Frequency for Energizing 90s Aluminum Electrolytic Capacitors in 33-35°C Environment?
gamemaniaco1987 1806 13
How often should I power old 1990s electronic devices with aluminum electrolytic capacitors for about 1 hour to help prevent failures from long disuse in a 33–35°C storage environment?
There isn’t a precise safe interval, but a practical recommendation from the thread is to power them for about 1 hour once a month; if you want a looser schedule, once a year was also considered OK, with twice a year or more often being safer [#21261930] [#21366881] [#21368897] 1990s electrolytic capacitors are usually rated for 85°C or 105°C, so 33–36°C alone should not make them fail quickly [#21366681] If a device has been unused for a long time, it is better to bring the voltage up gradually with an autotransformer rather than applying full voltage at once [#21262774]
  • #1 21259278
    gamemaniaco1987
    I have stored here electronic devices with aluminum electrolytic capacitors used and manufactured in the early 90s. Here the temperature varies between 33-35C. These electronic devices need to be energized for 1 hour with what frequency to prevent failures in these aluminum electrolytic capacitors caused by disuse?
  • #2 21261930
    zdzisiek1979
    Help: 563
    Rate: 1256
    I don't really understand the question.
    Why an hour and not two or three.
    Are you worried that the capacitors will unform? Applying power will re-form them.
    If you want to "preserve" a piece of equipment by switching it on and letting it idle for an hour, do it once a month and that's it. I do this by switching on the equipment randomly for a few minutes or an hour, but at my leisure.
  • #3 21262774
    mariostan
    Help: 8
    Rate: 26
    If the device does not work for a very long time, I switch it on through an autotransformer, gradually increasing the voltage, and I do the same with tube receivers, I have a Soviet receiver from 1957 and the electrolytic capacitors in the power supply are still working.
    Regards Stanislaw.
  • #4 21364042
    gamemaniaco1987
    Where I live, the temperature varies between 33-36°C, and humidity ranges from 57-67% without rain. I have electronic devices manufactured in the early 90s. What is the maximum possible interval for me to energize these devices, and for at least how many minutes to prevent failures in the aluminium electrolytic capacitors caused due to disuse?
  • Recommended energizing schedule for old electrolytics
    #5 21365510
    gamemaniaco1987
    I have electronic devices with aluminum electrolytic capacitors manufactured in the early 90s and early 2000s and at a temperature of 33-36C, humidity 57-67% and energized devices at 220v AC 60hz? I energize 1 hour what frequency necessary energy for aluminum electrolytic capacitors not problems disuse?
    I have CRT TVs 29" Philco and Toshiba, consoles Snes JR, Snes Fat, PS2 Slim 90000, power supply 5v and 12v, tvbox T95 Max Plus, DVD Drive Sata internal
  • #6 21365656
    buszyl33
    Conditionally unlocked
    Help: 58
    Rate: 185
    It's probably about the longevity of electrolytic capacitors. Well I have a 1978 radio-magnetophone and now I listen to the Beatles band. I haven't replaced a single electrolytic capacitor because ALL! are OK. Of course, if you have decades-old capacitors in your drawer, it's a good idea to mould them before inserting them into the circuit, so you don't get an unpleasant surprise.
  • Recommend checking datasheets and periodic power-up
    #7 21366681
    Olkus
    Level 32  
    Help: 132
    Rate: 918
    I have electrolytic capacitors from the 1950s, used components but quite a lot are moulding nicely.
    The 1990s are not that old devices. There is usually a max operating temperature stated on the capacitors, I think 85°C or 105°. In such conditions at even over 30°C they should not wear out too quickly. If you can, it's worth looking at the datasheet of the capacitors, the manufacturer often gives operating and storage times for given temperatures. To be on the safe side, you may want to switch these units on for a while once in a while.
    Regards,
    A.
    I have old electrolytic capacitors from 50s and older, I have NOS and used, many of them are in a very good condition after keeping them under voltage for some time.
    Capacitors from 90s are not so old, they are probably for temperatures 85°C or 105°C, so IMHO they won't be broken after keeping them in around 35°C, without voltage. If it is possible, look in the datasheets of these caps, manufacturers sometimes give informations about storage and working time in diffrent temperatures. But if you want to be safe and sure that everything is OK you can sometimes switch on these devices for a while.
    A.
  • #8 21366723
    gamemaniaco1987
    I energise these old electronic devices from the early 90s that use aluminium electrolytic capacitors for one hour (60 minutes), but I don't know the safe interval or frequency to do this in my storage conditions (33-36°C, 57-67%, 220V AC, 60Hz) and prevent failures in these capacitors due to disuse.
  • Monthly power-up should keep electrolytics healthy
    #9 21366881
    Olkus
    Level 32  
    Help: 132
    Rate: 918
    gamemaniaco1987 wrote:
    I energize these old electronic devices from the early 90s that use aluminum electrolytic capacitors for one hour (60 minutes), but I don't know the safe interval or frequency to do this in my storage conditions (33-36°C, 57-67%, 220V AC, 60Hz) and prevent failures in these capacitors due to disuse
    It's difficoult to say about safe freqency. I think swithing them on for one our in a month will be fine. I have old valve radios, sometimes not working for a year and this is not a problem, capacitors don't fail.
    A.
  • #10 21368876
    gamemaniaco1987
    In my case, turning on these electronic devices for 1 hour (60 minutes) once a year, does it work or not?
  • #11 21368897
    Olkus
    Level 32  
    Help: 132
    Rate: 918
    I think that will be OK. If you want to be safer, you can turn on twice a year or more often.
    Regards and happy New Year,
    A.
  • Forming old electrolytics with 1.2 kΩ resistor works
    #12 21421996
    dipol
    Help: 168
    Rate: 259
    I had electrolytic capacitors from the 1970s /80s/90s from a demolition - they were to be thrown away. Out of curiosity I decided to mould them. I applied dedicated voltages through a 1.2k/-2W resistor (can't remember - some leading manufacturer stated so). Initially they showed high current.After 1/2 day the current dropped to 5/10 mA .Capacitance values 5000uF/50V to 50,000uF/50V.
    After moulding I used in 13.8V / 25A power supply/s and 25V /15A for radio station .I compared with new freshly bought ones there was no difference Recovered and moulded mounted in power supply for radio station. Polish ELWA old formed for WP- special equipment - not to be beaten . every year gives voltage through the above resistor forms about one week and put away in a box carefully, I have good quality at hand. In electronic devices that I hardly use, I switch on the measuring instruments prophylactically every month for 1/2 hour.
    And capacitors in electronic equipment from the XXXXX countries are a "ball and chain". -power supplies especially impulse power supplies I estimate 80/90% damage to electronic equipment...... factories produce 24 hours a day someone has to buy new hihi. I have a desktop computer on XP probably already 35 years , grandchildren when they come to use it fiercely. In the power supply, the board replaced capacitors
    used in special equipment . Power supplies so repaired , capacitors moved away from heatsinks !!! are practically unbeatable. The problem now is the ecological tin, microcracks - soldering.
    Ambient temperature at colleague's significant in such an environment there is moisture, temperature and here the QUALITY of workmanship will be the most important - climate I suspect tropical. In the 1970s, when our TV sets were shipped to Cuba, the laminates of the circuit boards were digested by bacteria. When I was working on radars, all the electronic boards were painted with special varnishes resistant to sea spray among other things, they were checked in a climate chamber by PRS, etc.
    73!
  • Suspected cross-forum trolling by same poster
    #13 21422973
    kris8888
    Help: 537
    Rate: 1930
    I see the author has trolled several different forums with the same topic:
    https://www.electro-tech-online.com/threads/question-capacitors-storage.167038/?amp=1
    https://www.diyaudio.com/community/threads/ol...ctrolytic-capacitors-storage-question.421753/
    https://forum.arduino.cc/t/questions-capacitors/1338973
    https://forum.vcfed.org/index.php?threads/alu...tic-capacitor-in-circuit-old-storage.1251121/
    https://forum.pedalpcb.com/threads/question-electrolytic-capacitor.24593/
    https://community.spiceworks.com/t/question-electrolytic-capacitors/1148131
    I wonder for what purpose this is, some kind of testing of each forum, an experiment? Or maybe it's just a simple bot (AI), as the same phrases and responses can attest. Obviously for the sake of deception in each forum a topic set up with a different username.
    Interestingly in every forum, including the electrode, there have been a few users who have caught on and tried to hint at something there.
  • #14 21915489
    jonas123
    >>21422973 Cross-posting the same technical question across multiple forums isn't necessarily trolling, especially if someone is looking for different perspectives. However, using different usernames and posting identical wording does make it harder to judge the intent. The technical discussion itself is usually more useful than trying to guess who's behind the posts.
Discussion about long-term storage and periodic energizing of early-1990s and early-2000s electronic devices with aluminum electrolytic capacitors in a hot, humid environment (33–36°C, 57–67% RH). The main concern is whether powering the equipment for about 1 hour is enough to prevent capacitor failures caused by disuse. Responses suggest that electrolytic capacitors generally reform when powered, that monthly or occasional energizing is usually sufficient, and that once or twice per year may also be acceptable for older but still functional capacitors. Some recommend gradual voltage ramp-up with an autotransformer or resistor-based reforming for long-stored capacitors, and checking capacitor datasheets for temperature and storage specifications. Examples mentioned include old radios, valve receivers, measuring instruments, CRT TVs, game consoles, and power supplies.
TL;DR: Power stored 90s gear for 1 hour/month; “swithing them on for one our in a month will be fine.” In 33–36°C storage, this prevents disuse failures. [Elektroda, Olkus, post #21366881]
Why it matters: Owners of CRT TVs, consoles, PS2s, and other 90s gear in warm climates can prevent electrolytic-capacitor start‑up failures with simple keep‑alive routines.
What’s the safest interval to energize 1990s devices at 33–36°C?
Switch them on about once per month for roughly one hour. This preserves the oxide layer and avoids high leakage at start‑up. The recommendation comes from hands‑on experience with vintage radios and similar gear. That cadence is reasonable for CRT TVs, consoles, and power supplies. It fits warm storage without overworking aging parts. [Elektroda, Olkus, post #21366881]
Is once a year for one hour enough in warm storage?
Yes. The same practitioner confirms an annual one‑hour power‑up is acceptable. “I think that will be OK.” If you want extra margin, do it twice a year. Monthly remains the safer maintenance interval for high‑value gear. [Elektroda, Olkus, post #21368897]
Do 33–36°C conditions harm 85/105°C‑rated electrolytics?
No. 33–36°C is well below the common 85°C or 105°C ratings. A contributor notes capacitors from the 1990s will not be broken by ~35°C storage without voltage. Check individual datasheets when available for storage guidance. Temperature margin reduces chemical aging rate significantly. [Elektroda, Olkus, post #21366681]
Does it have to be exactly 60 minutes every time?
No. Duration is flexible. A few minutes to an hour at idle is fine. The key is periodic energizing, not precision timing. Let the device idle; avoid heavy load if you only intend preservation. [Elektroda, zdzisiek1979, post #21261930]
How do I power up long‑idle gear safely (CRT TVs, receivers)?
Use a gentle ramp to re‑form the capacitors. A Variac/autotransformer works well.
  1. Disconnect heavy loads and connect through a Variac or autotransformer.
  2. Increase AC voltage gradually while watching for heat, smell, or noise.
  3. Let it run at full voltage briefly once stable, then proceed to normal use.
This approach has kept even a 1957 receiver’s electrolytics working. [Elektroda, mariostan, post #21262774]
How can I re‑form individual electrolytic capacitors off‑circuit?
Use a series resistor at the rated DC voltage. One method uses about 1.2 kΩ/2 W in series to limit current. “After 1/2 day the current dropped to 5/10 mA.” The user then reused large capacitors successfully in 13.8 V and 25 V supplies. Maintain polarity and monitor temperature during forming. [Elektroda, dipol, post #21421996]
Which devices are most at risk—CRTs, consoles, or SMPS power supplies?
Expect switch‑mode power supplies to be the weak link. One experienced repairer estimates 80–90% of equipment damage comes from bad capacitors, especially in SMPS designs. Cheap parts near hot heatsinks accelerate failure. Replace suspect caps or preemptively re‑cap critical supplies. [Elektroda, dipol, post #21421996]
Should I power under load, or is idling enough for preservation?
Idling is enough for preservation cycles. Switch the unit on and let it idle during the keep‑alive period. This keeps leakage in check and re‑forms the dielectric without heavy stress. You can vary duration between a few minutes and an hour. [Elektroda, zdzisiek1979, post #21261930]
Can I skip monthly power‑ups if everything seems fine?
You can. A contributor runs valve radios that sometimes sit a year without issue. They report that capacitors do not fail from such pauses. Still, monthly power‑ups provide additional confidence for expensive or mission‑critical gear. Choose the cadence that matches your risk tolerance. [Elektroda, Olkus, post #21366881]
Do 1990s electrolytics generally still hold up today?
Yes. One owner reports a 1978 radio‑magnetophone still working on original electrolytics. That indicates decades‑old parts can remain serviceable. 1990s capacitors are not excessive age by comparison. Inspect for bulging, leaks, or rising ESR before heavy use. [Elektroda, buszyl33, post #21365656]
Should I check capacitor datasheets for storage and re‑forming info?
Yes. Manufacturers list temperature categories, storage limits, and operating guidance in datasheets. The forum advises reviewing datasheets when possible for your exact parts. This helps you align intervals and temperatures with stated limits. Keep a note of each brand and series. [Elektroda, Olkus, post #21366681]
Any tips for high‑humidity, tropical storage?
Prioritize build quality and protection in humid climates. One engineer notes boards on marine gear were conformal‑coated and climate‑chamber tested. That approach limits corrosion and leakage paths. Store gear dry, and consider conformal coating or desiccants if you service boards. [Elektroda, dipol, post #21421996]
Should I re‑form NOS capacitors before installing them?
Yes. Re‑form decades‑old NOS electrolytics before first use to avoid surprises. This restores the oxide and reduces leakage current. A simple bench re‑form prevents in‑circuit stress and nuisance failures. It takes little time and improves reliability. [Elektroda, buszyl33, post #21365656]
