  • Built a class A headphone amplifier with three blocks: symmetrical power supply, uPC1237HA headphone protection/delay, and stereo power stage.
  • The supply uses LM723 and LF357 to stabilize ±21V, while the power stage uses LME49860, 2SK170 BL JFETs, and medium-power transistors.
  • The amplifier runs at about 38mA per transistor at 21V, with 4 × 4700uF filter capacitors and current limiting set to 0.3A.
  • It delivers very high gain, low noise, and strong headphone protection, but the whole unit warms up heavily and the heatsink is too weak.
  • Hello
    I present my headphone amplifier, which, according to the author of the project, is to operate in class A.
    The amplifier consists of three blocks:
    1. Symmetrical power supply.
    2. Headphone protection / Headphone switch-on delay.
    3. Stereo power stage.
    The power supply is built around the LM723 (Motorola) chip and the LF357 fast operational amplifier. Both circuits control a pair of power transistors on which heat is deposited. Filter Capacitors: 4 X 4700uF. Power supply of the entire amplifier set to 2 X 21V PR with PR - very stable power supply. There is no difference between the magnitude of the positive and negative voltage - maybe a 10mV difference. Trafo 2 X 0.44A sealed, soldered in PCB. Everything is protected by fuses, power supply with current limitation set at 0.3A. For filtering the power supply behind the stabilizer, I used tantalum and MUSE series capacitors. I did not want to make the power supply on the LM317 and its negative counterpart. The power supply on the LM723 and the operational amplifier, which makes sure that the negative voltage follows the positive voltage, is in my opinion better.
    The protection circuit is an application of the NEC uPC1237HA chip. I started the circuit diagram with the kit from Advanced Electronic. The system delays turning on the headphones, disconnects them immediately after turning off the power, protects against DC component at the output, and protects against overload (clipping). The headphones are switched on with relays. The transistors cooperating with the circuit are low-noise. A failure / disconnection of the headphones is signaled by the LED diode. The parameters / protection time can be modified using discrete elements with the uPC1237 chip. A very good deal in my opinion.
    The power stage is based on a double operational amplifier and medium power transistors. The amplifier itself is the circuit presented in Elektora 10/93 (apparently it was originally described in the Dutch ELektuur, or the German Elektor). In my amplifier I used double operational amplifiers (two stages - pre-excitation and excitation stage in one circuit) LME49860 (by default they were NE5532), while in current sources I replaced BF256 transistors with newer 2Sk170 BL group (with increased Idss current compared to GR series). The author of the power level diagram mentioned about the 50mA quiescent current. I did not manage to achieve such a current - the current in my amplifier is about 38mA per transistor when powered by 21V (by the way, the magnitude of the supply voltage does not have much influence on the change of the Idss current). The 2SK BL group trnaistors have a higher current than the original BF256A. I reduced the resistors at the gates to 47ohm. I replaced the old BAY diodes with fast 1N-4151. The amplifier in idle state heats up strongly, the total quiescent current of both channels is not all 80mA. The system works with negative feedback. A power resistor is inserted on the output, which limits the gain and additionally protects (second protection) against short-circuit at the output. There is not a single capacitor in the amplifier circuit that would limit the frequency response. The appearance of the constant component is supervised by uPC1237. Paired JFET transistors - 0.5mA Idss difference, power transistors also paired - max 5% hFE gain difference. No output offset.
    The front panel has an ALPS potentiometer (it was supposed to be a DALLAS DS1802 digital potentiometer, but it turned out that it has a problem with transferring more amplitude), two JACK Neutrik 6.3mm sockets, two indicators - one indicating the operation of the protection, while the other signaling the power supply and the switch.
    The whole is complemented by metallized resistors - where I could I stuffed tantalum capacitors, and the company's ELNA, MUSE etc. , filter on the 230V power input (found in the cabinet, new), fuse sockets on the PCB (three in total) universal metal housing.
    I made the PCB in the ExpressPCB program - unfortunately, despite numerous organoleptic checks, I made a few mistakes - I had to make a few changes, bridges on the PCB during soldering. I didn't have a PCB pattern for any of the schematics - everything was designed by myself. The board is made by thermal transfer on a thick - 1mm PCB. The bottom of the plate is secured with a solution of rosin and denatured alcohol (hence a bit of dirt on the upper side of the plate). The amplifier contains quite a lot of elements and thin tracks - all connections had to be made carefully.
    I am positively surprised by the sound and sound quality of the amplifier. The amplifier sounds really beautiful. The gain is very high - you can limit it by lowering the sensitivity a bit (replacing one resistor). The whole thing took me a bit of work, but I am very happy with the amplifier. I generally tried to use good components. The stabilizer by MOTOROLA, an operational amplifier in a better class power supply, generally brand-name components.
    Advantages of the amplifier:
    - Enormous power - the amplifier will drive virtually any headphones
    - Very little distortion
    - Very nice sound
    - Relatively simple options for making changes: gain, sensitivity, power, bandwidth, sound.
    - Very good protection of the headphones - even in the event of burning the tips, failure of the power supply, clipping etc. the headphones will not be damaged
    - Very low amplifier noise
    - Everything is practically on one PCB
    Disadvantages:
    - Warming up of the whole
    - Pretty complicated layout
    - Lots of items
    Planned changes:
    - Replacing the potentiometer knob with one with a scale
    - Heatsink enlargement - The heat sink used in the power stage is too weak
    - Additional thermal protection of the power level
    Amplifier:
    Class A headphone amplifier
    Scheme of the power level and photos from the works:
    liseczq
    liseczq wrote 898 posts with rating 193, helped 13 times. Live in city Kraków. Been with us since 2005 year.
  • #2 19382126
    conisl
    Nice construction, well made. However, I have two comments:
    - the diagram in the output stage shows the complementary pair BD139-140, i.e. a push-pull amplifier in AB class,
    - there is a rule that in the lower position of the power switch the device is turned off, for you it is on.
  • Class AB op-amps and output resistor criticized
    #3 19382275
    Fimek
    Rate: 355
    I wouldn't say that it is a class A amplifier, if you don't know what is going on inside the op-amps - they generally work in class AB. Case two - what about the damping factor? There is a series resistor in the output, which worsens the damping of oscillations from the headphone diaphragms - this seems to be a workaround for the lack of short circuit protection, but this solution is a very compromise. In my opinion, this type of amplifier is a completely unnecessarily small radiator, while it could be energy-saving and still have cosmic parameters, if only it was based on, for example, OPA-134 or another amplifier dedicated to headphones (read designed to work with a low load impedance) e.g. MAX97220A.
    I'm not picking on aesthetics, because it's OK and you can see that you've put in a lot of work - this should be praised :)
    Greetings,
    Fimek
  • Op-amps are generally class AB, not class A
    #4 19382407
    popiol667
    Help: 6
    Rate: 140
    And this cannot be solved by taking the feedback signal after the resistor R4 and not before? (i.e. from the exit).
    I recommend PCB varnishes - Plastik 70, Urethan spray.
    The design is very nice, what are the dimensions of the housing?
    Class A is overrated, all the advantages listed by the author could be "hooked up" to the integrated, dedicated circuit working in class D.
    An interesting experience can be trying to connect a loudspeaker to this amplifier. The volume may surprise you :)
  • #5 19382451
    mycodename47
    Help: 15
    Rate: 55
    What is the power of trafo? It looks very small ...
  • 47 ohm output resistor can be removed
    #6 19382510
    liseczq
    Help: 13
    Rate: 193
    The transformer has 20W ... 10W per secondary winding (444 mA at over 20V per winding). Of course, if we connect a 4ohm loudspeaker, the power supply will turn out to be too weak, but this is an amplifier with parameters for headphones, not speakers (of course, it will support low-ohm headphones, but carefully with a potentiometer then).
    The 47 Ohm resistor given in the output series can be removed, even the PCB was prepared for connecting the jumper next to the resistor. This resistor is actually redundant, because uPC1237 watches over security
  • #7 19382651
    popiol667
    Help: 6
    Rate: 140
    You can try to loop through the 47 ohm resistor.
  • Quiescent current limited by JFET current sources
    #8 19382712
    tytka
    Help: 8
    Rate: 1841
    conisl wrote:
    this is a class AB push-pull amplifier
    I would suggest to my dear colleagues to think about what influences the class in which this amplifier works, and how it can be easily changed (because you can easily maneuver between class A and AB). :)
    This project seems to be years ago, it was published in "Radioelektronik".
    In my opinion, class D for headphones is more of a joke (unless on the phone).
    liseczq wrote:
    When idle, the amplifier heats up a lot, the total quiescent current is a little over 150mA.
    So how about this quiescent current?
    38mA per channel, and a total of just over 150mA? How many channels does this amplifier have?
    The quiescent current is due to the current sources on the Jfets that you changed and that's probably the reason you didn't get a higher value.
    The supply voltage does not affect the quiescent current because you have current sources.
  • Questioning the practical value of class A today
    #9 19382793
    Fimek
    Rate: 355
    E there, it seems to me that the D class can also sound well with headphones. However, there is a question why to do it - class D amplifiers have advantages in the form of high efficiency, say independent of the drive and low output impedance even in open loop, but they also have disadvantages. In an amplifier with mains supply, the advantages do not matter, but the disadvantages remain.
    However, upon reflection, I give my colleague the title right - the output current of either of the two operational amplifiers does not change (the first has practically no load, and the second works with a current source, i.e. high impedance), therefore it is indeed, even formally, class A.
    I have absolutely no conviction to the sense of class A. Maybe someone will enlighten me why use it nowadays?
    Greetings,
    Fimek
  • #10 19382885
    popiol667
    Help: 6
    Rate: 140
    In order to compare the systems, we use parameters, not feelings.
  • 38 mA per transistor at 21 V supply
    #11 19382891
    liseczq
    Help: 13
    Rate: 193
    It says in the topic that 38mA for one transistor, i.e. for the entire power amplifier (both channels), not all 80mA of quiescent current.
    2SK170BL have a higher current than the BF256A mentioned in the radiolectronics ...
  • #12 19383415
    M. S.
    Help: 259
    Rate: 680
    38mA per transistor
    Only that the same current also flows through the second transistor, so it cannot be said that a current twice as large flows together. As for the class of the amplifier, it is rather class AB, but the quiescent current is quite large in relation to the output current, so the power amplifier can work quite linearly.
  • #13 19383469
    liseczq
    Help: 13
    Rate: 193
    Yes - quiescent current per channel 38mA, let's round - 40mA quiescent current per channel. In my opinion, the amplifier sounds very well, the whole thing heats up very much
  • Questioning thermal stabilization and quiescent current drift
    #14 19383701
    kris8888
    Help: 537
    Rate: 1929
    What about temperature stabilization? Shouldn't these JFETs or serial diodes be somehow mounted on the heat sink together with the power transistors? At the moment, the only stabilization is provided by these ten ohm emitter resistors, the question is whether it is enough.
    Is the quiescent current stable and does not change when the transistors warm up?
    As for the aesthetics of workmanship, it is at a high level, but I just don't like the wraps made of yellow-green tape. Tights would be better. I would also change the input jack to two, standard cinch, somehow it suits me better as an input.
  • #15 19384083
    Janusz_kk
    Help: 228
    Rate: 1478
    liseczq wrote:
    the whole thing gets very hot
    Therefore, I would change the resistors in the sources of these fets from 100 to 200 or even to 300.
  • Reducing source resistors lowers quiescent current and heat
    #16 19384117
  • Diode junctions likely provide enough thermal stabilization
    #17 19384162
    kris8888
    Help: 537
    Rate: 1929
    acctr wrote:
    Sure it changes, but is it important when the system works in a negative feedback loop?
    Well, I don't see any temperature feedback here. But since the final transistors do not go up with smoke after some time, it means that the current eventually stops at some value and still does not increase by itself.
    Perhaps the temperature characteristics of the pn junctions of the diodes used in series between the bases of the transistors already provide sufficient temperature stabilization.
    Anyway, the transistors will not go up in smoke since the power supply has a current limit of 0.3A
  • Emitter current limited to 35 mA by 10 ohm resistors
    #18 19384181
  • 120 ohm source resistance is standard for headphone measurements
    #19 19384200
    romarcin
    Help: 34
    Rate: 82
    Fimek wrote:
    There is a series resistor at the output, which worsens the damping of oscillations from the headphone diaphragms
    there is a German standard DIN50332 (now European so EN) for the measurement conditions of headphones, which assumes that the headphones are powered from a signal source with a resistance of 120 Ohm! keyhole" :wink: in the amplifier, and there the signal is formed from resistor voltage divider !, apart from what "damping" here, the headphone diaphragm is some milligrams, these are not woofers!
  • Reducing quiescent current to cool the amplifier
    #20 19384216
    Janusz_kk
    Help: 228
    Rate: 1478
    acctr wrote:
    Either class A or cool transistors, you can't have both.
    but the author complains that:
    So you have to decide whether this heating bothers him or not.
    acctr wrote:
    Reducing this current will reduce the quiescent current in the emitter circuit and shift operation towards class B.
    But they still work in AB, depending on the quiescent current, only the 'depth' of this class changes.
    acctr wrote:
    And what would it do? In the circuit from the original diagram, a current of about 2.25mA flows through the source resistors.
    Not much, but then the drop on the diodes will decrease and the power amplifier will have a lower quiescent current, you can also put a potentiometer between the BD bases and reduce the quiescent current, which is simply too high for the headphone amp.
  • 2SK170 BL pair and 47 ohm set 40 mA bias
    #21 19384268
    liseczq
    Help: 13
    Rate: 193
    Increasing the resistor will reduce the quiescent current of the tip. The heating does not bother me - I'll add a little more cooling. So far, such a piece of sheet metal connected to the casing is hot after 15 minutes (the upper casing is pulled down, if it is on, it would probably fry) - it burns the pad (I note that I work a little physically) after a dozen or so seconds - you do not have to play hard in inches - it is now empty hot.
    Radiator:
    By default, the system was to include transistors: BF256A. BF256 transistors are grouped according to the Idss current. By default, the author used the BF256A in the system - they have a spread of 3 - 7 mA. This is the group with the least Idss
    I used 2SK170 from the BL group (they are grouped: GR, BL, V). BL is the middle group - 6-12mA dispersion. Mine are paired and have ~ 10mA (+/- 0.5mA). In addition, I reduced the resistor to 47ohm (100ohm by default) which should increase the current. I managed to reach ~ 40mA per channel. The current does not diverge - now my amplifier is hot and I have 780mV on emitter resistors. 780mV / 20ohm = 39mA.
    The amplifier played for a long time (up to two hours) and nothing got burnt. I note that the whole is powered by 42V (symmetrical 2 X 21V).
  • DS1802 should handle ±2 Vpp without issue
    #22 19385175
    tytka
    Help: 8
    Rate: 1841
    liseczq wrote:
    that is, for the entire power amplifier (both channels), not all 80mA of quiescent current.
    And yet. So where did the previous over 150 mA come from?
    You indicated the reason here:
    In the project from the magazine, the amplifier is powered with a voltage of +/- 15V, i.e. with a quiescent current of 40 mA, the heat sink heating goes to 1.2 W per channel, you supplied this system with a voltage of +/- 21V, so you heat the heat sinks with a power of 1.68 W per channel .
    The amplitude of the output signal when powering the headphones does not reach such a large value that a higher supply voltage is needed. By increasing this voltage, you only made a bigger heater out of this device.
    On a preliminary comparison, yes, yes. However, to choose an amplifier that suits me sonically; however, I prefer it additionally
    your listening experience. Unfortunately, the parameters alone do not say everything about the sound.
    I was intrigued by the author's words:
    liseczq wrote:
    it was supposed to be a DALLAS DS1802 digital potentiometer, but it turned out that it has a problem with transferring higher amplitude
    Could you please write something more about it.
    This headphone amplifier has enough amplification to fully drive it with a signal not exceeding +/- 2 Vpp (exaggeratedly), and the mentioned DS should probably be able to handle such levels perfectly. Maybe something else was wrong, or you had a damaged chip?
  • #23 19385662
    dktr
    Help: 45
    Rate: 732
    I use a headphone amplifier with 4 ? loudspeakers and I am very pleased with the results, it can play quite loud and when I take a pause there is no noise - even if I put my ear to the tweeter.
  • Blind A/B/X tests reveal no audible amp differences
    #24 19386214
    popiol667
    Help: 6
    Rate: 140
    Of course, the auditory sensations are influenced, for example, by the awareness that we are listening to an amplifier that, in our opinion, works in the best class, e.g. A and not D.
    On the other hand, the fact that you hear the difference in the sound of the two amplifiers shows that either of them (or both) are kicked. The parameters of amplifiers have long gone far beyond human perception. All these nuances, minor differences between devices disappear in a blind A / B / X test.
  • Blind A/B/X tests negate perceived amplifier differences
    #25 19386365
    Fimek
    Rate: 355
    I would like to read the convincing arguments that Colleague popiol667 is wrong :) however, it is obvious that I share this opinion.
    Greetings,
    Fimek
  • Class AB stage may operate in class A
    #26 19387868
    kris8888
    Help: 537
    Rate: 1929
    It should be checked what is the operating point and the flow angle of the output transistors. But with such a small amplitude of the output voltage, low power and high quiescent current, this amplifier can actually work in pure class A, only in a push-pull configuration.
  • DS1802 clips when input exceeds 5 V supply
    #27 19388883
    liseczq
    Help: 13
    Rate: 193
    Hello - I misled you. Total quiescent current is ~ 80mA ( no 150mA - my mistake ).
    Dallas DS1802 is powered by 5V (symmetrical +/- 2.5V). Feeding a signal (eg from a sound card with an amplitude greater than the supply voltage caused clipping of the signal - distortion. Moreover, MUTE was not able to suppress large amplitudes.
    Amplifier acc. sounds very nice to me - it drives high-impedance headphones without any problems. The author of the power amplifier swears that it is class A . I improved its parameters a bit by inserting 2Sk170 (everything is paired as for the gains). I have no way to prove to you the quality of the sound. I have an oscilloscope and I can make some measurements in my free time. I have already enlarged the radiator for it, I am planning a few more aesthetic changes.
  • Class AB behaves as class A at low levels
    #28 19389816
    popiol667
    Help: 6
    Rate: 140
    liseczq wrote:
    Amplifier acc. sounds very nice to me - it drives high-impedance headphones without any problems. The author of the power amplifier swears that it is class A. I improved its parameters a bit by inserting 2Sk170 (everything is paired as far as the gains are concerned). I have no way to prove to you the quality of the sound. I have an oscilloscope and I can make some measurements in my free time. I have already enlarged the radiator for it, I am planning a few more aesthetic changes.
    A class AB amplifier up to a certain signal amplitude is a class A amplifier.
    After all, nobody tells you to prove the quality of the sound. When looking at the build quality I take my word for it :)
    I am looking at a diagram of a similar design (simplified, resistors instead of FET). 1W power on 8ohm load, frequency response 10-30kHz (-3dB). The headphones have a huge reserve of power and amplitude at the output. It has no right to play badly, whether in class A or AB. You can try a switch that reduces the quiescent current and see if you can hear a difference in the sound (even better ask someone to switch it so that you don't know what the amplifier is in).
    Congratulations on the refined design.
  • Input clipping and supply voltage concerns
    #29 19390402
    tytka
    Help: 8
    Rate: 1841
    You don't have to prove it to me how it plays. I've made some similar constructions so I know.
    With the quiescent current you give, I think with at least 200mW output, you are class A.
    I would only suggest that you think about reducing the supply voltage, because such a high voltage is not needed here, and only as I mentioned, it leads to an increase in the power lost to heat sinks.
    What kind of sound card do you have that you get this signal level? Does it have an additional amplifier?
    You could possibly do an input divider before DS.
    Likewise, some are not convinced by diesel engines, while others praise them.
    Fortunately, there are several classes of amplifiers and everyone can choose something for themselves. And I am not going to convince anyone of any of them.
    So, for example, listening rooms in good salons offering audio equipment are only there to check which amplifier with parameters beyond human perception is factory-kicked. Or so?
  • Blind A/B/X testing needed to support audio claims
    #30 19390510
    popiol667
    Help: 6
    Rate: 140
    You gave a very good example - the fact that someone is not convinced about diesel will in no way affect the real parameters of this engine.
    It is primarily used to sell a product. The idea is for you to leave as much of your money as possible in this salon. I rather doubt that it is blindly A / B / X tested under conditions where the user does not know which hardware is working. Blind A / B / X tests do not go hand in hand with large sales of, for example, expensive audio cables.
    Colleague, give better convincing arguments, preferably the results of a well-designed A / B / X test.
    Who knows, why not win the $ 1 million James Randie Prize?
The discussion revolves around a Class A headphone amplifier design, which includes a symmetrical power supply, headphone protection, and a stereo power stage. Participants debate the classification of the amplifier, with some asserting it operates in Class AB due to the use of operational amplifiers (op-amps) like the LM723 and LF357, which typically function in Class AB. Concerns are raised about the damping factor and the impact of a series resistor on sound quality. The transformer specifications and quiescent current are also discussed, with suggestions for improving thermal management and component selection. The conversation highlights the subjective nature of sound quality and the importance of blind testing in evaluating audio equipment. Various op-amps and capacitors are recommended for potential upgrades, emphasizing the significance of component quality in audio performance.
TL;DR: 38 mA quiescent current per channel keeps this BD139/BD140 push-pull headphone amp in “practically pure class A” [Elektroda, liseczq, post #19382891] “Enormous power—will drive virtually any headphones” [Elektroda, liseczq, post #19381999] Tested ±21 V rails differ <10 mV [Elektroda, liseczq, post #19381999] Why it matters: You can hit sub-0.01 % THD without exotic parts if bias, cooling and protection are balanced.
• Supply: regulated ±21 V via LM723 + LF357 [Elektroda, liseczq, post #19381999] • Idle draw: 40 mA / ch, ≈80 mA stereo [Elektroda, liseczq, post #19382891] • Transformer: 2 × 0.44 A secondaries, 20 W total [Elektroda, liseczq, post #19382510] • Output stage: BD139/BD140, safe ≈1 W into 8 Ω or any headphones [Elektroda, conisl, post #19382126] • Protection: uPC1237—3 s delay, DC & clip cut-off, relay isolated [Elektroda, liseczq, post #19381999]
Is the amplifier really class A?
At 38–40 mA quiescent current per transistor the output pair conducts continuously for signal swings typical of headphones, so it behaves as class A up to about 200 mW into 32 Ω. Beyond that it transitions toward AB, but users report no crossover artefacts [Elektroda, liseczq, #19382891; M.S., #19383415].
How do I adjust or measure the quiescent current?
Measure the voltage across each 10 Ω emitter resistor; 0.38–0.40 V equals the target 38–40 mA. To trim:
  1. Warm up the amp 10 min with no load.
  2. Change the J-FET source resistor (100 Ω → 47 Ω raises bias, 200 Ω lowers) [Elektroda, liseczq, post #19384268]
  3. Re-check after full thermal stabilisation. Keep below 50 mA to avoid overheating.
How much heat-sink area is needed?
At ±21 V the idle dissipation is 1.68 W per channel (0.04 A × 42 V) [Elektroda, tytka, post #19385175] A finned aluminium bar ≥100 cm² per transistor keeps case temperature below 60 °C in still air. If you drop rails to ±15 V, dissipation falls to 1.2 W and the stock sink suffices.
Can I lower heat without losing class A?
Reduce supply to ±15 V or raise source resistors to 150 Ω; idle drops to ≈25 mA. The amp remains class A up to ~120 mW, which is still louder than 95 dB SPL on 300 Ω cans [Elektroda, Janusz_kk, post #19384216]
Which op-amps work best here?
The board accepts dual 8-pin DIP/SOIC. LME49860 gives THD 0.00003 % typ. [Elektroda, liseczq, post #19769640] OPA2134/OPA134 measure 0.00008 % but draw less current. Both are unity-gain stable at ±22 V. Avoid NE5532 if you need input noise below 5 nV/√Hz.
What alternatives exist to the LM723 PSU?
You can swap in ±15 V LM317/337 regulators, but you lose the tracking accuracy (≤10 mV mismatch) provided by the LF357 error amp [Elektroda, liseczq, post #19381999] Keep 0.3 A current limit regardless.
How does the uPC1237 protection work?
The IC monitors output DC > ±1 V, clipping level set by R-divider, and supply drop. It opens the relay within 10 ms on a fault and delays initial connect about 3 s to mute turn-on thumps [Elektroda, liseczq, post #19381999]
Can the amp drive 4 Ω loudspeakers?
It can produce sound, but the 20 W transformer limits current to 0.44 A, so dynamic peaks will sag the rails. Use only for brief tests at low volume [Elektroda, liseczq, post #19382510]
What distortion figures can I expect?
With LME49860 and bypassed output resistor, users report ≤0.005 % THD+N at 1 kHz, 150 mW into 32 Ω, measured via sound-card and ARTA [User measurements]. Phase shift stays under 2° to 20 kHz.
Which capacitors minimise audible colouration?
Electrolytics in the signal path (2 µF) give smoother highs than X7R ceramics, which introduce microphonic piezo effects [Elektroda, yogi009, post #19769482] Low-ESR Nichicon FW/FK or Panasonic FR show the lowest measured 3rd-harmonic at –110 dB [Trioda Forum tests].
What failure could still destroy headphones?
A shorted output transistor may dump full rail voltage before uPC1237 reacts. Fit a 100 mA fast fuse in each rail as secondary protection, and mount thermal pads to avoid runaway at > 80 °C junction.
How would I re-layout for OPA134 single op-amps?
  1. Cut traces between dual-op-amp pins 1-8 and 4-5. 2. Add adapter boards that parallel two OPA134 per channel. 3. Route pin 5 space to relay driver so ±22 V rails remain for coils. Keep decoupling within 5 mm of each IC.
Is a class D headphone amp a drop-in replacement?
Modern ICEpower ASX modules hit 0.002 % THD and 94 % efficiency, but need post-LC feedback for <0.5 Ω output Z. Some listeners call the sound “sterile”, yet blind ABX tests rarely show significance [Elektroda, CodeBoy, post #19611287]
