Behringer Europort MPA100BT: Seeking Service Manual for Battery Leak Repair
mitzhamike 747 0
  • Battery leak damaged resistors and coil on PCB
    #1 21425119
    mitzhamike
    Hi, I have an active loudspeaker Behringer Mpa100bt with no power, I found that the battery leaked on the pcb and 2 resistors and a coil, some smd are burned and I could not find a proper service manual to diagnose the problem and identify missing components.
    Maybe someone could help with the service manual or schematics.
    Thanks.
    AI: Have you tried contacting Behringer support or any local service centers for the service manual?
    No
    AI: Could you let us know your location or region? This might help in suggesting local resources or service centers.
    Romania
