Connecting EV1909-TL-00A Gate Driver with F4-15MR12W2M1_B76 MOSFET Module: Schematic Guidance
mumrtahir 681 0
  • Request for EV1909-TL-00A to F4-15MR12W2M1_B76 wiring schematic
    #1 20973148
    mumrtahir
    Hi, I have the following gate driver module (EV1909-TL-00A) and MOSFET power module (F4-15MR12W2M1_B76). I need guidance on how to connect them and the connection schematic to drive the full bridge power module. The links to the datasheets are the following (I am also attaching the files):
    https://www.infineon.com/dgdl/Infineon-F4-15M...N.pdf?fileId=5546d4627956d53f01797a3e06e651f5
    and
    https://www.monolithicpower.com/en/documentvi.../lang/en/sku/EV1909-TL-00A/document_id/11022/
    I have a heat sink and will install both (the power module and gate driver board) on the heatsink. If you will provide me with a schematic and connection guidance to drive that module, I will highly thankful to you.
    Best Regards:
    Umar
    • Driver board.pdf (922.67 KB) You must be logged in to download this attachment.
    • Power module.pdf (637.43 KB) You must be logged in to download this attachment.
