Aluminum Electrolytic Capacitor Leakage After 10 Years Storage—Humidity or Heat?
855 14
Why would aluminum electrolytic capacitors fail and leak after about 10 years of unused storage, and is the cause more likely humidity or heat?
The most likely cause is age-related deterioration of the electrolytic capacitors during long idle storage, not simply humidity or heat; electrolytics lose their formation when unused, can develop high leakage current on first power-up, and may overheat, boil the electrolyte, and leak or fail if brought up abruptly [#21680032][#21680033][#21680037] Some capacitors can sometimes be recovered by re-forming them with a slowly rising voltage, but if a capacitor is bulging or already leaking it should be replaced [#21680033][#21680034][#21680045] Because several units have already failed, the practical advice is to replace all electrolytic capacitors in the old power supplies before re-energizing the equipment [#21680034][#21680039]
  • Heat and humidity likely caused capacitor leakage
    #1 21680031
    Elizabeth Simon
  • #2 21680032
    Aubrey Kagan
  • Electrolytics need reforming after long storage
    #3 21680033
    David Ashton
  • Replace all electrolytic capacitors before powering old gear
    #4 21680034
    PeterTraneus Anderson
  • #5 21680035
    Elizabeth Simon
  • #6 21680036
    Jack Grubbs
  • Unreformed capacitors can overheat and leak on power-up
    #7 21680037
    David Ashton
  • #8 21680038
    David Ashton
  • Replace electrolytics and X2 caps before re-energizing
    #9 21680039
    Conrad Mannering
  • Replacing the power supplies may be easier than repair
    #10 21680040
    Elizabeth Simon
  • Discharge, clean, and replace leaking capacitors
    #11 21680041
    Sambath Kumar
  • Modern electrolytics and out-of-circuit leakage testing
    #12 21680042
    Rick Curl
  • Leakage can short adjacent solder pads
    #13 21680043
    Sambath Kumar
  • Bias cap leaked despite bulk cap surviving
    #14 21680044
    Elizabeth Simon
  • Electrolytic capacitor reclamation safety guidance
    #15 21680045
    Aubrey Kagan
Aluminum electrolytic capacitors stored unused for about 10 years can deteriorate and leak electrolyte due to aging, loss of the oxide insulating layer, and internal corrosion. Prolonged idleness without periodic voltage application causes the oxide layer to thin, increasing leakage current and potentially leading to heating, electrolyte boiling, and physical leakage or rupture upon sudden power-up. Reforming capacitors by gradually applying voltage through a current-limiting resistor or incandescent bulb can restore the oxide layer and reduce leakage risk. However, if capacitors show bulging, leakage, or cannot be reformed, replacement is necessary. Storage conditions such as heat, humidity, and corrosive atmospheres exacerbate degradation. Cleaning leaked electrolyte from PCBs with isopropyl alcohol is recommended before repair. Other components like LCDs may also degrade over long storage. Replacement of all electrolytic capacitors in old equipment is often advised to prevent failures. Historical capacitor types (e.g., oil/paper) have longer lifespans but modern electrolytics have proprietary electrolytes that vary. Additional issues include failures of suppression capacitors and NiCad battery leakage damaging PCBs. References to the "Capacitor Plague" highlight widespread failures in certain periods. Technical resources and industry expert advice on capacitor restoration and safe reforming procedures are available.
TL;DR: After 10 years idle, aluminum electrolytics lose oxide and go leaky; "Electrolytics do not suffer idleness well." Replace or reform slowly before power-up. [Elektroda, Anonymous, post #21680033]
Why it matters: It prevents blown supplies, leaked electrolyte, cracked safety caps, and costly downtime for rebooted lines.
What causes aluminum electrolytic capacitors to leak after long storage?
Idle time thins the aluminum oxide dielectric. Initial power then produces high leakage current, heating, and gas pressure. Vents open and electrolyte escapes. Regular use maintains formation; idleness accelerates corrosion and drying. Replace visibly bulged or leaking parts. "Electrolytics do not suffer idleness well." [Elektroda, Anonymous, post #21680033]
Do I need to reform capacitors after 10 years on the shelf?
Yes. Long-idle electrolytics need a slow voltage ramp to rebuild the oxide layer and reduce leakage. This lowers inrush stress and avoids boil-off or venting. Units that were continuously powered usually stay formed and fare better. If reformation fails or parts leak, replace them. [Elektroda, Anonymous, post #21680033]
What happens if I skip reforming and power up abruptly?
An unreformed capacitor draws high leakage current. The I×V heating can raise internal temperature and boil the electrolyte, causing venting or even rupture. This edge case appears when the dielectric fails to reform quickly under load. "...consequent leakage or explosion" is a real risk. [Elektroda, Anonymous, post #21680037]
How do I safely reform an old electrolytic with basic tools?
  1. Put an incandescent bulb in series with the supply as a current limiter.
  2. Apply voltage below the cap rating and raise it slowly while watching leakage.
  3. Stop if the bulb brightens steadily, the can warms, or venting appears; replace the part. [Elektroda, Anonymous, post #21680034]
Why did a small bias/bootstrap cap fail while the bulk cap survived?
Small bootstrap caps can see higher effective stress at startup because their oxide is underformed and they charge through resistive paths. Higher leakage power density heats them faster than the large bulk cap, triggering venting earlier. Replace any cap that leaked. [Elektroda, Anonymous, post #21680037]
Should I shotgun-replace all electrolytics or only the bad ones?
Replace all electrolytics in gear that sat unused for years, especially after any have failed. Mixed-age supplies and unknown storage conditions raise future failure risk. Many restorers recap before first power to protect scarce parts. [Elektroda, Anonymous, post #21680034]
How do I clean a PCB after electrolyte leakage?
Power down, disconnect, and discharge using a resistor or bulb. Brush both sides with isopropyl alcohol to remove conductive residue. Wipe and air-dry. Then test and replace leaky parts. This restores insulation and limits corrosion spread. [Elektroda, Anonymous, post #21680041]
Can leaked electrolyte cause shorts even if the cap looks fine?
Yes. Residue between close solder pads can conduct and create shorts without visible board burns. Clean thoroughly with isopropyl alcohol and recheck. Visual inspection alone can miss conductive films under components. [Elektroda, Anonymous, post #21680043]
Do LCDs also degrade in long storage?
Yes. Darkened, unreadable LCDs are common after long idle periods. The practical fix is replacement of the display module. Visual symptoms include uniformly dark or mottled segments that do not respond. [Elektroda, Anonymous, post #21680038]
Are X2 suppression capacitors a concern on first energizing old gear?
Yes. Aged X2 caps across the mains often fail with a sharp crack and smoke on re‑power. Replace them proactively during service to avoid nuisance trips and odor. They usually fail safe but can startle operators. [Elektroda, Anonymous, post #21680039]
Do modern electrolytics still use boric acid as the electrolyte?
Historic parts often used weak boric acid solutions. Modern electrolytes vary by brand and are more proprietary. Composition changes aim at lower ESR, better life, and safety. Treat unknown residues as conductive until cleaned. [Elektroda, Anonymous, post #21680044]
How should I test electrolytics for leakage in-circuit?
In-circuit readings can mislead because surrounding parts mask true leakage. Lift one lead to measure capacitance and leakage accurately. Compare results with expected behavior during slow reforming. Refit only if values stabilize. [Elektroda, Anonymous, post #21680042]
What voltage rating margin should I choose when replacing caps?
Use a voltage rating about 2× the measured steady voltage where space and cost allow. This margin reduces stress and improves longevity in supplies. Verify actual operating voltage before ordering replacements. [Elektroda, Anonymous, post #21680041]
Is full recap standard on vintage computers and controls?
Yes. Technicians restoring 30+ year-old Apple IIe and BBC units replace electrolytics before power to prevent supply and logic damage. This practice reduces repeat failures and speeds diagnosis. [Elektroda, Anonymous, post #21680039]
Where can I read a safe reclamation method from an industry expert?
See the linked note on aluminum electrolytic reclamation shared in the thread. It outlines a cautious, instrumented approach to bringing aged capacitors back. Follow safety and replace if any parameter deviates. [Elektroda, Anonymous, post #21680045]
