how can this circuit be adjusted to operate smoothly and correctly, the transistor hfe is 165
276 15
How can I adjust this transistor amplifier so it operates smoothly and correctly with an hFE of 165?
Reduce the collector resistor and tame the emitter bypassing; with hFE 165 the transistor should still bias properly, but the original 3.9 kΩ collector load and fully bypassed 1 kΩ emitter resistor make the stage clip. [#21679130][#21679134] A good starting point is about 2.2 kΩ to 2.7 kΩ in the collector so the collector sits near half of the 12 V supply, around 6.5–7 V, instead of only about 3 V. [#21679130] To get a voltage gain of about 4, split the 1 kΩ emitter resistor and bypass only part of it, for example 560 Ω + 470 Ω with the capacitor across the 470 Ω, or 390 Ω + 620 Ω with a 22 µF cap, so the DC bias stays the same but the AC gain is controlled. [#21679134][#21679135] The 16 µF emitter capacitor has low impedance at 1 kHz, so it drives the AC gain far too high and can saturate the amplifier; without that full bypass the gain is roughly 3900/1000 ≈ 4. [#21679132][#21679141] If needed, use preferred values like 8.2 kΩ and 2.7 kΩ in the bias network, and add a DC path after the output capacitor so the output does not sit with a simulator offset. [#21679130][#21679141]
  • #1 21679129
    NYAME EPHRAIM MECHANE
  • Reduce collector resistor to center output swing
    #2 21679130
    David Ashton
  • #3 21679131
  • High gain from 16 µF emitter bypass capacitor
    #4 21679132
    Richard Gabric
  • #5 21679133
  • Emitter resistor split to set gain near 4
    #6 21679134
    David Ashton
  • Collector resistor reduced for better symmetry
    #7 21679135
    David Ashton
  • #8 21679136
  • Measured 100 mV input and 400 mV output without distortion
    #9 21679137
    David Ashton
  • #10 21679138
  • #11 21679139
  • #12 21679140
  • Emitter bypass capacitor raises AC gain and removes offset
    #13 21679141
    David Ashton
  • Request for gain 10 and open-loop gain adjustment
    #14 21679142
  • #15 21679143
  • #16 21679144
The discussion focuses on adjusting a transistor amplifier circuit with a transistor hFE of 165 to operate smoothly and achieve a target voltage gain of 4, with an AC input signal of 10 mV at 1 kHz and a 12 V supply. Key points include the impact of the emitter resistor (1 kΩ) and its interaction with the transistor's current gain, resulting in an emitter voltage around 2.3 V and collector voltage near 3 V. The original circuit's gain was excessively high (~260) due to the low impedance of a 16 µF capacitor across the emitter resistor at 1 kHz, causing saturation and distortion. Solutions involve removing or splitting the emitter bypass capacitor to tailor gain and frequency response, and adjusting collector and emitter resistor values. Simulation results suggest using a 1.8 kΩ collector resistor with a split emitter resistor (390 Ω and 620 Ω) and a 22 µF capacitor across part of the emitter resistor to achieve a gain near 4.3 without clipping. Further clarifications address DC offset issues caused by the output coupling capacitor and the need for a DC path to ground (e.g., a 100 kΩ resistor) to eliminate offset in real circuits. The user also inquires about achieving a gain of 10 with similar AC conditions and capacitor values (1 µF), indicating ongoing tuning and simulation efforts. The discussion emphasizes the trade-offs between gain, distortion, and frequency response in transistor amplifier design and the importance of component value selection and circuit simulation for optimization.
TL;DR: With hFE=165, bias for about 6.5–8 V at the collector and set AC gain using Rc/Re; “gain is (collector resistance / emitter resistance).” A fully bypassed emitter at 1 kHz can yield ≈260× gain and severe clipping. [Elektroda, Anonymous, post #21679141] Why it matters: This lets you fix clipping and hit target gains (×4 or ×10) without chasing transistor hFE variations.
How do I fix asymmetric clipping when hFE is 165?
Set the collector near mid-supply by reducing Rc. With IE≈2.3 mA, lowering Rc from 3.9 kΩ to ~2.2–2.7 kΩ centers the swing. This improves negative headroom while keeping positive peaks clean. Small changes to the base divider (2.7 kΩ/8.2 kΩ) use preferred values without shifting bias much. The approach is resilient to hFE because the base network dominates. “Aim to get a bit more than half the supply voltage at your collector.” [Elektroda, Anonymous, post #21679130]
Won’t changing Rc break my required gain?
Not if you decouple DC bias from AC gain. Split the emitter resistor and bypass only the lower portion with a capacitor. DC bias still sees the full emitter resistance, but AC gain becomes Rc divided by the unbypassed emitter resistance. This lets you retune Rc for symmetry and set gain independently. “Use a portion of [Re] to control the AC gain.” [Elektroda, Anonymous, post #21679134]
How do I get a clean gain of about 4 at 1 kHz?
Two options. Easiest: remove the emitter bypass capacitor so gain ≈ Rc/(Re+re′) ≈ 3.9 kΩ/1.01 kΩ ≈ 3.9. Cleaner headroom: use Rc≈1.8 kΩ, Re split as 390 Ω unbypassed and 620 Ω bypassed with 22 µF, giving ≈4.3× and ~8 Vpp before clipping. Add a small preset in Rc or the unbypassed Re to trim exactly to 4. [Elektroda, Anonymous, post #21679135]
How can I design for gain ≈10 at 1 kHz, 12 V supply?
Use the rule gain ≈ Rc/Re(ac). Keep the DC emitter resistance ~1 kΩ for the bias current, but make the unbypassed portion ≈Rc/10. Example: choose Rc=2.2 kΩ; set unbypassed Re≈220 Ω; bypass the remaining ~780 Ω with ~22 µF. Verify the collector sits near 6.5–8 V, then fine-tune with a trimmer in Rc or Re. “Gain is (collector resistance / emitter resistance).” [Elektroda, Anonymous, post #21679141]
What does “open gain” mean here, and why did it clip?
With the emitter fully bypassed, Re(ac) collapses to re′ plus the capacitor’s small impedance. At 1 kHz, 16 µF is ≈10 Ω, re′ ≈11 Ω, so Re(ac) ≈15 Ω. With Rc=3.9 kΩ, gain ≈3,900/15 ≈260×. That far exceeds the headroom of a 12 V stage, so the waveform clips hard. This is expected “open” (fully bypassed emitter) behavior without feedback. [Elektroda, Anonymous, post #21679134]
Why does my scope show a 3.3 V DC offset at the output in simulation?
Your coupling capacitor needs a DC path to ground on the output side. An ideal meter is infinite resistance, so the cap holds zero volts and the trace appears offset by the collector’s DC level (~3.1–3.3 V). Add a 100 kΩ load to ground, or use a realistic DVM (≈10 MΩ) to charge the cap and remove the false offset. [Elektroda, Anonymous, post #21679141]
How do I read gain from my scope traces correctly?
Use peak-to-peak values. Measure input Vpp and output Vpp on the same timebase and volts/div. Gain = Vout(pp)/Vin(pp). In the thread example, 0.1 Vpp in and 0.4 Vpp out give a gain of 4. Watch for DC offsets; use AC coupling on the scope if needed. “Your input is 100 mVpp, output about 400 mVpp, so you’re spot on.” [Elektroda, Anonymous, post #21679141]
What capacitor values make sense at 1 kHz for this stage?
For emitter bypass, ensure Xc is comparable to or lower than the intended Re(ac). At 1 kHz, 16 µF is ~10 Ω, which with re′ ≈11 Ω drives huge gain and clipping. Using 22 µF across only part of Re yields controlled gain and flat response. Preferred E12 values (e.g., 22 µF) simplify sourcing. [Elektroda, Anonymous, post #21679134]
How much does hFE=165 matter for bias and gain?
Very little here. The base divider current dominates because the emitter resistor reflects to the base as hFE×Re, which dwarfs the divider. The DC operating point is set mostly by the divider and emitter resistor. That’s why the design tolerates wide hFE spread without big bias shifts. This stabilizes both symmetry and small-signal gain. [Elektroda, Anonymous, post #21679130]
What input level can I use before clipping with the tuned ×4 build?
With Rc≈1.8 kΩ and a split emitter (390 Ω unbypassed, 620 Ω bypassed by 22 µF), you get about 8 Vpp output before clipping. That supports roughly 2 Vpp at the input for a ×4 gain target. “This gave me a gain in the region of 4.3 and an output around 8 Vpp before clipping.” [Elektroda, Anonymous, post #21679135]
Can I add a trimmer to dial in the exact gain?
Yes. Insert a small trimmer in series with the unbypassed emitter resistor or replace Rc with a preset. Adjust while monitoring collector DC (target ~6.5–8 V) and output Vpp. David suggests a 470 Ω preset for Re or a 2.2 kΩ preset for Rc to land exactly at ×4. [Elektroda, Anonymous, post #21679135]
Quick 3‑step: how do I set bias and gain without oscillations or clipping?
  1. Set the base divider for ~2.9 V at the base and confirm IE≈2.3 mA.
  2. Choose Rc so the collector sits near 6.5–8 V at 0 input.
  3. Split Re; bypass only the lower portion to get target gain Rc/Re(ac). [Elektroda, Anonymous, post #21679130]
