Do Electrolytic Capacitors Lose Capacitance or Short After Long Periods Unused?
555 9
Do electrolytic capacitors in old electronic devices need to be powered on periodically to prevent capacitance loss or failure during storage?
Partly true: electrolytic capacitors can deteriorate during long storage, especially at higher temperatures, but they do not normally need to be powered on every month to avoid failure. [#21685547][#21685549] If equipment is used often, there is usually no issue; if it is only used a few times a year and is valuable, periodic power-up may be worthwhile. [#21685547] The thread says electrolytics deteriorate in storage or in use when exposed to heat, and modern electrolytics can have some years of shelf life at low temperatures without needing reforming. [#21685547] For mains-powered gear, a variac can be used to bring the voltage up slowly from zero. [#21685547][#21685549]
  • #1 21685543
    john87
  • Methods for reconditioning old electrolytic capacitors
    #2 21685544
    Giovanni Di Maria
  • #3 21685545
    john87
  • #4 21685546
    john87
  • Modern electrolytics have years of shelf life at low temperature
    #5 21685547
    Richard Gabric
  • #6 21685548
    john87
  • #7 21685549
    Richard Gabric
  • #8 21685550
    john87
  • #9 21685551
    john87
  • #10 21685552
    john87
Electrolytic capacitors stored unused for extended periods can suffer depolarization, loss of capacitance, and potential short circuits. To restore aged capacitors, several reconditioning methods exist: gradual voltage application with limited current ("sweet method"), repeated charging and discharging at nominal voltage, pulsed voltage with long-period square waves, thermal treatment by immersion in hot water (70-80°C), and application of short high-voltage pulses. Regular use of electronic devices containing electrolytic capacitors may help maintain capacitor health, but monthly powering is not strictly necessary for all equipment. Capacitor degradation accelerates with elevated storage temperatures; prolonged exposure above 5-10°C can be detrimental, especially in climates with ambient temperatures around 31-35°C. Modern electrolytics have improved shelf life at low temperatures, but older devices from the 1990s (e.g., SNES consoles, PS2, CRT TVs) may require careful management. Using a variac to slowly ramp up voltage during power-up can reduce stress on aged capacitors. Manufacturer quality varies, influencing longevity and storage recommendations. Nichicon's technical documentation provides detailed guidance on aluminum electrolytic capacitor characteristics and shelf life.
