  • #1 2050796
    banem
    Hi
    I recently bought my first meter, the cheapest one for PLN 20 and I don't understand only one function. At the bottom left there is a function called hFE and there is a socket for it marked BC E. I know it has something to do with transistors, but what? This is my first post on this forum so please be patient.
    xHaKeReK
    Help: 33
    Rate: 55
    HFE is a measurement of transistor gain. The meter applies a constant voltage to the base, say 10mV, and to the emitter a higher voltage, say 10V, and measures the collector voltage. HFE is the gain, i.e. the number of times the collector voltage is greater than the control voltage at the base. I hope you understood :D
    dee jay G
    Help: 71
    Rate: 41
    If I'm not mistaken, hFE is the gain factor (beta) of the transistor (sounds scary, doesn't it?).
    At least that's what I was told, a long, long time ago, and then I wasn't interested in it and never used it, so I'm not sure. This is probably used to "pair" transistors.
    Regards
    Luke.
    PS: I've been in this for so long and I don't know 100% what it is... Shame Mr. dee jay G, shame.
  • #4 2050836
    banem
    So if it is 10mV base and 10V emitter then this gain will be 1000?
    Pi-Vo
    Level 37  
    Help: 319
    Rate: 207
    This is the current gain of the transistor. It is the ratio of the collector current to the base current and determines the current gain of the transistor. If, for example, 1mA flows through the base to the emitter and 1A through the collector, the hFE is 1000. Do not mix this voltage! A bipolar transistor is an amplifying element current controlled! unlike lamps and field effect transistors which are voltage controlled.
  • #6 2050877
    banem
    Thank you very much, now everything is clear (I think :P I just need to read up on the theory now. This forum is just great, a few minutes and I got help :D Too bad I got here so late.
  • #7 2050954
    xHaKeReK
    Help: 33
    Rate: 55
    Sorry about the tension :( but i got it :P
The hFE parameter, also known as the current gain or beta of a transistor, measures the ratio of collector current to base current. It indicates how much the transistor amplifies the input signal. For example, if 1mA flows through the base and 1A through the collector, the hFE would be 1000. The measurement is performed using a multimeter that applies a constant voltage to the base and emitter, allowing users to determine the transistor's gain. Understanding hFE is essential for pairing transistors in electronic circuits.
