically impossible. Not to say that a little cable and an access point (as above) will probably come out cheaper.
  • #5 20909997
    mykolavlasov11
    >>20908788
    W tym przypadku musiałbym przeciągnąć go po całym mieszkaniu, czego chciałbym uniknąć.
  • #6 20912346
    sebap
    Help: 538
    Rate: 1082
    You'll probably spend a bunch of money on some meshes or, God forbid, repeaters and you'll still end up convinced to go with cable
