Electrolytic Capacitor Lifetime and Capacitance Loss After 30 Years Storage
1458 11
Do electrolytic capacitors age when left unused for decades, and should I replace the electrolytics in an old circuit?
Yes, electrolytic capacitors do age even when they are not used, and the rate depends on the capacitor’s quality, the electrolyte, how close it was run to its maximum working voltage, and operating temperature [#21679257] In some cases a capacitor can partially recover by re-forming it, which means gradually applying voltage while monitoring current [#21679257] For old equipment, several replies recommend replacing aged electrolytics if that is practical, and one restorer said they routinely replace electrolytics more than 25 years old because they can leak [#21679257][#21679267] Aluminium and tantalum electrolytics are the main ageing problem types, while non-polarized capacitors such as polyester, mylar, and mica are much less troublesome [#21679264] Electrolytics also commonly have a skewed tolerance such as -10% / +50% because their capacitance can drift with age [#21679263]
  • #1 21679256
    Andy Whitfield
  • Capacitor re-forming may partially restore specs
    #2 21679257
    Rick Curl
  • #3 21679258
    Alan Winstanley
  • #4 21679259
    darlene damon
  • Aged tantalum capacitors can short after storage
    #5 21679260
    David Ashton
  • Old electrolytics measured above nominal value
    #6 21679261
    Andy Whitfield
  • #7 21679262
    Andy Whitfield
  • #8 21679263
    David Ashton
  • #9 21679264
    David Ashton
  • Paper capacitors and old oil caps can become leaky
    #10 21679265
    PeterTraneus Anderson
  • First measurement skewed by slow capacitor charging
    #11 21679266
    Andy Whitfield
  • #12 21679267
    stephen Rainsbury
Electrolytic capacitors age over time even when not in use, primarily due to electrolyte degradation, operating voltage proximity to maximum ratings, and temperature conditions. This aging results in reduced capacitance and potential failure modes such as leakage or short circuits, especially in aluminum and tantalum electrolytics. Re-forming capacitors by gradually applying voltage can partially restore capacitance, a technique used in vintage radio restoration. Replacement of all electrolytic capacitors in circuits older than 25-30 years is generally recommended to ensure reliability, as aging capacitors may cause circuit malfunction. Non-polarized capacitors like polyester, mylar, mica, and paper types tend to be more stable but paper capacitors can become leaky over time. Large electrolytic capacitors may initially show abnormal charging behavior and capacitance readings that stabilize after repeated measurements. The Sprague brand is noted for high-quality capacitors, with some older Sprague 15,000µF capacitors measuring above nominal capacitance after long storage. Tantalum bead capacitors can fail short-circuit after storage, posing risks such as transformer damage. Testing methods include capacitance measurement and simple smell tests for leakage. Overall, proactive replacement or re-forming is advised for long-stored electrolytic capacitors to maintain circuit performance.
TL;DR: Electrolytics age in storage; “electrolytics typically have a skewed tolerance like −10/+50%.” Replace older caps or carefully re‑form before use. [Elektroda, Anonymous, post #21679263]
Why it matters: This FAQ helps hobbyists, restorers, and engineers diagnose capacitance loss, decide replace vs. re‑form, and avoid avoidable failures in vintage and stored gear.
Do electrolytic capacitors age when not used?
Yes. The electrolyte and oxide deteriorate with time, even in storage. Expect increased leakage, ESR changes, and reduced effective capacitance. As one expert put it, “Electrolytic capacitors definitely do age.” If reliability matters, plan inspection or replacement before power‑up. [Elektroda, Anonymous, post #21679257]
What tolerance should I expect, and why do some measure high?
Large can electrolytics often ship with asymmetric tolerance, commonly around −10%/+50%. A 15,000 µF part may legitimately measure near 22,500 µF and still meet spec. That skew helps ensure minimum filtering under load. So over‑nominal readings on good meters are not unusual. [Elektroda, Anonymous, post #21679263]
Should I replace all electrolytics in a 30‑year‑old project?
Yes for mission‑critical or audio gear. Many restorers replace electrolytics older than roughly 25 years to avoid leakage, noise, and sudden failure. This proactive approach saves troubleshooting time on vintage synths and similar equipment. [Elektroda, Anonymous, post #21679267]
How do I safely re‑form an electrolytic capacitor?
Follow a gentle three‑step process: 1. Apply a low DC voltage and watch current. 2. Increase voltage in steps as current falls. 3. Stop if current won’t decline or the can warms. This can partially restore oxide and reduce leakage. [Elektroda, Anonymous, post #21679257]
Why did my 15,000 µF Sprague read 19,000–20,000 µF?
That falls within typical skewed tolerance for electrolytics. Premium brands may measure above nominal when new or healthy. The key is acceptable leakage and ESR under working voltage rather than exact capacitance alone. [Elektroda, Anonymous, post #21679263]
My big caps first measured 2–3× value, then settled. What happened?
They charged slowly on the first run, so the meter’s algorithm interpreted a larger effective capacitance. After initial conditioning, subsequent measurements reflected closer‑to‑nominal behavior. Pre‑charging or re‑forming often stabilizes readings. [Elektroda, Anonymous, post #21679266]
Do tantalum capacitors fail after long storage?
Yes. Older bead‑style tantalums can short when re‑energized after years offline, sometimes stressing transformers or supplies. Replace suspect parts or power up through a current‑limited source to mitigate risk. [Elektroda, Anonymous, post #21679260]
Which capacitor types age the least in storage?
Non‑polarized film types—polyester, Mylar, mica—tend to remain stable for decades. They rarely show the electrolyte‑driven failures seen in aluminum or tantalum electrolytics. Use them where practical for long‑term reliability. [Elektroda, Anonymous, post #21679264]
Are paper or oil‑filled capacitors risky in restorations?
Yes. Paper caps often become leaky and can damage tubes or coils. Some sealed oil‑filled types pose another risk: physical leakage of PCB fluid, which is hazardous. Replace on sight in vintage radios. [Elektroda, Anonymous, post #21679265]
How does aging affect RC timing circuits?
Aging electrolytics can change capacitance and leakage, shifting time constants and behavior. You may see partial recovery after use, but replacement restores predictable timing. That’s common in battery‑powered displays and timers. [Elektroda, Anonymous, post #21679261]
Is it better to replace or try to restore old electrolytics?
If time and cost allow, replacement yields the most reliable outcome. Otherwise, re‑form cautiously and monitor current. “If replacing all...is an option...that is probably the right thing to do.” [Elektroda, Anonymous, post #21679257]
What is an electrolytic capacitor reformer?
A reformer is a controlled supply that steps voltage while monitoring current to rebuild the oxide layer. EPE documented a DIY reformer in its August–September 2012 issues for audio work. [Elektroda, Anonymous, post #21679258]
Any quick field test for bad electrolytics in synths?
One restorer heats the leads with a soldering iron; a fishy smell suggests electrolyte issues. It’s a crude screen, not a replacement for ESR/leakage tests, but it flags replacements fast. [Elektroda, Anonymous, post #21679267]
Can a cap seem fine yet still be a failure risk?
Yes. An electrolytic can measure near‑nominal capacitance but have high leakage or ESR under voltage, leading to hum, heat, or regulator stress. Always check behavior at working voltage. [Elektroda, Anonymous, post #21679257]
Why do restorers preemptively swap radio coupling caps?
Leaky paper coupling caps bias stages incorrectly and can destroy hard‑to‑replace parts. Many restorers replace these on principle before first power‑up to protect tubes and coils. [Elektroda, Anonymous, post #21679265]
