[Solved] What Does the ZD3 Marking Signify on Marshall Stanmore Speakers?
kolatrus08 1407 3
  • #1 21037386
    kolatrus08
    Electrical schematic with component labels, including ZD3 on a Marshall Stanmore amplifier. what is the marking of ZD3 on Marshall stanmore
    viayner
    Help: 1563
    Rate: 2047
    markings suggest me that they are shottkey diode, if they are really zener diode how they are connected looks a bit interesting.
    Pin 7 is a power supply here zener diode make sens, but scheme looks strange, ZD3 should be to base and resistro is between base nad collector. This diode should be <36V while this is the limit for the microchip.
    ZD1 make no sens, if this is zener diode it limit/reduce the potential on FB pin, but it not make sens while pin 1 is on GND. Shottkey diode seems more logical but are you sure about connection? My guess is to protect the transistor in optocoupler.
    D4 seems to be switching/fast diode.
    Regards
  • #4 21040304
    kolatrus08
    the problem was different
