SHARP LC-43CFE6131E TV Wont Turn On After Update - Installation Issues
pablo801 1188 2
  • USB .bin update attempt leaves black screen
    #1 21310810
    pablo801
    Hello everyone!
    After updating my TV via the settings, it no longer turns on. I retrieved the file on the previous topic but my television does not want to install it.
    SHARP MODEL: LC-43CFE6131E
    SERIAL: A43CF6131EB38396115750801343
    So I need your help urgently
    thank you very much
    AI: Could you please specify how you performed the update on your TV? Was it via USB, over-the-air, or another method?
    Put .bin file into USB flash drive FAT and press power button
    AI: Are there any error messages or codes displayed when you try to turn on the TV or install the file? If so, what do they say?
    Black screen
  • #2 21864103
    malekarooh
    @ElektrodaBot @ElektrodaBot
  • USB recovery with exact Sharp firmware package
    #3 21864119
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    Initial assessment
    Your LC-43CFE6131E is most likely in a failed firmware / soft-bricked state after the update. For this exact model family, the official Sharp manual confirms that the TV supports Software Update (USB), and it explicitly says that the detailed method is supplied with the firmware package itself. Sharp’s global support page also says to use the country-specific download site, and if the model is not found there, to contact the dealer/support. (s3.infra.brandquad.io)
    Very important correction
    Do not rename the file to
    install.img
    just because you found that advice online. An official Sharp document that uses
    install.img
    is for PN-LE601 / 701 / 801 series only, which is a different product line. For your TV, the correct filename must be exactly whatever the recovery package for LC-43CFE6131E specifies. (business.sharpusa.com)
    What to do now
    1) Prepare the USB again, very carefully
    Use:
    - a small USB stick if possible,
    - FAT32,
    - one partition,
    - firmware file in the root of the drive,
    - no folders, no extra files.
    The manual for this chassis family shows the TV can work with FAT32-formatted USB storage, and the USB software update is the intended service path. (s3.infra.brandquad.io)
    2) Use only the exact recovery package for your set
    For this model, the critical points are:
    - exact model: LC-43CFE6131E
    - exact market/version,
    - ideally matching serial / panel variant if the source provided firmware by serial number.
    If the file came from another topic for a “similar” Sharp, that is risky. Sharp also warns generally that files/documentation from another country/product variant may not apply even if names look similar. (global.sharp)
    3) Try a forced USB start
    Because you currently have a black screen, the normal on-screen menu path is unavailable. The practical low-risk recovery attempt is:
    1. Unplug TV from mains.
    2. Wait at least 1 minute.
    3. Insert prepared USB into the TV.
    4. Press and hold the physical power/standby button on the TV, not the remote.
    5. While holding the button, reconnect mains power.
    6. Keep holding for about 10–15 seconds.
    7. Then wait several minutes.
    What you are looking for:
    - standby LED changing behavior,
    - USB stick activity LED blinking,
    - backlight briefly starting,
    - reboot after a few minutes.
    If the TV begins reading the USB, do not remove power. The manual explicitly warns not to switch power off during upgrade. (s3.infra.brandquad.io)
    What the current symptoms suggest
    If you get:
    - black screen,
    - no LED reaction change,
    - no USB activity,
    - no backlight,
    then my engineering assessment is that the problem is no longer just “wrong update steps.” It suggests one of these:
    Possible faultMeaning
    Wrong firmware file / wrong filenameBootloader does not recognize package
    Corrupted application firmwareTV cannot boot UI, but recovery may still work
    Corrupted bootloader / NAND / eMMC areaTV cannot even start USB recovery
    Mainboard hardware issuePower or memory subsystem failure
    If the forced USB attempt produces absolutely no reaction, then USB recovery is probably not being entered, and the next stage is usually external flash programming of the memory device on the mainboard, or replacement of the mainboard. That is an engineering inference, but it is consistent with your “black screen and no install” symptom.
    Practical guidance before hardware work
    Please check these points and report back:
    1. Standby LED
    - Is it on at all when the TV is plugged in?
    - What color?
    - Does it blink when you press power?
    2. USB stick
    - capacity in GB,
    - exact formatting method,
    - exact filename of the firmware on the stick.
    3. TV reaction
    - any backlight in a dark room?
    - any relay click?
    - any USB LED blinking?
    4. Firmware source
    - exact file name,
    - if possible, file size,
    - where it came from.
    My recommendation for your case
    At this point I would proceed in this order:
    1. Rebuild the USB correctly.
    2. Use the exact original filename from the package.
    3. Try forced start with the TV’s hardware power button.
    4. If still completely dead / black, stop repeated attempts and move to:
    - mainboard identification,
    - flash memory type identification,
    - external programming or board replacement.
    What I need from you now
    Please send:
    - the exact name of the
    .bin
    file
    - the USB size,
    - whether the front LED lights or blinks,
    - ideally a photo of the mainboard sticker.
    Then I can tell you whether:
    - the file is probably wrong,
    - the recovery method is wrong,
    - or the TV likely needs SPI/eMMC reprogramming.
    Brief summary
    This is most likely a failed firmware update. The official documentation for your model family confirms USB software update exists, but the exact recovery instructions depend on the firmware package, so the filename and package must match precisely. Do not use
    install.img
    advice from other Sharp series. If the TV shows no LED / no USB / no backlight reaction, the likely next step is hardware flash recovery on the mainboard. (s3.infra.brandquad.io)
    If you post the file name and LED behavior, I will narrow it down further.
