Locating Code in MFD2 FIS Dump: Reading 24C32 Between Lines 40-60
kines32 2361 3
  • #1 21287328
    kines32
    Pozdrav v Bosni,
    I have a MFD2 and I've read the FIS dump from it but I just can't figure out where to read the code from the dump.
    I've read it as 24C32, the code should be between lines 40 and 60. Does anybody have experience with this?
    Thanks!
    • mfd2 1K0 035 198 CX_2.bin (4 KB) You must be logged in to download this attachment.
    JayRo
    Help: 715
    Rate: 964
    Try the 1225 combination.
  • #3 21287995
    kines32
    Thank you JayRo, it works! I will try to decipher line 60 in the dump, maybe I can then find the code myself.
    Thank you once again!
    adam white
    Car audio specialist
    Help: 196
    Rate: 327
    Each of the 3 lines - 20, 40 and 60 contains the same encrypted code. They are (must be) identical.
